Running initiating and signal circuits in the same conduit? - Electrician Talk - Professional Electrical Contractors Forum
Old 08-05-2017, 09:09 PM   #1
Rewards Points: 228
Default Running initiating and signal circuits in the same conduit?
I'm in Alberta, Canada, and working with a fresh journeyman who insists he learned in school that for addressable systems, the initiating and signal circuits need to be in separate conduits.
I've wired systems in the same conduit before, and they've all passed inspection. Is there a CEC or fire code rule I'm missing?
quarky2001 is offline   Reply With Quote
Old 08-06-2017, 12:26 AM   #2
Rewards Points: 790
It's been a while since I've been involved in FA work..but with all the wiring rated for the same voltage ; and is all for the same FA system ; we've used same conduits for both.
Old 08-06-2017, 05:04 AM   #3
Rewards Points: 446
several years ago I researched this question and found nothing in NFPA 70 or 72 that required them to be separated .
farmantenna is offline   Reply With Quote
Old 08-06-2017, 05:41 AM   #4
Rewards Points: 26,374
I've never seen an addressable notification circuit. These operate by DC polarity reversal.
So they have no potential to generate cross-talk nor to detect it coming the other way.
Consequently, there is no theoretical reason that they can't share a conduit.
Old 08-06-2017, 09:34 AM   #5
MTW
Rewards Points: 9,962
It's standard practice to run them in the same raceway here, unless dictated otherwise by manufacturers requirements. So far I have never seen that to be the case.
Old 08-06-2017, 10:42 AM   #6
halfamp's Avatar
Rewards Points: 516
No reason they can't be ran together
Also @telsa Simplex has both addressable strobes and speakers
halfamp is offline   Reply With Quote
The Following User Says Thank You to halfamp For This Useful Post:
telsa (08-06-2017)
Old 08-06-2017, 10:45 AM   #7
MTW
They do, but everyone hates Simplex. In my area, people avoid it whenever possible.
Old 08-06-2017, 10:50 AM   #8
halfamp's Avatar
Rewards Points: 516
While I'll admit that their service is great in some areas, other areas it is certainly less than perfect. Their product I believe is truly second to none, and just as addressable inputs proved to be the trend of the future, I'm sure other manufacturers will also trend to addressable outputs as they can be much better tailored to local reporting functions (CO alarming, suppression system notification)
I've had more than my share of hair pulled out from dealing with simplex
Old 08-06-2017, 02:43 PM   #9
Bird dog's Avatar
Rewards Points: 776
I think it's more practical than a specific requirement. I see no reason unless it is easier to run them together. In large buildings, why should I run my pull station wire through all my horn & strobe boxes.
Old 08-06-2017, 05:24 PM   #10
Rewards Points: 228
Thanks all, that's exactly what I thought. I have no idea where this fellow got the idea they had to be separated.
I've actually installed Simplex addressable strobes - they're pretty awesome, and make the VI an absolute breeze! Our engineer was comfortable with the following procedure: disconnect the loops one by one, and ensure that the appropriate devices disappear. Then, just create a ground fault at the first and last strobe in the loop (assuming Class B), and you're good to go!
A tip if anyone sees these though - pictured is the the culprit, for the love of god DON'T snap the strobe into the speaker portion until you've cleared all your troubles. The only way you change the address after you've done this involves 4 flatheads and a lot of luck, or cutting the back open to get at the DIP switches. I learned this the hard way.
Old 08-06-2017, 05:26 PM   #11
Rewards Points: 228
I've had terrible luck with Simplex hardware and their technicians. I'll take Edwards over them any day!
