Separated Garage sub panel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By Helmut
Closed Thread
Old 12-15-2016, 05:36 AM   #1
Default Separated Garage sub panel
Hey guys,
So here's what's going on... I've been a contractor for around 15 years, I barely ever play with electric aside from the basics. Until recently anyway. I just moved into a new place and long story short, the garage for my house needs electric. Here's the deal..
Right now, my garage has a small fuse box with 1 light and 1 outlet off it. Then running out the wall, underground through conduit and into the basement is the connection to the main breaker.
The run from the Main to the Garage is roughly (just under) 200ft. I just upgraded the house main with a 200amp box. Now I want to install the old 100amp box into the garage.
Any recommendations on first, what size wire I should use for the run from the main to the sub panel? [Again, 200ft distance, with below ground conduit, to a 100amp subpanel] and also, any other recommendations or input anyone would like to put in, by all means I'm open to it! I'm trying to get this done asap. Like I said, I know most of what I'm doing, im just getting drained trying to figure out the best way to supply power to the panel.
Thanks ! -- Reaper.
DarkWoodsReaper is offline
Old 12-15-2016, 05:59 AM   #2
German Spy
Helmut's Avatar
Rewards Points: 4,535
Hire and pay an Electrician.
Majewski likes this.
Helmut is online now
Old 12-15-2016, 06:04 AM   #3
Lol i can do eveything myself, why hire one just to run a length of cable? I just am unsure what the best wiring will be to use given the voltage drop due to distance, etc. I've installed new switches on breakers, grounding rods, basically everything aside from wiring the meter to the main itself. But I appreciate the reply.
Old 12-15-2016, 06:06 AM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
the site has had a few bugs recently. did you happen to see any messages when you registered ?
wildleg is offline
Old 12-15-2016, 06:09 AM   #5
Aside from a welcome to the site message? Was there something I should be looking for?
Old 12-15-2016, 06:37 AM   #6
ponyboy's Avatar
Rewards Points: 709
Originally Posted by DarkWoodsReaper View Post
I'm not just a DIY person, im a contractor. I had assumed this was a forums site where other contractors gave tips and the like to others. It's called electrician talk, I didn't think it was just for gossip lol, I assumed it would be a.good place to get a simple answer.
But alright no big deal, literally thousands of other sites. Thanks guys, take care.
This site is for electrical contractors and electricians. It said that on the page you had to fill out to register.
ponyboy is offline
Old 12-15-2016, 07:10 AM   #7
Speedy Petey's Avatar
Rewards Points: 642
I understand you are a contractor, even one who "barely ever play with electric aside from the basics", but this is still DIY question. This was made very clear when you joined the site.
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Speedy Petey is offline
Closed Thread
different panel from same switch gear, & panel feeder and branch circuit question mike883 General Electrical Discussion 33 10-21-2017 10:20 PM
Garage Panel Board gregalex General Electrical Discussion 1 11-05-2016 01:43 PM
Phase loss at sub panel in detached garage Nmartin General Electrical Discussion 57 10-17-2016 10:05 PM
Garage 3 wire feeder sub panel vinniem General Electrical Discussion 29 07-31-2016 09:50 PM
