Silver Migration - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 2 Post By LARMGUY
  • 3 Post By macmikeman
  • 3 Post By MDShunk
Old 08-05-2018, 03:38 PM   #1
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 58
Default Silver Migration
I learn something new every day.
Watching a car repair video in which the electronic dash cluster was causing a parasitic amp draw killing the battery overnight.
Easy diagnosis through Amperage Clamp but cause was not determined until he received the cluster back from reman.
https://www.kurtzersa.com/electronic...migration.html
Silver has strong tendencies to migrate, since silver oxide is water soluble. The migration of silver on electronic assemblies expresses itself in the formation of conductive paths by wandering metal ions and under the influence of humidity between traces of different potentials. Preferred direction is towards the electric field. This effect is of eminent practical importance in the case of small structures. This migration can lead to malfunction, in the worst case to the total failure of the electronics through shorts. Alloying palladium to the silver can effectively reduce if not inhibit the silver migration. Other metals like copper and tin also tend to migrate, albeit at a slower rate.
Just for your information about circuit boards and possible non visually obvious causations of failure.
B-Nabs and splatz like this.
Cowboy words of wisdom.
The Following User Says Thank You to LARMGUY For This Useful Post:
splatz (08-05-2018)
Old 08-05-2018, 03:51 PM   #2
Rewards Points: 17,615
The other keen thing to look for closely is where it say Made in China...........
MechanicalDVR, tjb and telsa like this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 08-05-2018, 03:53 PM   #3
Rewards Points: 6,421
Reminds me of "tin whiskers" that have been blamed for failures in electronic components.
Southeast Power (08-05-2018)
Old 08-05-2018, 06:22 PM   #4
Rewards Points: 1,552
Its a large bleed that can drain a battery overnight. Somewhere around 1.5 - 2 amps tracking across a board.
Old 08-06-2018, 03:30 AM   #5
Rewards Points: 1,486
Silver migration is a known problem to the old time electronics repairers,
Especially those who fix electronic equipment containing electron tubes.
due to the high voltages involved silver would migrate across the glass base between the pins. doesn't take much voltage in the wrong place to stop a valve based circuit from working.
Silver plated conductors? Nutmegger777 General Electrical Discussion 16 04-20-2018 09:39 PM
Manufactured home Silver Label electricguy Canadian Electrical Forum 4 06-18-2016 05:43 PM
