Running feeders in suspended Ceiling. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
Old 09-26-2016, 11:26 PM   #21
Rewards Points: 21,898
Most case I useally run EMT if you can get around it and if you have unblocked view you can run it straight shot.,,
but in real life it never be easy because ya never know what you snag into .,,
the last one I have to run 3 inch EMT in the ceiling from electrical room to the distubation panel and few spots I did actually smack right into a dense location of ductworks have to wiggle it little then got it thru and yes I did talk to my tin knocker contractor so he did help me a bit so it was a bessing in desgude due he have to fix the HVAC at the same time.
but yes I did use the large MC before and I am not too crazy with it if you are not prepare for it.
Majewski likes this.
glen1971 (09-26-2016)
Old 09-27-2016, 07:53 AM   #22
butcher733's Avatar
Rewards Points: 798
The universal trick is to find a 'horizon' -- an altitude above the grid -- that permits a straight shot.
All-thread drops and Sammy Super Screw solves all.
Take your pick of J-hooks or Minerallac straps.
Earlier this year my foreman started off my next job with the statement "I really wish we would have ran this Underground". I had to run two and a half inch EMT in a suspended ceiling through four rooms and across the hallway. I spent about an hour walking through everything with this story stick making marks for all the obstructions and ended up finding a space of about 5 inches that would let me get a straight shot through everything.
I ended up getting it done with three Factory ninety's a junction box, and one offset. Suspended ceilings and large pipe sucks.
I'll take therapists for $400.
butcher733 is offline   Reply With Quote
Old 09-27-2016, 08:21 AM   #23
Rewards Points: 26,908
It CAN get worse.
I had to run 3" EMT over a hard rocked ceiling -- with irritating insulation enough to give you silicosis in one-hour -- that required the "slinky-technique."
This translates as cutting down 10-foot sticks so as to add additional die-cast set-screw couplings rather willy-nilly. At each coupling, you gain a few degrees of freedom -- so as to snake the run through the framing. Naturally, an excessive number of two-hole straps are required.
This effort was delightfully followed up by tugging in 4x600 kCMIL in copper. ( Three quarter turns plus the slinky. )
I once spent EIGHT-HOURS to dope out a straight shot for a 2 1/2" EMT run.
I had to hit a thermal-exhaust port only 6"x6" that the emperor didn't protect. It was a very close call.
I'd run out of quarter-turns for that feeder, so I had to set a 18"x18" 3R pull can right atop the exhaust port.
Just feeding that hole long copper required a five-man crew.
At least I didn't have to pay their power bill.
Old 09-27-2016, 08:26 AM   #24
Not fun to run!
I read somewhere that this cable was invented for the Canadian mining industry.
Anyone: Is that correct ?
Old 09-27-2016, 07:35 PM   #25
Rewards Points: 24,170
I've read that in more than one blog.
Old 09-27-2016, 09:56 PM   #26
cabletie's Avatar
Rewards Points: 1,274
Not sure about that cable, but feeder size MI cable was invented by Satin himself. After running four parallel sets of MI through a hospital ceiling 2-1/2" EMT seems like 14-2 Romex.
Well I guess if it doesn't kill you it will make you stronger. Next time I would rather pound my head against a block wall for 160 hours.
HackWork likes this.
Twist lock receptacle in suspended ceiling Jamato General Electrical Discussion 31 07-31-2016 12:25 PM
Powerful ceiling fans ? tomatina General Electrical Discussion 12 05-19-2016 11:27 PM
Running MC ceiling Arikculwell Residential Electrical Forum 10 05-15-2016 05:41 PM
Basement drop ceiling SparkyinIL General Electrical Discussion 22 02-17-2016 09:09 PM
Difference Between Single and Dual Capacitor Ceiling Fan swimmer Residential Electrical Forum 6 01-08-2016 10:42 AM
