Shot in the dark regarding pipe routing - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 2 Post By btharmy2
  • 1 Post By wildleg
Old 08-10-2017, 07:59 PM   #1
Rewards Points: 228
Default Shot in the dark regarding pipe routing
Don't know if anyone will have any bright ideas, but I'm sure this problem has been encountered by people here before.
I'm doing a commercial building, but we're only doing the base build - fire alarm, emergency lighting, and powering the roof top units. Then the tenant shows up and builds whatever else they want.
For the RTUs, I have to get 5 pipes out of the electrical room (basement) and onto the ceiling of the 2nd floor, so there are two slabs to bust through. Here's the problem. Because it's only a base build, we only really have exterior walls (and a couple very small interior walls, none big enough to fit five 1" emt pipe into) to run pipe through, which is fine, but it seems that at the top and bottom basically every wall on the 1st floor, there's a giant steel I-beam at the bottom of it, making it impossible to get a pipe through it.
How do you find routes in this sort of place?
quarky2001 is offline   Reply With Quote
Old 08-10-2017, 08:20 PM   #2
Rewards Points: 262
Run them exposed up the wall of the electrical, mechanical or janitor closet on each floor.
MechanicalDVR and telsa like this.
btharmy2 is offline   Reply With Quote
Old 08-10-2017, 11:44 PM   #3
cabletie's Avatar
Rewards Points: 1,274
Keep them close to columns. They will box around them later.
Old 08-11-2017, 12:20 AM   #4
Rewards Points: 3,050
Like cabletie said I'd look to run up along side a column.
Old 08-11-2017, 12:48 AM   #5
Switched's Avatar
Rewards Points: 9,260
Brian said dryer duct was the conduit... Being super flexible it should help out some!
I like Cabletie's suggestion....
Old 08-11-2017, 01:50 AM   #6
Rewards Points: 18,279
Smart fellers just run ser cable up the columns and poke thru the middle of the H. I seen drywallers using spray on 3M adhesive to install bull nose and corner bead , so maybe you could use the same for vertical supports every 4-1/2 feet....
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 08-11-2017, 09:56 PM   #7
Rewards Points: 228
Thanks for the advice - sadly there are no electrical/janitors closets besides the main electrical room, but I really like the column idea. They're going for a future "industrial" look in the final building, so they're not boxing out the columns (I know, electrical pipe would add to that decor nicely, but whatever...), but I'm definitely keeping that idea under my hat, thanks!
We found two crappy non-structural walls we're going to run through though. It involves a bit of sneaky work with pull elbows.
Old 08-11-2017, 10:01 PM   #8
Why try to hide it if they are going for the industrial look?
Old 08-11-2017, 10:08 PM   #9
360max's Avatar
Rewards Points: 1,234
....run up the wall that houses the stairwell, that wall remains the same for the life of the building
Old 08-11-2017, 11:29 PM   #10
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
your profile says you are an apprentice, so I am answering the post with that in mind.
when you run into a wall and have no plan showing how something is to be installed, you have to think of a few things.
1) how much does what you propose to do going to cost ?
2) is your installation practical ?
3) what does the client want ?
4) what do the plans and specs indicate ?
5) what did your company include in the bid for this item ?
these questions should always run through your mind when you are planning some work. If you install a gold plated solution for something that your company estimated based on a dime store budget, you are not doing anyone, including yourself, any favors.
Installing pulling ells and hard to install pull runs because someone didn't provide a place for the pipework is also not necessarily the best solution.
Sometimes these type of things come up and a best fit solution based on the estimate/bid, the plans, and a compromise needs to be worked out with the powers that be, whether that is onsite jobsite management or above.
just my 02
B-Nabs likes this.
Pipe Drop from ceiling to shelve darren79 Canadian Electrical Forum 4 01-27-2017 07:57 PM
Pipe fill ElectricalArtist General Electrical Discussion 10 08-22-2016 07:33 PM
Gas Pipe Conference Table (Standards for concealed wiring) sparky158 General Electrical Discussion 1 03-24-2016 03:06 PM
