Shop bathroom receptacle? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By flyboy
Old 05-06-2019, 11:54 AM   #1
German Spy
Helmut's Avatar
Rewards Points: 4,523
Default Shop bathroom receptacle?
Say a auto mechanics shop bathroom, not open to the public.
Landscaper shop bathroom, for employees...ect
Are you required to put a receptacle in there?
Old 05-06-2019, 01:07 PM   #2
Rewards Points: 20,695
Depends on your code cycle. If up to date then yes, bathroom receptacles are now required 2017 NEC to be gfi protected, dwellings and non dwellings.
Nationalize all foreign owned farmland now. Now.
Old 05-06-2019, 01:29 PM   #3
German Spy
Helmut's Avatar
oh, so in the 2017 cycle, they now require receptacles in non dwelling bathrooms?
Old 05-06-2019, 01:50 PM   #4
Rewards Points: 1,303
The only rule is that if you do install an outlet it must be GFCI protected. It doesn't have to be 20A or dedicated, or exist in the first place.
I don't know of any change for the 2017.
Helmut (05-06-2019)
Old 05-06-2019, 03:10 PM   #5
sbrn33's Avatar
Rewards Points: 3,564
Hax is right, no need to put one in there and if you do just throw in a GFCI rec on any circuit you want.
Is hax smarter than Mikey?
Old 05-06-2019, 03:12 PM   #6
Let me clarify. I am not saying that there is definitely no change for 2017. Just that I haven't seen one.
Old 05-14-2019, 09:35 PM   #7
DashDingo's Avatar
Rewards Points: 22
No
DashDingo is offline   Reply With Quote
Old 05-14-2019, 11:54 PM   #8
Are we sure? I thought it was one of the bullet points in the update code class I just sat thru for the 17 cycle. I admit I COULD be wrong, We are still on the 2008 code. Still. I don't even know why they make us go to code update classes. We are still on the 2008 code.
Old 05-15-2019, 12:33 PM   #9
Small Potatoes
flyboy's Avatar
Rewards Points: 4,249
YES
So if you're on the 2008 code why are you concerned about it? As of 2008, 2011, 2014 and 2017 there is no requirement for a receptacle in a commercial bathroom.
See 210.52 Dwelling Unit Receptacle Outlets.
See 210.52 (A) General Provisions. Again, the code speaks to and uses the term "dwelling units"
Dwelling Unit. A single unit, providing complete and independent living facilities for one or more persons, including permanent provisions for sleeping, cooking, and sanitation.
Guest Room and Guest Suites fall under the definition of Dwelling Unit and by definition a receptacle would be required in the bathroom of those occupancies.
No where in the 2017 NEC Handbook (Article 210 or anywhere else) can I find an exception or note that requires a receptacle be installed in a non dwelling unit bathroom.
sbrn33 likes this.
Old 05-15-2019, 12:40 PM   #10
[QUOTE=flyboy;5196484]So if you're on the 2008 code why are you concerned about it? As of 2008, 2011, 2014 and 2017 there is no requirement for a receptacle in a commercial bathroom.
No where in the 2017 NEC Handbook (Article 210) can I find an exception or note that requires a receptacle be installed in a non dwelling unit bathroom.[/QUOTE
Zip your flyboy up. I admitted I might be wrong. I sat thru a four hour code upgrade class. I yawned a whole lot. Guess I screwed up. I sat thru a timeshare seminar once too. Didn't buy a timeshare. Got a free dinner at a hotel and a round of golf though.......
Old 05-15-2019, 01:10 PM   #11
Small Potatoes
flyboy's Avatar
[quote=macmikeman;5196490]
Zip my flyboy up?
no receptacle in bathroom chuckd83 Residential Electrical Forum 75 02-20-2019 02:10 PM
240 volt receptacle in coffee shop big vic General Electrical Discussion 20 06-24-2018 10:27 PM
Does this bathroom receptacle need afci? NDC Canadian Electrical Forum 9 06-12-2018 04:58 PM
Receptacle required in a commercial Handicap Bathroom sparky1plug NEC Code Forum 3 11-28-2017 09:55 PM
adding a ground papaotis Residential Electrical Forum 71 05-22-2017 11:54 AM
