Siemens resi panel - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 10:34 PM   #21
Rewards Points: 184
Yes, but why should I have to add/move bars in a brand new panel. why can't they get it right? 2 screw terminals for every breaker space should be code!
NJSparky is offline   Reply With Quote
Old 02-17-2015, 10:46 PM   #22
Rewards Points: 14,275
But HD is always cheaper and you can buy 99% of your stuff there.
Cough, gag, hack, puke...
Old 02-17-2015, 10:57 PM   #23
corn-fused
papaotis's Avatar
Rewards Points: 620
but why supply so many terminals when each terminal will hold ' up to 3 #10 wires' . from the specs of a panel i was looking at the other day. dont remember which one. if the mfg. suggests that then why does everyone think its a sin?
Old 02-17-2015, 11:06 PM   #24
MTW
Rewards Points: 10,272
The value packs are definitely cheaper than the supply house.
Old 02-17-2015, 11:07 PM   #25
MTW
Originally Posted by meadow View Post
Anyone else find the newer main breaker Siemens panels have the neutral/ground bar only on one side? Or is it just a bunch of HD returns?
Where in CT are you buying Siemens panels at HD?
Old 02-17-2015, 11:07 PM   #26
Rewards Points: 184
My supply house sells both
Old 02-17-2015, 11:12 PM   #27
Rewards Points: 184
Because the code says it's a sin. double tapping neutrals is a no-no. also look at this panel, it's a 30/30, which means it has a potential of 60 120volt circuits. there aren't nearly enough screws!
http://w3.usa.siemens.com/powerdistr...es-series.aspx
edit: thats a 40 circuit, but the 30/30 is the same
Old 02-17-2015, 11:13 PM   #28
MTW
Mine does too, but they sell Eaton/CH and I don't use that stuff.
Old 02-18-2015, 01:46 AM   #29
Very Long Vacation
Rewards Points: 5,262
200 amp 40 circuit used to come with neutral/grd bars that went the full length of the bus, no matter if it was al bus or copper and supply house or HD, now they only go halfway down. 100a/24 circuit MB panels now only have a bar on one side, if your using it as a subpanel you need to purchase and additional bar kit. Total BS to me as this used to be my preffered brand for installs. Not sure of 30/30's as i never install them.
It looks like they've got different styles now based on what and where you buy them. Total BS considering this got me by surprise.
NY and Mass HDs have them. But I just looked at their site, apparently half of them have the bar on one side or shortened. No way can I get AFCIs to work in these panels without it looking like arse:
http://www.homedepot.com/b/Electrica...vZbm2wZ1z0x9jn
And for that price lowes still has the full version in stock:
http://www.homedepot.com/p/Siemens-E...vZbm2wZ1z0x9jn
MTW (02-18-2015)
Old 02-18-2015, 08:30 AM   #30
Rewards Points: 48
Default Wider Loadcenters
Siemens ES series loadcenters with the shortened neutral bars are a PIA.
The TL series is a better product.
I was working in a Square D Homeline panel and the Neutral bus was hidden behind the extra long frame AFCI breakers...so you have to pull a breaker to land additional wires.
I would like for a manufacturer to redesign the residential loadcenters to be wider. Widen them to 20 inches to give us more room for wiring. I very rarely mount a panel in a 14 1/2 inch stud bay.
shortcircuit2 is offline   Reply With Quote
Old 02-18-2015, 07:53 PM   #31
Rewards Points: 218
I hate the new arrangement Siemens has done on the 30/40 &40/40 load centers.
The older style that had the neutral/ ground buss all the way down were much better.
Teaspoon is offline   Reply With Quote
Old 02-18-2015, 09:14 PM   #32
Very Long Vacation
Are all of them this way or just the ones at HD? I think I will stop using Siemens no matter the price if that is.
Old 02-18-2015, 09:24 PM   #33
corn-fused
papaotis's Avatar
Rewards Points: 620
are seimens that chaep out east? around here theyve almost doubled in the last few years.
Old 02-18-2015, 09:30 PM   #34
Rewards Points: 3,078
Siemens P4040B1200CU -- ES panel, 200 amp with main breaker, 40 circuit, copper bus = $112
Greg
Old 02-18-2015, 09:51 PM   #35
butcher733's Avatar
Rewards Points: 798
are pl and es panels the same?
I'll take therapists for $400.
butcher733 is offline   Reply With Quote
Old 02-18-2015, 11:04 PM   #36
Rewards Points: 1,991
Insist on PL. ES panels have short and sometimes only 1 neutral bar, no ground bars and aluminum buss bars
The Following 4 Users Say Thank You to JoeSparky For This Useful Post:
chicken steve (02-19-2015), flyboy (02-20-2015), meadow (02-19-2015), papaotis (02-18-2015)
Old 02-18-2015, 11:24 PM   #37
MTW
Or you can just stop buying that garbage and use Square D instead.
The Following User Says Thank You to MTW For This Useful Post:
meadow (02-19-2015)
Old 02-18-2015, 11:29 PM   #38
Rewards Points: 804
Square D is the best panel money can buy.
Old 02-18-2015, 11:31 PM   #39
MTW
Do they sell them at Menards?
Old 02-18-2015, 11:37 PM   #40
corn-fused
papaotis's Avatar
Rewards Points: 620
yep!
The Following User Says Thank You to papaotis For This Useful Post:
Chris1971 (02-19-2015)
siemens breaker in a sq d QO panel ampman General Electrical Discussion 12 05-05-2011 10:58 AM
need an interior for an older Siemens panel ChristopherL General Electrical Discussion 3 12-01-2010 09:06 AM
what else fits in a siemens panel jjdrees General Electrical Discussion 26 06-03-2009 01:06 PM
Can I use a Murray in this Siemens panel? Solar Z General Electrical Discussion 28 05-29-2009 12:01 AM
Siemens panel problem jack davis General Electrical Discussion 2 02-24-2009 09:21 PM
