single ended vs. double ended led tubes - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
Old 02-06-2019, 05:34 PM   #21
Rewards Points: 524
Originally Posted by Wiredindallas View Post
One advise i have in regards to converting to direct wire LED is to label the fixture as to having converted. Some lamps come with such labels.
I second that. Label your fixtures!!!! Anyone could pop a fluorescent lamp in them and....
John Valdes likes this.
John M. is online now   Reply With Quote
Old 02-06-2019, 05:50 PM   #22
Rewards Points: 750
Satco lamps come with a big bunch of labels in the box. I think it is a code requirement to label rewired fixtures also. Maybe in the UL listing?
Old 02-06-2019, 06:15 PM   #23
Rewards Points: 46
And then what? I'd like to know what would actually happen. I suspect it wouldn't be very dramatic.
Sent from my Moto Z (2) using Tapatalk
Old 02-06-2019, 06:20 PM   #24
Russian Bot
Helmut's Avatar
Rewards Points: 3,695
I would imagine the installer would then look at the bulb he took out, and read the label on the bulb that says LED, if he didn't when he took it out.
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
Old 02-06-2019, 06:22 PM   #25
Rewards Points: 1,529
What if the owner took them out when they stopped working and didn't know?
In most situations LED bulbs are interchangeable with standard bulbs.
Old 02-06-2019, 06:28 PM   #26
Rewards Points: 7,520
I mistakenly wired 347 volts directly to a fluorescent bulb once. It exploded.
Original installation had a remote slab mounted ballast for 4 bulbs that ran 4 separate single bulb lay in fixtures. PIA to make any changes so they wanted to install ballasts in every fixture and loose the remote ballast. I forgot to install one ballast and energized the bulb full voltage!
Old 02-06-2019, 07:25 PM   #27
daveEM's Avatar
Rewards Points: 2,382
Someone can change the bulbs without opening the wiring compartment.
Having a sticker would tell them not to install normal fluorescent tubes.
I read a sticker once when I was changing bulbs. Haven't bothered since and I'd sure be pissed if something blew up.
We keep the T8 ballasts in my neighbourhood. I get to change the ballasts down the road too. Money.
Anyway the cleaning lady changes the tubes. Calls me when they don't work.
I like perfect.
Old 02-11-2019, 07:22 PM   #28
Rewards Points: 112
I retrofitted a shop full of 8 foot fluorescents with 4 foot LED kits that included new tomb stones, brackets, and jumper wires. The lamps were single ended with no wires needed on the end tombstones. Only the center tombstones were connected to the 120 line that previously fed the ballast. I left the old ballasts in after cutting all the wires. Easy job, good profit. I can't remember the brand name of the kits but my supply house had them. So does Home Depot. They came with stickers to warn they were LED lamps.
armsjac is offline   Reply With Quote
Old 02-13-2019, 09:24 PM   #29
worksmartnothard's Avatar
Rewards Points: 12
Pretty sure it’d be dramatic to install a flo bulb into straight 120v. Hence the stickers. Code around here
worksmartnothard is offline   Reply With Quote
Differential encoder to single ended input MDShunk PLCs, VFDs, Motors and Controls 2 05-06-2018 07:19 PM
changing flourescent to LED tubes fearless510 Lighting Design 9 07-21-2017 06:46 AM
Creating a "service call kit" for your second truck HackWork Business, Marketing, and Sales 41 04-07-2017 12:12 PM
Difference between Single and Double Ended Lamps swimmer NEC Code Forum 9 05-08-2016 09:46 AM
