Siemens Load Center - Electrician Talk - Professional Electrical Contractors Forum
Old 07-09-2012, 11:40 PM   #1
A Little Short's Avatar
Rewards Points: 1,194
Default Siemens Load Center
Will regular Siemens breakers fit a Siemens Mfg Housing Load Center?
Or simply put, is there a difference between a regular Siemens panel and Siemens Mfg Housing panel?
Old 07-09-2012, 11:47 PM   #2
Rewards Points: 2,002
Is it a standard 1" plug on breaker?
Old 07-10-2012, 12:01 AM   #3
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
they are all type QP
Old 07-10-2012, 12:02 AM   #4
Originally Posted by TOOL_5150 View Post
they are all junk.
Fixed it for ya.
The Following 3 Users Say Thank You to user4818 For This Useful Post:
electrictim510 (07-10-2012), Shockdoc (07-10-2012), TOOL_5150 (07-10-2012)
Old 07-10-2012, 12:14 AM   #5
Well actually these were QT. Which I think means "twins" or "tandems"
Most of the mobile homes I've seen used a C/H panel but this one was a Siemens. It said "Siemens Mfg Housing Load Center" and I didn't know if they were different than a standard one.
Old 07-10-2012, 12:18 AM   #6
Rewards Points: 21,665
The breakers cost less than 5 bucks, so why not go on a wild fling and buy one and try it?
I stand with Tucker Carlson
Old 07-10-2012, 12:48 AM   #7
Ambassador of Amps
TOOL_5150's Avatar
Originally Posted by Peter D View Post
Fixed it for ya.
haha yep, stupid auto-correct.
Old 07-10-2012, 09:58 AM   #8
Rewards Points: 1,006
Even my damn iPhone has an opinion.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 07-10-2012, 09:59 AM   #9
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
$100 and i can get a GE THQ to fit
Old 07-10-2012, 10:21 AM   #10
Resi Service Electrician
electrictim510's Avatar
Rewards Points: 550
$200, a drill, sawzall, duct tape and a soldering gun and I'll make any breaker fit.
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
electrictim510 is offline   Reply With Quote
Old 07-10-2012, 10:37 AM   #11
The keys here, of course are cash and duct tape.
__________
Old 07-10-2012, 06:16 PM   #12
Rewards Points: 864
And a very big hammer!
Sparky J is offline   Reply With Quote
Old 07-10-2012, 08:43 PM   #13
Ok Mr. "Surfy Man" hope it rains on both sides of the island at the same time!
I have some on my truck, but if I get the job I would like to know if I had the right ones and not have to run to the S/H. I'm not going to take a breaker out just to see if it fits when I was just there for an estimate.
The panel only had twins in it so I didn't know from looking at them if a standard Siemens would fit or not.
Old 07-10-2012, 10:19 PM   #14
Rewards Points: 2,950
If there are already QT breakers installed then QP will work. The buss is the same for both. The QT requires a notch in the buss to allow the "rejection tab". QP will fit with or without the notch in the buss.
The Following User Says Thank You to btharmy For This Useful Post:
A Little Short (07-10-2012)
Help with Load Center RandyH General Electrical Discussion 12 12-05-2011 09:41 PM
capacity of a 600 amp load center Buzz239 General Electrical Discussion 7 03-09-2011 02:12 PM
320 or close load center boggs General Electrical Discussion 2 12-20-2010 11:33 AM
Sears load center sprky777 Vintage Electrical 19 08-12-2008 09:03 PM
