Shoe horn for LB.. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 09-27-2013, 07:38 PM   #21
Tool Fetish
I sent a guy out last week to pick up two 2-1/2" malleable LBs. We were going to pull three 350s + ground. LBs came with "4/0 MAXIMUM" molded into the wall of the LBs. Sent him back and installed two sweeps instead.
I'm pretty sure that there is a maximum conductor size on PVC LBs also.
SteveBayshore is offline   Reply With Quote
Old 09-27-2013, 07:54 PM   #22
Rewards Points: 1,224
Originally Posted by 360max View Post
they have it your just to cheap to buy it.
I have never had any luck using those...the rollers just pop out when you put much pressure on them.
There was a brand (maybe Efcor) that came with a rounded piece of metal with slots that kind of snapped into the end of the fitting giving you a smooth round surface to pull over. Those worked good for me.
Old 09-27-2013, 09:05 PM   #23
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
Originally Posted by B4T View Post
Yesterday I had to get 4/0 AL through a 2" PVC LB.. no fun...
It would be great if some manufacture came up with something like a shoe horn to make the conductors "slide" through easier..
Anyone ever come across such a labor saving devise??
I have, its called a 2 1/2" LB
The Following User Says Thank You to sparky970 For This Useful Post:
wildleg (09-28-2013)
Old 09-27-2013, 09:52 PM   #24
Cow
Rewards Points: 5,262
I'm getting ready to pull a couple parallel runs of 4-350's and a 1/0. I'm using a 4" Form 35 LB for each run. Fortunately, it came with the rollers inside! These ones stated 3-500's max, close enough for me.
Old 09-27-2013, 10:43 PM   #25
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
no sh*t...use bigger pipe
I'd rather be sleeping.
Old 09-28-2013, 12:52 AM   #26
Rewards Points: 1,572
Is Efcor still around? Did read that Bridgeport owns the rights to Efcor & Regal Fittings also.
Edit: Hubbell owns Efcor, no mention of the brand being marketed on their website.
Norcal is offline   Reply With Quote
Old 09-28-2013, 12:43 PM   #27
Jlarson's Avatar
Rewards Points: 4,320
Had to form some wires.
Old 09-28-2013, 06:11 PM   #28
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Originally Posted by 15millionand5 View Post
I'm not understanding this thread at all.
(3) X 4/0 al is extremely common to put thru a 2" PVC LB is services.
The thread is about a product to make the job easier... idea is never work harder than you have to.....
If tool makes the job easier.. you buy it..
Welcome to ET.. where the clowns don't need a tent to try and make people laugh..
Old 09-28-2013, 06:31 PM   #29
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
if you want to provide an NEC compliant installation, you need to follow the rules.
Here is a link to carlon's own information on their LB's. Read it and weep:
http://www.carlonsales.com/techinfo/...y_Wirefill.pdf
BBQ (12-21-2013)
Old 09-28-2013, 06:34 PM   #30
wildleg's Avatar
I'm not liking you very much anymore.
If I followed those stupid NEC rules I wouldn't be able to instal a PVC riser out of a meter hub either.
In reality, there are a billion services with 3 X 4/0 running thru a 2" PVC LB. And it's fine. Code is for gay people.
as if anyone didn't know where you would stand. hello again cletis.
Old 09-28-2013, 07:21 PM   #31
EBFD6's Avatar
Rewards Points: 1,014
I'm not cletis you gaytard.
Yeah, everyone knows he's Hackwork.
EBFD6 is offline   Reply With Quote
Old 09-28-2013, 07:22 PM   #32
wildleg's Avatar
cletis, hackwork, what's the dif?
Old 09-28-2013, 07:24 PM   #33
drspec's Avatar
Rewards Points: 1,120
I know of a few services that have 4/0 set installed in 2" LBs.
Pretty sure that needed a bit of coaxing.
Old 12-21-2013, 08:50 PM   #34
I've had the chance to use the RackATiers LB shoe horn 3 separate times over the last couple weeks. I'm not a big fan.
In all 3 situations I was pushing 4/0 Al thru 2" pipe and LB.
It worked ok to guide the wire out of the LB when pushing down from the meter. But when trying to push the loop into the LB going into the house and down thru a 90, the shoe horn wouldn't stay in position. It kept moving and made the process hard. I tried and gave up in all 3 installations.
Haxwoper is offline   Reply With Quote
Old 12-21-2013, 10:55 PM   #35
sparky402's Avatar
Rewards Points: 534
Ive heard its easier to use an LR or LL instead. I havent tried it but ive had guys swear by it.
sparky402 is offline   Reply With Quote
Old 12-21-2013, 11:11 PM   #36
BBQ
Salty Member
BBQ's Avatar
Old 12-21-2013, 11:12 PM   #37
Originally Posted by BBQ View Post
Yeah, I mean, wtf?
The Following User Says Thank You to Haxwoper For This Useful Post:
dronai (12-22-2013)
Old 12-21-2013, 11:23 PM   #38
Ive heard its easier to use an LR or LL instead. I havent tried it but ive had guys swear at it.
FIFY....
Old 12-22-2013, 04:38 AM   #39
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
those things suck nutz
Old 12-22-2013, 07:53 AM   #40
mbednarik's Avatar
Rewards Points: 1,126
Ll and lr bodies should be avoided like the plage if you are near pulling max conductor through it.
Remember the Shoe Bomber? Semi-Ret Electrician Off Topic (Non Trade) 3 07-07-2013 01:19 AM
Greedy Shoe Companies? brian john Off Topic (Non Trade) 41 06-26-2013 07:54 AM
If The Shoe Fits 360max Off Topic (Non Trade) 11 05-09-2013 07:56 AM
Shoe Shine Tech dronai Off Topic (Non Trade) 10 12-28-2011 06:36 PM
horn/strobe??? BigIssues General Electrical Discussion 14 12-08-2010 01:18 AM
