That is Sharp - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 1 Post By nrp3
  • 2 Post By mdnitedrftr
  • 2 Post By nrp3
  • 1 Post By drspec
  • 2 Post By Chris1971
  • 2 Post By Dash Dingo
  • 2 Post By Switched
Old 07-04-2017, 08:21 AM   #1
Rewards Points: 1,902
Default That is Sharp
Was out in the warehouse getting a meter I needed and backed into back box someone left standing up it fell over and landed on my arm. I felt it slicing my skin below the elbow. Six stitches later
Not the first time I have been cut to the point of needing stitches by a box, had a fish tape come loose once and slit the back of my hand.
Another time or two I can't remember the circumstances but stitches were had.
Old 07-04-2017, 08:31 AM   #2
Rewards Points: 804
Ouch!
Old 07-04-2017, 08:41 AM   #3
Rewards Points: 1,360
Speaking of backing into things and feeling pain, someone moved my driver's side mirror and I didn't notice while half asleep. I backed into a slow speed collision with a tree yesterday morning. Pissed me right off first thing. The Love Bus needs stitches too.
Old 07-04-2017, 08:44 AM   #4
Can't Remember
Rewards Points: 390
One of the builders I was working with a few years back got cut up bad when the back of his hand ran across the edge of a broken ceramic soap dish. Cut right through the tendons. I drove him to the emergency room for some surgery. The hand specialist was on duty that day so he was taken care of quickly.
Old 07-04-2017, 10:42 AM   #5
Rewards Points: 804
I cut myself on the back of an electric range a few years ago. Ended up getting 6 stitches. Waltched the ER doctor stitch me up. Was quite interesting.
Old 07-04-2017, 10:47 AM   #6
mdnitedrftr's Avatar
Rewards Points: 1,131
Sometimes I feel like these companies purposely sharpen things so people will get hurt.
Big John and Dash Dingo like this.
- Rich
mdnitedrftr is offline   Reply With Quote
Old 07-04-2017, 10:50 AM   #7
Rewards Points: 2,868
Broken ceramic is often like a razor blade edge.
Sheetmetal cut on a dull shear leaves a super sharp burr that I have encountered many times.
Once just pulling a washer forward to engage the self leveling legs, cut right across all the fingers on my hand.
Old 07-04-2017, 10:52 AM   #8
More like they are cheap and don't sharpen their cutting tools.
Old 07-04-2017, 10:55 AM   #9
Can't Remember
Rewards Points: 390
Almost anywhere there's stamped sheetmetal from studs to appliances, you're at risk.
brian john and MechanicalDVR like this.
Old 07-04-2017, 11:04 AM   #10
backstay's Avatar
Rewards Points: 296
I cut my finger nail the other day.
Old 07-04-2017, 11:17 AM   #11
No mention of stitches so I guess you executed it well!
Old 07-04-2017, 11:34 AM   #12
drspec's Avatar
Rewards Points: 1,116
The last time I can remember ending up with stitches was a few years back. I was rushing a meter base replacement and was having trouble getting the old one off of the wall. So I got a good grip on it and tugged hard, that resulted in the meter base getting hung on the service cable and the top of it caught be across the bridge of my nose. I was pouring blood, but had to finish the job so power could be restored.
Got home and the wife made me go to the emergency room where I believe I received 6 stitches and a slight concussion diagnosis.
brian john likes this.
Old 07-04-2017, 11:39 AM   #13
Rewards Points: 804
With your sawzall?
brian john and backstay like this.
Old 07-04-2017, 04:23 PM   #14
Dash Dingo's Avatar
Rewards Points: 318
Metal strip fixtures are made from recycled razor blades.
brian john and RePhase277 like this.
Dash Dingo is offline   Reply With Quote
The Following User Says Thank You to Dash Dingo For This Useful Post:
brian john (07-04-2017)
Old 07-04-2017, 05:01 PM   #15
Originally Posted by Chris1971 View Post
With your sawzall?
M12 bandsaw, get with the times, sawzalls are old hat.
Old 07-04-2017, 05:02 PM   #16
Old 07-04-2017, 07:08 PM   #17
Rewards Points: 44
Working on lift above ceiling, pulling in MC - felt a tug on my hand.
I pulled my open hand across the corner of a metal stud used as a brace across the corner of two walls ( it was turned up ) 6 stitches and now 4 years later I'm having tendon problems with two fingers.
Think they will re-open workers comp case ??
FF301 is offline   Reply With Quote
Old 07-04-2017, 07:46 PM   #18
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Originally Posted by FF301 View Post
...I pulled my open hand across the corner of a metal stud used as a brace...
I got some gnarly cuts from those things. If I'd stayed in construction sooner or later one would've sent me to the ER.
Always wear your gloves.
Old 07-04-2017, 08:05 PM   #19
Switched's Avatar
Rewards Points: 9,082
A number of years ago I was using a flex bit to go from a second story to the first, the bit bound up and the drill kept going. It split the drill shaft into two pieces, one stuck in the chuck and the other slapped me on the face..... Or so I thought...
My face stung a little, but that was to be expected as it just hit me. No bother, I just headed down to the truck to grab another and start the whole process. As I passed by the Super on the job I noticed a look of shock on his face.
I stopped and asked if he was alright, wiping my sweating face with my forearm at the same time. I noticed that my forearm was covered in blood, and as I scanned it for the cut I began to realize that blood was pouring from another direction.
At that moment someone had grabbed me and placed their button-up shirt on my face.... I suddenly began to realize what happened.
I had opened up my face from the bottom of my ear to the bottom of my chin, very deep and very clean. Blood spewed from it all over the floor and onto me.
I got a nice drive to the closest Doc-in-the-Box, where they said "No way we are sticking that, he needs the emergency room!"
I showed up to the hospital and ended up with a plastic surgeon to seal my face back up, just a small scar is all that is left on the bottom of my skin... That guy was worth every penny he charged WC!
...... I still hate flex bits.....
brian john and chicken steve like this.
Old 07-04-2017, 09:21 PM   #20
Nope two years out of date in states I've worked in.
