scissor lift stops after going up 9 feet - Electrician Talk - Professional Electrical Contractors Forum
Like Tree41Likes
Unread 04-13-2019, 08:48 AM   #1
Rewards Points: 20
Default scissor lift stops after going up 9 feet
scissor lift stops after going up 9 feet, it is supposed to go up for 16 foot
I ordered a scissor lift from you one year ago
It was working fine until two weeks ago It goes up for 9 feet, Then it stops.
I do not know what is the cause
Do I need to add more hydraulic fluid? If so then how to do it?
The lift is operated by 110 V
Attached is some pictures
I tried attaching pictures but it is asking me to enter URL
justme0987 is offline   Reply With Quote
Unread 04-13-2019, 08:56 AM   #2
Semper Fi
Southeast Power's Avatar
Rewards Points: 7,212
The annual maintenance is due.
justme0987 likes this.
Unread 04-13-2019, 08:57 AM   #3
Rewards Points: 9,611
I found the section in the maintenance manual for you.
scissor lift stops after  going up 9 feet-6df5bf94-a22a-46d3-812d-91018528b789.jpg
glen1971 and Bird dog like this.
Unread 04-13-2019, 09:00 AM   #4
Rewards Points: 20
What is the specifics that need to be done
Thanks
Unread 04-13-2019, 09:03 AM   #5
Semper Fi
Sounds like a tilt sensor but, I would have someone come out and do the maintenance and "recertify" it unless is some kind old very old junkyard rescue.
If its worth keeping, its worth professional maintenance.
Unread 04-13-2019, 09:05 AM   #6
Rewards Points: 20
where to find professional to do the maintenace?
I live in Baldwin county AL
Unread 04-13-2019, 09:06 AM   #7
Rewards Points: 20
how to search for scissor lift professinal? This lift is one yesr old
Unread 04-13-2019, 10:26 AM   #8
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 1,888
try this
http://bfy.tw/ND8n
The_Modifier and glen1971 like this.
Unread 04-13-2019, 10:28 AM   #9
Rewards Points: 16,906
What brand is it?
Have you googled factory service the brand?
Kind of reminds me of Hand holding 101........
glen1971 and TGGT like this.
Unread 04-13-2019, 11:10 AM   #10
360max's Avatar
Rewards Points: 1,228
Make sure nothing is underneath the very bottom of lift so the guards can protrude toward ground (they are the length of lift on each side on bottom sides, and protrude when lift goes up) .
micromind, glen1971 and Helmut like this.
Unread 04-13-2019, 11:12 AM   #11
360max's Avatar
Sounds like lift guards are stuck
micromind and Helmut like this.
Unread 04-13-2019, 11:18 AM   #12
MikeFL's Avatar
Rewards Points: 1,670
Check the blinker fluid. Happens to me all the time and I once thought about moving to Alabama, so maybe that's why.
I smell a troll. Question is, who is it?
Bird dog likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Unread 04-13-2019, 11:18 AM   #13
Rewards Points: 2,188
justme0987
Please take a few minutes and fill out your profile.
The_Modifier likes this.
Unread 04-13-2019, 12:41 PM   #14
Rewards Points: 2,094
Most, if not all, lifts have tilt sensors. These are to prevent you from going too high when parked on a slope and thus, tipping over.
They go bad sometimes and the lift won't go over a certain height.
Unread 04-13-2019, 01:01 PM   #15
Rewards Points: 20
I think the problem is with the hydraulic oil
I notices that the reservoir is low in oil
What type of oil I need to add?
Do I need to adjust anything else after adding the oil?
Anyway to post pictures here?
Unread 04-13-2019, 01:08 PM   #16
Rewards Points: 20
is it better to use AW-32 or AW-46
Unread 04-13-2019, 01:08 PM   #17
Rewards Points: 20
I live in south Alabama Thanks
Unread 04-13-2019, 01:12 PM   #18
You need to read your owner’s manual. If you don’t have it, find it online.
Unread 04-13-2019, 01:15 PM   #19
Rewards Points: 20
I imported the lift from China, Got it last year , no owner manual, some documents in Chinese
Unread 04-13-2019, 01:18 PM   #20
Rewards Points: 20
Just emailed the manifacturer for the owner manual in English
500 feet UF, how much available power? MattM-NC General Electrical Discussion 54 03-13-2019 09:54 PM
battery powered vacuum on 20 feet emt conduit Wire Tags General Electrical Discussion 64 12-14-2018 11:46 PM
Socks and your feet MikeFL Tools, Equipment and New Products 19 07-06-2018 07:47 PM
Best Work Boots For Sweaty Feet Manganga New Member Introductions 32 04-06-2018 10:38 PM
Arc fault rule (adding more than 6 feet of wire) Anathera NEC Code Forum 4 02-25-2016 09:17 AM
