Siemens resi panel - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 06:41 PM   #1
Very Long Vacation
Rewards Points: 5,262
Default Siemens resi panel
Anyone else find the newer main breaker Siemens panels have the neutral/ground bar only on one side? Or is it just a bunch of HD returns?
Old 02-17-2015, 06:44 PM   #2
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,366
Did you pick up one of the contractor specials with an aluminum bus and free breakers?
Old 02-17-2015, 06:48 PM   #3
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
there is only one N/G? GD.
I'd rather be sleeping.
Old 02-17-2015, 06:57 PM   #4
Very Long Vacation
If you mean the value packs then yes.
Old 02-17-2015, 07:05 PM   #5
Yeah Toast!!
Roger123's Avatar
Yes, that is how the "value packs" are made.
Old 02-17-2015, 07:15 PM   #6
Very Long Vacation
Even taking out parts? These panels can allow up to 40 circuits using tandems, I don't see enough holes with just one bar.
Old 02-17-2015, 08:47 PM   #7
Rewards Points: 1,138
This is the reason I stopped buying panels at Home Depot, a 200 Amp Siemens panel from supplier comes with 2 ground/neutral bars and two ground bars
'I believe that banking institutions are more dangerous to our liberties than standing armies"
Thomas Jefferson
electricalwiz is online now   Reply With Quote
Old 02-17-2015, 09:36 PM   #8
Very Long Vacation
Guess I got a home chepo exclusive
Old 02-17-2015, 09:45 PM   #9
Big Pickles's Avatar
A 100 amp 30/30 from hd comes with 2 of each.
Big Pickles is offline   Reply With Quote
Old 02-17-2015, 09:56 PM   #10
Rewards Points: 3,078
All of the ones from my supplier are copper bus, 2 ground bars, 2 neutral bars.
Greg
Old 02-17-2015, 10:05 PM   #11
Rewards Points: 184
200 amp 40 circuit used to come with neutral/grd bars that went the full length of the bus, no matter if it was al bus or copper and supply house or HD, now they only go halfway down. 100a/24 circuit MB panels now only have a bar on one side, if your using it as a subpanel you need to purchase and additional bar kit. Total BS to me as this used to be my preffered brand for installs. Not sure of 30/30's as i never install them.
NJSparky is offline   Reply With Quote
Old 02-17-2015, 10:06 PM   #12
MTW
Rewards Points: 10,272
Thanks for reminding me once again why I prefer Square D.
The Following User Says Thank You to MTW For This Useful Post:
meadow (02-18-2015)
Old 02-17-2015, 10:09 PM   #13
Rewards Points: 184
I just did a new house and used a homeline with the lock-on neutrals for AFCI's. not a bad panel and kept the pigtails out, only thing i didn't like was that there isn't alot of 1/2" KO's in the top as they put a big concentric on the left side that took up alot of space.
Old 02-17-2015, 10:12 PM   #14
Look at the ground bars on the PL series
http://w3.usa.siemens.com/powerdistr...pl-series.aspx
Greg
Old 02-17-2015, 10:19 PM   #15
Rewards Points: 184
I've never seen that panel before, they must not stock them around here. My only gripe with that is those ground bars at the top are right where the conductors are supposed to be routed IMO. they are in the way and once the hots are laid in there you can't get to them to add circuits without moving everything. why not just run the middle ones all the way down and call it a day?
Old 02-17-2015, 10:21 PM   #16
Rewards Points: 184
Here's what I'm used to seeing around here
http://w3.usa.siemens.com/powerdistr...es-series.aspx
Old 02-17-2015, 10:24 PM   #17
Ya, Aluminum bus. My supplier only supplies copper bus.
I agree about the position of the ground bars, dumb location.
Greg
Old 02-17-2015, 10:25 PM   #18
Rewards Points: 184
that panel comes in copper bus also but it's set up exactly the same.
Old 02-17-2015, 10:26 PM   #19
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Take 5 grounds and put them in a greenie, and only land the sixth one.
Old 02-17-2015, 10:31 PM   #20
corn-fused
papaotis's Avatar
Rewards Points: 620
most of the panels i see have pretapped evenly spaced holes in the back where you can add a bar or MOVE the one thats in it
The Following User Says Thank You to papaotis For This Useful Post:
derekwalls (02-18-2015)
siemens breaker in a sq d QO panel ampman General Electrical Discussion 12 05-05-2011 10:58 AM
need an interior for an older Siemens panel ChristopherL General Electrical Discussion 3 12-01-2010 09:06 AM
what else fits in a siemens panel jjdrees General Electrical Discussion 26 06-03-2009 01:06 PM
Can I use a Murray in this Siemens panel? Solar Z General Electrical Discussion 28 05-29-2009 12:01 AM
Siemens panel problem jack davis General Electrical Discussion 2 02-24-2009 09:21 PM
