Single pole to switch a 3 way - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
Old 10-15-2017, 11:24 PM   #21
Rewards Points: 8
Originally Posted by B-Nabs View Post
The relay solution is the only one that truly fulfils the OP's desires. What is the ceiling type? Switch box type? Type of building construction? Type of occupancy? The answers to some of these questions would help figure out where you can hide things like relays.
Residential master closet. Single gang switch box.
Light box not an ideal option but it's a 3-0 nail on.
Splatz supplied a great solution.
I plan on dropping a box, blanked off, below the switch in which to house the realy
Sent from my HTC6545LVW using Tapatalk
Shaneyj is offline   Reply With Quote
Old 10-16-2017, 06:21 AM   #22
Rewards Points: 1,292
Originally Posted by Shaneyj View Post
I filled in the truth table... But depending on the definition of a "true", I ended up with an OR and an XOR.
A 3 way switch configuration cannot be powered from both "inputs" at the same time... I think.
But if power applied both switches are in a 1/high/true, then it's an OR.
But if the true is defined as switch being up (initial condition both switches down with zero output), then my truth table came out as an XOR.
So, is it an XOR because mechanically both switches can not be applying power to load simultaneously?
I think you have it -
If you wired the switches in parallel it's an OR - power's on if either one is on, or both. Power's on when both are on means it's not an XOR.
If you wired the switches in series it's an AND - power's on only if both are on.
If you wired the switches in the three way configuration, power's on if one's on and one's off, but not if both are on - that's XOR.
Old 10-16-2017, 07:35 AM   #23
Barjack's Avatar
Rewards Points: 280
I take it the client wants to be able to leave the closet doors open AND be able to turn the light off right?
Well why not just disable the door switch and install a new single pole switch on the wall.
You would be running a new wire in any case. I just think the 3 way solution will give the unintended effect of turning the closet light back on if the doors are shut.
Barjack is offline   Reply With Quote
Old 10-16-2017, 07:49 AM   #24
Rewards Points: 8
You make a good point... I think their intention is to be inside the closet with door shut and light on. But you bring up a very plausible scenario where if door is open and light is off and someone exits and shuts door without thinking about it light will go on.
I've pitched the idea of motion sensor but they like the idea of the closet switch.
Maybe bringing this potential scenario to light -pun intended- will change their minds.
Old 10-16-2017, 08:00 AM   #25
I figured this was so one person could go in the closet with the door shut and the light on to pick out their clothes for the day while the other's asleep in bed.
Old 10-18-2017, 08:27 PM   #26
Dpm1132's Avatar
Rewards Points: 52
why don't you use an occupancy sensor and have a switch to override it
Dpm1132 is offline   Reply With Quote
Old 10-18-2017, 08:43 PM   #27
Rewards Points: 1,360
Just put the junction/relay box on the inside of the closet.
Old 10-18-2017, 08:47 PM   #28
Barjack's Avatar
Rewards Points: 280
The point Iím trying to make is that automation can be an annoyance. Too much automation is definitely so.
The simple automation of the door switch controlling the closet light has caused the client to contact the OP about a solution. Giving the client even more automation by turning it into a 3 way switch may look good and even work, it could cause even more annoyance due to its unintended effects.
The real problem is that the door switch controls the light. Change it to a wall switch and be done with it.
Old 10-18-2017, 09:08 PM   #29
Going_Commando's Avatar
Rewards Points: 1,542
I am completely at a loss as to why someone would want to over-ride a jamb switch. If the closet door is open, the light is on. If it is closed (i.e. not getting anything out of the closet), the light is off. Who wouldn't want that be the case, and then if someone does, how much of your time is it worth to figure out how to make that happen? Who just wants to randomly leave the closet door open, but have the light off? By the same token, who the hell hides in the closet and needs to be able to turn a light on without opening the door?
Old 10-18-2017, 09:30 PM   #30
Barjack's Avatar
Rewards Points: 280
I dunno. Iíve done some renovations with some rather large master closets. All with custom cabinetry and decorative lighting including pendants and chandeliers.
Not really though because that would be illegal in a clothes closet.
Old 10-18-2017, 10:34 PM   #31
Rewards Points: 8
I pitched that as an option... They like the door switch
Old 10-18-2017, 10:35 PM   #32
Rewards Points: 8
Plan A
QO Single Pole GFCI Issue Takideezy Residential Electrical Forum 2 08-29-2017 09:28 PM
Single Pole Thermostat 240V Azachi Canadian Electrical Forum 29 06-18-2017 12:53 PM
2 Pole or 2 Single Pole Breakers Azachi Canadian Electrical Forum 13 12-19-2016 08:20 AM
To get feedback on my prices? Angel Advanced Tech Business, Marketing, and Sales 50 09-02-2016 10:38 PM
