-   General Electrical Discussion (https://www.electriciantalk.com/f2/)
-   -   Run Coax Through Recessed Outlet (https://www.electriciantalk.com/f2/run-coax-through-recessed-outlet-275064/)
Gooch4130 09-10-2019 09:18 PM
Is it against code to drill a hole in the top of a recessed outlet and run coax into it? I am only going to use the bottom plug so I am not concerned about space. There is at least 1.5" of 'recess' in the box and it would be far from the electrical wiring.
https://imgur.com/krhxMBA
Gooch4130 09-10-2019 09:29 PM
CoolWill 09-10-2019 09:32 PM
Not at all. Knock yourself out.
TheLivingBubba 09-10-2019 09:32 PM
TheLivingBubba 09-10-2019 09:50 PM
I'm auditioning for your other usernames Moderator spot, how did I do?
wcord 09-10-2019 09:53 PM
If you are in Canada, you can not mix the low voltage coax, with line voltage in the same box without a divider.
In the States, probably the same rule, unless you want to ignore the code as some "professionals" claim is okay to do so.
HackWork 09-10-2019 09:55 PM
It’s not in the same box. It’s just in the recessed portion in front of the box. As a professional, I know that.
CoolWill 09-10-2019 10:17 PM
You're in a dead heat. I think I need to see you two fight to the death.
You most certainly can do it in Canada. All you have to do is put the cable... in.. the... box. Simple.
TheLivingBubba 09-10-2019 10:28 PM
I can install a ceiling fan faster than him...but he's better looking than me.
OP find a link to what the box looks like, you're not going to be able to post pics till you get 20 posts.
Southeast Power 09-10-2019 11:04 PM
That was you. :vs_laugh:
