Services/Branch Circuits - Electrician Talk - Professional Electrical Contractors Forum
Old 08-09-2015, 11:07 PM   #1
Rewards Points: 18
Default Services/Branch Circuits
I have a customer that wants to protect the conductors supplying power to chillers. The feeders now are being fed directly from a transformer to starter. The starters are inside the chiller plant and the customer would like to add a disconnect outside adjacent to the transformers. Is it possible to use disconnects that size for the feeders? The transformers are 500 KVA 480/277 volts (2 chillers) and 1000KVA 480/277 volt (2 chillers). The starters are the only disconnecting means that is currently supplying the load. Thanks
eagle2014 is offline   Reply With Quote
Old 08-09-2015, 11:30 PM   #2
CADPoint's Avatar
Rewards Points: 1,838
...The feeders now are being fed directly from a transformer to starter
Wouldn't the Starter be rated as the disconnect in this case? I'm missing what else they need...
Is it in fact a tap, that they need to change?
Address the circuits needs by using a breaker or in you case (a fused) disconnect.
Adding a breaker to the bus would be cheaper with a sitting disconnect.
If you are even thirsty, you are two quarts low.
Old 08-09-2015, 11:41 PM   #3
Rewards Points: 18
The customer want to disconnect the feeders from the transformer. Plus the taps from the transformer is more that 25 ft., but it does have a fused starter. The seem to think a disconnect adjacent to the transformer is code and safer.
Old 08-09-2015, 11:47 PM   #4
Rewards Points: 26,538
Your need // logic is a tad off.
Disconnect at these dedicated (oil cooled, Poco style, pad mounted) transformers.
Your job is done.
Your proposal is going to cost big $$$$$ to not achieve much.
Old 08-09-2015, 11:49 PM   #5
Rewards Points: 5,198
Are you saying that there is no fusing?
Old 08-10-2015, 12:14 AM   #6
Rewards Points: 18
There are fuses in the starter.
Old 08-10-2015, 12:29 AM   #7
A WAG: There should be fuses in the big transformers, too.
They are normally manipulated by a hot stick.
Old 08-10-2015, 12:32 AM   #8
It's protected.
Al. Branch circuits Clarky Residential Electrical Forum 6 04-12-2014 11:26 AM
Branch Cir. Split/2 Services Mr. Rodgers General Electrical Discussion 3 12-24-2013 03:23 PM
Sub or Branch Circuits? k_buz General Electrical Discussion 7 10-21-2012 07:45 AM
More Range Branch Circuits? appropriate tech Residential Electrical Forum 10 09-14-2012 06:22 PM
Range Branch Circuits appropriate tech Residential Electrical Forum 4 09-03-2012 04:52 PM
