Should I trust this motor? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-10-2015, 01:01 PM   #1
mr.photon's Avatar
Rewards Points: 78
Question Should I trust this motor?
This motor is on sale for about $40, its a 3 phase. It seems to be surplus. Should i be able to trust it? I will be running it off Wye 3ph.
http://www.surpluscenter.com/Electri...FC-10-2844.axd
"Science isn't about why, Its about why not!" -Cave Johnson
mr.photon is offline   Reply With Quote
Old 02-10-2015, 01:04 PM   #2
Rewards Points: 664
why do you think there would be a problem? if it is connected correctly & given the right voltage it should work fine. it looks to be a foreign made motor.see it is made in india. wouldn't expect the same performance as an american motor , but i could be wrong.
circuitman1 is offline   Reply With Quote
The Following User Says Thank You to circuitman1 For This Useful Post:
mr.photon (02-10-2015)
Old 02-10-2015, 01:05 PM   #3
mr.photon's Avatar
Rewards Points: 78
The "foreign made" part is what im worried about. I dont know how well it will work up to its ratings or how long it will last.
Old 02-10-2015, 01:09 PM   #4
Rewards Points: 664
we had chineese motors made by TATUNG they were absoulute garbage.for the price i would give it a try. know the german & italian are good we had a lot of them on our machines.
Old 02-10-2015, 01:11 PM   #5
mr.photon's Avatar
Rewards Points: 78
I am going to try to use them on a drill press, so i dont know how well it will work for that. I will have to live up to its 1/3 hp rating.
Old 02-10-2015, 01:14 PM   #6
Rewards Points: 664
for a drill press i don't see a problem.
Old 02-10-2015, 01:41 PM   #7
daveEM's Avatar
Rewards Points: 2,382
$40.00?
Might work.
I like perfect.
Old 02-10-2015, 01:42 PM   #8
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
just don't buy it here
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Lep is offline   Reply With Quote
The Following User Says Thank You to Lep For This Useful Post:
Old 02-10-2015, 01:48 PM   #9
mr.photon's Avatar
Rewards Points: 78
Ok i will trust you on that one...
$40 is very questionable, but it is just $40, so why not...
Old 02-10-2015, 02:00 PM   #10
Rewards Points: 234
Many motors including many US companies outsource motors. What motor line besides Baldor do you think are actually built in the US?
Brook Crompton has a good name in the industry.
Why would you be running it wye connected? It very well could be a nine lead motor.
In fact, unless its nine leads, its not a true dual voltage motor.
Price looks good. Whats the application?
Old 02-10-2015, 02:04 PM   #11
mr.photon's Avatar
Rewards Points: 78
I will be using some for multiple applications, one on a drill press(if it works well), one on a small hose acceleration pump, and one more just for testing.
Old 02-10-2015, 02:25 PM   #12
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
Toshiba Lincoln electric us motors...they all have us made lines of motors.
12 lead motors are dual voltage.
At that price and if that is a name brand motor I would suspect it is a Chinese knock off. They like to copy things and the have one tiny misspelling to remove liability.
Old 02-10-2015, 02:59 PM   #13
Lep
Lep's Avatar
You never know I guess they could be shorting you a couple turns per coil,what else crappy bearings,funky laminations.
Old 02-10-2015, 03:36 PM   #14
NC Plc's Avatar
Rewards Points: 7,888
How much does it matter if it fails? You didn't say what the application was.
I would take it apart and look around before I used a motor that cheap.
NC Plc is offline   Reply With Quote
Old 02-10-2015, 03:38 PM   #15
mr.photon's Avatar
Rewards Points: 78
I did mention it in post 11, Quote -
"I will be using some for multiple applications, one on a drill press(if it works well), one on a small hose acceleration pump, and one more just for testing."
Old 02-10-2015, 03:53 PM   #16
NC Plc's Avatar
Oh, I missed it. I wouldn't use it without first taking it apart and checking out what they went so cheap on. All of that stuff sounds like hobby related projects not industry related projects.
Old 02-10-2015, 04:00 PM   #17
mr.photon's Avatar
Rewards Points: 78
The pump is going to be the most important. I will be building It soon. It
will have to be running almost all the time, its for a water flow accelerator for a pump system, so it must be running almost all the time under load. Starting and stopping will be computerized by a programmed vfd.
Old 02-10-2015, 07:54 PM   #18
NC Plc's Avatar
If it's really important, why are you using a cheap and questionable motor?
The Following User Says Thank You to NC Plc For This Useful Post:
metalpats (02-13-2015)
Old 02-10-2015, 08:00 PM   #19
mr.photon's Avatar
Rewards Points: 78
I want to explore all options, i mean, $40? why not.
Old 02-10-2015, 08:22 PM   #20
NC Plc's Avatar
If it's a critical asset you don't go cheap. I would never put a questionable motor into operation doing something where a failure would either cost money, cause damage, or cost production time.
I don't just see the cost of the motor I see the cost of replacing it with another motor, the cost of the lost production, the cost of damage caused by the failure of the motor, and the cost of replacing other components that possibly would go out due to a domino effect of the above mentioned failure.
I mean, it's whatever you want to do but since I do industrial maintenance wherever critical assets are concerned I spend the money for reliability instead of trying to cut corners.
Tags
motor, surplus
Trust your gut. 99cents Business, Marketing, and Sales 10 06-24-2014 10:00 AM
Trust your intuition... 99cents Business, Marketing, and Sales 6 07-03-2013 06:43 PM
Do you always trust your instincts? Magnettica General Electrical Discussion 38 07-08-2011 10:29 PM
Never trust a contractor Bob Badger Off Topic (Non Trade) 3 08-10-2010 02:49 PM
losing trust 3phase General Electrical Discussion 14 04-24-2008 09:42 PM
