Self-Test GFCI's - Electrician Talk - Professional Electrical Contractors Forum
Old 02-19-2015, 12:17 PM   #1
Slave to the grind
CopperSlave's Avatar
Rewards Points: 630
Default Self-Test GFCI's
I just got this email from one of our supply houses. They are anticipating the costs to as much as double. We do a lot of new resi stuff....this will surely make an impact on our costs. I guess UL has decided that the general public is too stupid/lazy to push a test button.
I spend most of my money on racing and beer...the rest of it I waste.
CopperSlave is offline   Reply With Quote
The Following User Says Thank You to CopperSlave For This Useful Post:
51360 (02-19-2015)
Old 02-19-2015, 12:51 PM   #2
Rewards Points: 1,464
I completely agree with that move. It is obvious from recent posts here a few electricians almost bought it by not testing them before use. Do you suppose homeowners test also?
Old 02-19-2015, 12:58 PM   #3
Rewards Points: 64
I have seen the self test AFCI from Eaton and I have had trouble with them. They would only trip on self test. Replaced with a different non test model and all was good. Hope they don't have the same issues with the gfci
Old 02-19-2015, 01:14 PM   #4
Rewards Points: 1,224
What happens when the device fails its self test? Does it trip and kill the power to the equipment? Or does it just prevent resetting after a power outage or a manual test?
Old 02-19-2015, 01:49 PM   #5
Slave to the grind
Rewards Points: 630
From what I'm seeing, it will trip and not reset and, have to be swapped out with a new one.
Old 02-19-2015, 01:57 PM   #6
Rewards Points: 64
The one I had issues with would trip -- you reset it and then days later with no one at home the afci would trip. The code stated it tripped on self test. They say if that happens then replace the afci. I had 2 of them do that
The Following 2 Users Say Thank You to Dennis Alwon For This Useful Post:
51360 (02-19-2015), guest (02-19-2015)
Old 02-19-2015, 01:59 PM   #7
Slave to the grind
Rewards Points: 630
Those are the trouble calls that make you want to scream right there. I can only hope that Indiana keeps writing AFCI's out of the Code.
Old 02-19-2015, 02:51 PM   #8
To be clear we are talking about GFCIs in this case..
More troubling is the statement about how they (Eaton) are already planning on stopping production of the current GFCI line...
Time to go to the big box stores and stock up on the standard kind before the self-test units take over...
My question is this: Who mandated the change? UL or the NEC Code Nazis?
Old 02-19-2015, 02:58 PM   #9
I own stock in FotoMat!
Rewards Points: 6,520
Originally Posted by mxslick View Post
...........My question is this: Who mandated the change? UL or the NEC Code Nazis?
Self-test does not appear in the NEC.
Old 02-19-2015, 02:59 PM   #10
Not yet anyways...isn't Eaton on a few of the CMP's?
Old 02-19-2015, 06:44 PM   #11
No need for that to be in the NEC if it is in the product standard. In fact, in my opinion, things like that don't belong in the NEC, they belong in the product standards.
Old 02-19-2015, 06:49 PM   #12
Pass & Seymour says:
1.) Auto-Monitoring or Self-Test function: This function allows for periodic, automatic testing of the ability of the GFCI to respond to a ground fault. If the Self-Test function detects a problem, the GFCI must deny power or provide visual and/or audible indication.
I would expect that most manufactures will opt for the alarm in place of shutting off the power on a failed self test.
This is a revision UL 943, the product standard that covers GFCIs. From what I have read, the standard will apply to GFCI devices for the US, Canada, and Mexico. NEMA and the CPSC had a hand in the new product standard.
Old 02-19-2015, 06:54 PM   #13
Just one......... CMP10, Art. 240.
Old 02-19-2015, 07:12 PM   #14
Going_Commando's Avatar
Rewards Points: 1,652
Really? More fricken cost and pieces of junk to deal with? I should have gone HVAC. This crap is rediculous
The Following 2 Users Say Thank You to Going_Commando For This Useful Post:
five.five-six (02-20-2015), MTW (02-19-2015)
Old 02-19-2015, 08:45 PM   #15
MTW
Rewards Points: 677
Totally agree. I'm sick of manufacturer driven product changes. Furthermore, this is just another move in response to lack of personal responsibility.
The Following User Says Thank You to MTW For This Useful Post:
TheWireNut (02-20-2015)
Old 02-19-2015, 09:11 PM   #16
Rewards Points: 419
No kidding.
We have a monthly GFCI PM at our facility. There was once that I found a GFCI that would not trip, so I labeled the receptacle "FAILED - DO NOT USE" and made sure it covered all the holes in the recept.
Came back a few hours later to replace the recept, and found someone had plugged something into it. They didn't bother to remove the label, they jammed the plug right through it.
mikey383 is offline   Reply With Quote
Old 02-19-2015, 10:03 PM   #17
Rewards Points: 1,379
You don't understand. Every morning you get on your knees, close your eyes and express your undying love, gratitude and devotion to the Breaker Gods. Then the nuisance tripping miraculously disappears.
Old 02-19-2015, 10:07 PM   #18
MTW
Rewards Points: 677
So, if I'm understanding this correctly, all GFCI's must be self-testing after the cut off date. I'm guessing economies of scale will bring the price down eventually, but right now a self test GFCI is about $20. I can't see the price being significantly lower than that, and certainly not in the $10-13 range that a regular TR GFCI costs now.
Old 02-20-2015, 06:30 PM   #19
Rewards Points: 265
I think we should call a self testing GFCI the "Nanny State Outlet" sounds nicer and fewer syllables to say. Gives a nice warm fuzzy feeling to the common receptical drab.
TWN
TheWireNut is offline   Reply With Quote
Old 02-20-2015, 07:05 PM   #20
Rewards Points: 124
It's always something.
Mike
Circuit Tracer is offline   Reply With Quote
Why does a GFCI circuit breaker cost $5 more than a AFCI/GFCI Black Dog General Electrical Discussion 23 02-09-2015 01:32 PM
Required to the test the test button on E-Lights brother General Electrical Discussion 13 11-24-2014 10:36 PM
How many of you actually test GFCI's at your own home? Ragin Cajun General Electrical Discussion 16 05-07-2014 08:26 PM
test gfci ratrod56 General Electrical Discussion 11 10-25-2011 08:55 PM
State Electrical Test vs National Test SlayeR NEC Code Forum 28 03-28-2009 10:22 AM
