Service Upgrades/Panel changes - Electrician Talk - Professional Electrical Contractors Forum
Old 03-01-2015, 07:05 PM   #1
Rewards Points: 46
Default Service Upgrades/Panel changes
How many of you guys use ACWU or TECK90 from the meterbase outside to the panel inside?
Ive always used Pvc and changed the pipe to the size required which most of the time is a pain in the ass due to making the hole bigger going inside the house.
Also teck cable or acwu would be cheaper then pipe + rw90 right?
Buzz355 is offline   Reply With Quote
Old 03-01-2015, 07:20 PM   #2
Rewards Points: 3,014
Not sure if the USA has teck cable
Old 03-01-2015, 09:21 PM   #3
MHElectric's Avatar
Rewards Points: 4,746
I don't know much about that Teck cable you Canadians have, but from what I've seen and heard on these sites, I'm ready for the U.S. to start making this stuff readily available as well.
I'd be ecstatic if Home Depot started carrying it.
Old 03-01-2015, 10:20 PM   #4
Rewards Points: 1,637
I typically sleeve SE cable inside of PVC pipe under the meter. Once it goes into the house I just run SE cable to the panel. That provides both protection and good looks outside while giving you the ease of running SE cable to the panel.
The Following 2 Users Say Thank You to HackWork For This Useful Post:
Big Pickles (03-01-2015), electricdrummer (03-02-2015)
Old 03-01-2015, 10:25 PM   #5
Rewards Points: 3,090
Have you priced the two methods out and compared?
I wouldn't use teck in your situation, as it looks ugly.
Teck has it's advantages. Search Teck on line, interesting reading. Started in the mines of Kirkland Lake, Ontario. One of my old stompin grounds.
Borgi
Old 03-01-2015, 11:04 PM   #6
daveEM's Avatar
Rewards Points: 2,382
Tech is garbage. Unless it's buried and never seen.
I like perfect.
Old 03-01-2015, 11:07 PM   #7
Rewards Points: 3,994
It has it's place and looks decent when installed properly.. Same as conduit.. Some guys are better at doing underground so their work is hidden..
Tray cable on the other hand... That stuff is junk...
Old 03-02-2015, 02:26 AM   #8
Rewards Points: 14,269
You use ACWU or Teck because it's cheaper to install. Whatever works. I have zero problems using it if it makes my job easier.
Old 03-02-2015, 08:31 AM   #9
Mountain Electrician's Avatar
Rewards Points: 238
Living close to Canada, and working in a Canadian owned mill, I see this stuff quite a bit. My supply house stocks smaller sizes, but I can order anything I need and have it on site in a few days. I don't mind it, it just seems it gets improperly installed quite often.
The 'ole "subject to physical damage" conversation.
I have never used it in a residential application.
http://catalog.basicwire.com/viewite...r-power-cables
Old 03-02-2015, 10:15 AM   #10
Vintage Sounds's Avatar
Rewards Points: 4,004
It does exist in the US. It's called "MC-HL".
Old 03-02-2015, 10:42 AM   #11
Wyome
Rewards Points: 914
The supply houses I use are not too excited about it.
Service Upgrades cthermond Business, Marketing, and Sales 21 02-22-2014 07:24 PM
Need some Advise. Panel upgrades. whittom Commercial Electrical Forum 6 02-21-2014 10:13 AM
waterproofing service upgrades vida General Electrical Discussion 0 10-09-2012 08:45 PM
How many service upgrades? Zparme General Electrical Discussion 9 07-12-2012 06:45 AM
Service Upgrades Trimix-leccy Services and Service Equipment 26 06-09-2008 09:38 PM
