Servit Covers - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By MDShunk
  • 3 Post By MDShunk
  • 1 Post By matt1124
  • 1 Post By glen1971
Old 04-03-2018, 02:17 PM   #1
Vacated
Wiresmith's Avatar
Rewards Points: 2,848
Default Servit Covers
Burndy Servit Hug-A-Bug covers
does anyone know of similar covers for things like bolting lugs or ring terminals together for applications like motor terminals?
Old 04-03-2018, 02:19 PM   #2
Rewards Points: 6,421
Not specifically, but if you use a Polaris bug you can eliminate all the hassle.
brian john likes this.
Old 04-03-2018, 02:27 PM   #3
Vacated
Wiresmith's Avatar
if i can use compression(or cadweld on critical circuits/in poor environments) over mechanical i will every time, i think a bolted compression connection is a more robust connection.
Old 04-03-2018, 04:35 PM   #4
I suspect the solder and tape guys were saying the same thing when wire nuts hit the scene.
Old 04-03-2018, 10:25 PM   #5
Magic Smoke Remover
Rewards Points: 1,966
Wirenuts are killing the trade
Wiresmith likes this.
Old 04-03-2018, 10:25 PM   #6
Rewards Points: 3,984
Do you mean something like these?
https://www.cesco.com/Thomas-Betts-T...Black/p1895444
Couple of wraps of 88 backwards before you put them on and you're good to go.. They make them in all sizes and up to 5k that I know of..
Wiresmith (04-06-2018)
Old 04-06-2018, 01:56 PM   #7
Vacated
Wiresmith's Avatar
we do get a lot more service work because of them though.
Old 04-06-2018, 01:58 PM   #8
Vacated
Wiresmith's Avatar
exactly like that, thank you very much. do you like using them? might be better for vibration rubbing.
Old 04-06-2018, 04:21 PM   #9
That's all I've used for years.. There have been a few to tape, but not many.. They make motor change outs a lot easier.. Lots of the places I worked, we did all the rotation changes in the field, so we did the black phase (center up here) up first 100%, then just 88'd the other 2 and slipped the boots on. Once the rotation was checked, they could be done 100% or switched if needed.
If you're worried about vibration, they 88 backwards can fill in the sharp edges of your crimp lug, nut, etc.. Sometimes a piece of rubber inside the peckerhead of the motor may let you sleep better too, but I've only done that on a couple that I can recall..
The ones for 5kv are a little different, but still they beat taping that's for sure..
Bell/Taymac expandable in-use covers MTW NEC Code Forum 37 08-17-2017 09:59 PM
Old LB Fitting. Need Covers swimmer Residential Electrical Forum 4 03-25-2017 10:02 PM
Residential in use covers Nibor3470 General Electrical Discussion 10 10-15-2016 01:36 PM
Hinged panel covers Sparkchaser1 NEC Code Forum 7 06-03-2016 02:31 AM
Obsolete Square D QOC442L series G2 Panel Covers RePhase277 General Electrical Discussion 2 01-19-2016 02:11 PM
