Service Entrance... a few questions - Electrician Talk - Professional Electrical Contractors Forum
Old 02-23-2015, 05:10 PM   #1
Rewards Points: 186
Default Service Entrance... a few questions
Hi guys I need your help again for personal research
Q1 - How do we call the neutral cable unshielded actually supports the line conductors and on wish a messenger wire is attached for the neutral?
Q2 - Is a special wire required outside (from the pole to the building)... ABC? I'm guessing steel instead of copper
guitarboyled is offline   Reply With Quote
Old 02-23-2015, 05:15 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Messenger wire.
The middle strand is steel. ACSR stands for Aluminum Conductor Steel Reinforced.
Big Pickles (02-23-2015), nbb (02-24-2015)
Old 02-23-2015, 05:19 PM   #3
Rewards Points: 6
If your talking about that cable you have pictured there, we call it quadplex. 4 conductors hence the "quad". They also make 2 and 3 conductor aerial cables. Called duplex and triplex. The uninsulated wire is commonly used as a grounded conductor. It has aluminum wrapped around a single steel wire for strength. Hope I answered your question? Be safe.
Hired Hand is offline   Reply With Quote
Old 02-24-2015, 09:42 AM   #4
Rewards Points: 186
If I understand correctly both the unshielded wire that acts as a support for the line wire is called the messenger and so is the short portion of wire clamped to it near the service cap
Q3 - In a 3 phase entrance (for example main entrance connected to a switch gear or a splitter trough) the messenger goes directly to the neutral busbar or lug?
Q4 - How is the messenger sized?
Old 02-24-2015, 10:27 AM   #5
daveEM's Avatar
Rewards Points: 2,382
The bare conductor of the overhead wire is the Neutral. It goes to the neutral bar. 'Hired Hand' explains that particular cable.
It is sized by the cable manufacturer... You decide on the amperage of your outbuilding and look it up in the code and order the cable, be it tri or quad plex.
Install your 'point of attachment' below the service head.
I like perfect.
Old 02-24-2015, 05:47 PM   #6
Rewards Points: 6
I hope I understand your question correctly, forgive me if not. The short portion of wire I think your talking about which goes into the weather head(service cap) is actually crimped into the bare "messenger" wire your referring to. Just like any typical meter/panel main you have your conductors running from the meter base to the outside of your weatherhead. The bare in most cases will be crimped onto your grounded conductor(neutral) outside the head with the other cables. You or the poco(depending on how nice yours is) will install a bolt on porcelain or rubber knob to your pipe going through the roof about 1 foot under the cap. Then they will attach what's called a "catch off" to the bare conductor which will clamp on to the knob or bolt on clamp. Then all the weight/stress of the cable is on the steel wire in the bare conductor. From there they will probably crimp on to all conductors coming from your mast. Be safe.
2 service sets of service entrance conductors same raceway cheezhd2008 General Electrical Discussion 2 11-11-2013 11:08 AM
Two service entrance questions subelect Services and Service Equipment 18 08-12-2011 06:19 PM
Service Entrance Voltech NEC Code Forum 8 03-18-2011 12:40 AM
Old Service Entrance davis9 Vintage Electrical 7 12-04-2010 05:40 PM
Service Entrance silva.ac Services and Service Equipment 6 01-29-2009 06:51 PM
