Running NM for Kitchen Counter - Electrician Talk - Professional Electrical Contractors Forum
Old 07-22-2015, 11:22 PM   #1
A Little Short's Avatar
Rewards Points: 822
Default Running NM for Kitchen Counter
When doing a new house or just a new kitchen, do you run your NM for the counters above or below the receptacle boxes?
Meaning the horizontal run between boxes.
Which ever way, why do you do it that way?
Just a curiosity thing, I've done it both ways. Just thought I would see which way/why everyone else does it.
Old 07-22-2015, 11:25 PM   #2
It really depends on where the best access is for running the wires. Done it both ways you've described.
120/208 is offline   Reply With Quote
The Following User Says Thank You to 120/208 For This Useful Post:
MXer774 (07-24-2015)
Old 07-22-2015, 11:30 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
It's usually a mishmash, especially when it comes to the framing around windows. Sometimes it's just easier to go up and across the ceiling.
Big Pickles (07-25-2015)
Old 07-22-2015, 11:37 PM   #4
Rewards Points: 822
Done plenty of that this week. They used pre-fabbed walls and they had to re-do a lot especially around windows. Had 4-5 deep 2x4s and no room to drill, so UP & Over they went!
I just got to thinking after determining my homerun box which way is better to head to the next box. No windows or anything just wide open to the next box. Above or below, I didn't see a compelling reason for either way.
Old 07-22-2015, 11:37 PM   #5
Rewards Points: 11,027
Try to keep it between the countertop and upper cabinet heights so the cabinet installers don't screw into it.
The Following 10 Users Say Thank You to 99cents For This Useful Post:
220/221 (07-22-2015), daveEM (07-23-2015), fargowires (07-23-2015), jrclen (07-25-2015), meadow (07-24-2015), papaotis (07-24-2015), shocksystems (07-24-2015), TheWireNut (07-25-2015), transient (07-24-2015), wildleg (07-24-2015)
Old 07-22-2015, 11:39 PM   #6
Don't worry. The siders will get it.
Old 07-23-2015, 12:17 AM   #7
Rewards Points: 15,409
I won't pull any wire anymore till all the siding and trim is up. Nailguns will shoot a nail right thru T-111 and nail plates, and into a cable drilled in the center of a 2x4 exterior wall. (mostly all we get around here...). Current building code here requires #8 or longer siding nails. It gets a bit hotter working in a closed in house, but it sure keeps the wire from getting shot by tards.
Old 07-23-2015, 12:37 AM   #8
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
That never happens,,,,well maybe it does....
Old 07-23-2015, 07:42 AM   #9
It doesn't matter how long you wait.
SOMEONE WILL eff up your work sometime.
Old 07-23-2015, 07:44 AM   #10
Rewards Points: 1,080
I have always run the wire below the receptacle box. Never had an issue
120/208 (07-24-2015)
Old 07-23-2015, 11:35 PM   #11
Rewards Points: 5,198
I am not a residential wire man but I recently completed my kitchen. I did not know the short cuts. Looking back I wish I had just gone from each receptacle straight down to the unfinished basement and tied into j-boxes.
Old 07-24-2015, 06:45 AM   #12
Then you'll kick yourself when you finish the basement.
Dash Dingo (07-24-2015)
Old 07-24-2015, 08:35 AM   #13
That's for sure.
Old 07-24-2015, 09:11 AM   #14
Rewards Points: 38
I usually run my wires above the boxes, but it depends on the job.
Bay Ridge is offline   Reply With Quote
Old 07-24-2015, 04:11 PM   #15
Very Long Vacation
Rewards Points: 5,262
Did that trip the breaker?
Old 07-24-2015, 08:16 PM   #16
220/221's Avatar
Rewards Points: 3,998
To me, in any situation, the make up always seems easier and cleaner when the cables enter at the top.
Old 07-24-2015, 08:41 PM   #17
Rewards Points: 4,130
Mount a sub and feed it with 40a, run every receptacle to a dedicated 20a breaker. Now you can put any appliance anywhere you want.
Old 07-24-2015, 08:48 PM   #18
Dash Dingo's Avatar
Rewards Points: 318
I nail plate ever stud where there is a bored hole with wires in it, where I know there is a base or upper cabinet going.
I've seen how long some of those screws are the cabinet installers use.
Dash Dingo is offline   Reply With Quote
The Following 2 Users Say Thank You to Dash Dingo For This Useful Post:
Big Pickles (07-25-2015), Nobaddaysinak (07-24-2015)
Kitchen counter The_kid NEC Code Forum 17 02-14-2015 02:14 PM
Kitchen counter receptacles 347volts General Electrical Discussion 12 01-17-2015 10:20 AM
Kitchen Counter 20A Aegis Canadian Electrical Forum 44 01-24-2014 08:24 PM
Kitchen Counter Receptacles Chris1971 Residential Electrical Forum 12 01-31-2013 09:18 PM
Kitchen Counter top noarcflash Residential Electrical Forum 31 12-18-2011 02:23 PM
