RV generators - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By backstay
  • 1 Post By Bird dog
  • 2 Post By Bird dog
Old 09-13-2017, 12:12 PM   #1
Rewards Points: 214
Default RV generators
I purchased a new Champion 3100 watt generator for our camper. Has the usual 30a 120 RV recept, and a 20a 120v regular recept. Instructions say the neutral is isolated from the ground and frame, and attached to the stator in the generator. So the ground tied to the frame would not be grounded, unless a jumper is put in tieing neutral and ground together. Also I called Champion and they said newer camper trailers with GFI recepts in them would not work either. unless the neutral and ground are tied together in generator. Which seems to make sense. So on older campers without GFI recepts, the Ground on the generator could become hot and not trip anything? including trailer grounds. Doesn't seem right. Also there is a ground terminal on the outside of the generator that the book says you can tie to a ground rod. Also doesn't make sense since a ground rod is completely separate from the generator. I do electrical work but first newer generator. ..Any input would help.
(Also it has the inverter built into it for better output at any RPM.)
alselec53 is offline   Reply With Quote
Old 09-13-2017, 01:34 PM   #2
backstay's Avatar
Rewards Points: 296
Where to start...tying ground to neutral is called bonding. GFCI receptacles don't need a ground to function. Does the RV panel have the ground and neutral bonded in the service panel? I hope not, yet the GFCI receptacles would work just fine. If you run the generator as the power source to the RV, the neutral/ground need to be bonded somewhere. It would be done at the power pedestal in an RV park. You also should drive a ground rod or two at the generator location, but most people don't.
Bdm likes this.
Old 09-13-2017, 03:33 PM   #3
Rewards Points: 214
Not plugged into a RV park, generator only, is different.
The RV GFI recept will work without a ground but probably will not trip on a ground fault.
What is the ground rod for if its grounded to nothing. The generator is its own power source, separte from any power company, making the ground rod useless. The ground rod has to have a path to the source whatever that path may be. Where am I wrong here?
Old 09-13-2017, 04:23 PM   #4
Bird dog's Avatar
Rewards Points: 2,058
The ground rod would be a static electricity drain, so, no one is shocked if they're outside and touch the RV. It's not a return path for the generator or the GFI.
Speedy Petey likes this.
Old 09-13-2017, 06:33 PM   #5
backstay's Avatar
Rewards Points: 296
Look into two wire receptacles replaced with GFCI receptacles. You don't need a ground to a gfci to function. Try this, remove the ground wire to a gfci receptacl. Then take your Wiggy and touch the hot and the ground you removed. It will trip. If you're brave (dumb) use your fingers.
Old 09-13-2017, 09:26 PM   #6
Rewards Points: 214
Default RV Generator
Your right about the GFI tripping without a ground wire, because it is taking another path other than the correct neutral path.
So on the generator the camper GFI should work with even having the separate ground wire only tied to the frame of the generator. That makes sense..
But in the event of the ground becoming hot, I don't see how the breaker on the generator would trip, .. being an isolated neutral.
Old 09-13-2017, 09:29 PM   #7
Rewards Points: 1,360
Just make a cheater to tie the generator neutral to ground.
Old 09-13-2017, 09:54 PM   #8
Rewards Points: 214
Default RV Generators
Yes, .. actually, I think they have a jumper in the generator to do that.
Also they have a ground rod terminal, which seems useless with a generator.
Old 09-13-2017, 11:21 PM   #9
Band Member
emtnut's Avatar
Rewards Points: 2,500
Ground on any system could become hot, and not trip the breaker !!!
... A ground rod on a floating neutral genset, would put the frame at ground potential ... It's also required if the genset is a separatly derived system
As others have said ... If a gfci is tripping, it's because there is an imbalance between hot and neutral currrent.
There would have to be a neutral to ground bond somewhere in that trailer, and the current is taking 2 paths.... Even thou your generator doesn't have a ground rod... it's sitting on the ground, and the current sees that as a separate path.
Old 09-13-2017, 11:22 PM   #10
Band Member
emtnut's Avatar
Old 09-14-2017, 01:16 PM   #11
Rewards Points: 214
Don't listen to which guy?
Old 09-14-2017, 01:27 PM   #12
Bird dog's Avatar
It's Emtnut's signature & it's said jokingly.
dronai and emtnut like this.
Old 09-15-2017, 12:25 PM   #13
Rewards Points: 214
I know.. lol
Old 09-15-2017, 07:34 PM   #14
Band Member
emtnut's Avatar
I know.. lol
Are you sure ??
Old 09-16-2017, 09:42 PM   #15
Rewards Points: 214
I guess not.. lol
Old 09-16-2017, 09:46 PM   #16
Band Member
emtnut's Avatar
I guess not.. lol
... I'm the guy you shouldn't listen too
Old 09-16-2017, 10:39 PM   #17
Rewards Points: 214
no worries, lol
Noise Generators RunningSparky Commercial Electrical Forum 5 06-18-2016 07:29 PM
Geothermal generators? Nobaddaysinak Alternative Energy Forum 10 06-16-2016 08:50 AM
Generators starting up with no power loss LightsOn81 General Electrical Discussion 15 05-19-2016 03:04 PM
Generators Switched Business, Marketing, and Sales 13 04-06-2016 08:21 PM
Propane vs Diesel fuel for Generators katwalatapan Canadian Electrical Forum 21 02-20-2016 01:59 AM
