Smoke damage to a panel and breakers - Electrician Talk - Professional Electrical Contractors Forum
Old 08-06-2014, 09:08 PM   #1
Default Smoke damage to a panel and breakers
Does anyone know where to find the requirements for the replacement of panel and breakers that have gone through a fire and have fire/smoke damage? Insurance company is requiring it on a job we're doing before they'll authorize the work. Looking for info under the BC Safety Authority code, haven't found it yet.
albernielectric is offline   Reply With Quote
Old 08-06-2014, 09:11 PM   #2
backstay's Avatar
Rewards Points: 296
The cost to test the panel and breakers would be more than the replacement of them.
meadow (08-06-2014)
Old 08-06-2014, 09:24 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
Just change everything out and sleep well.
guest (08-06-2014), The_Modifier (08-08-2014)
Old 08-06-2014, 09:52 PM   #4
Bad Electrician's Avatar
Rewards Points: 4,969
Was there thermal damage to the equipment?
Water damage?
If the answer is no
Remove CB's Clean with an approved cleaner
Clean all insulating surfaces.
Megger panel
Install and megger, if reading deteriorates after installing CB's remove one at a time until you isolate the defective CB.
We regularly do restoration of services after water intrusion, blow up and fires.
Google NETA and NEMA for further information.
Err on the side of safety, use your eyes. verify all test and document.
Old 08-06-2014, 09:55 PM   #5
Not quite what I was looking for but thanks for the input.
Old 08-06-2014, 09:56 PM   #6
What more do you want, you could hire my firm and we would do the work.
Explain what additional information you would like.
Old 08-06-2014, 10:00 PM   #7
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
If they are requiring it and they are paying for it what is the problem? Take the money and run.
Old 08-06-2014, 10:07 PM   #8
Or if in doubt hire a firm that specializes in this type of work
Old 08-06-2014, 10:07 PM   #9
Rewards Points: 14,223
It sounds like the insurance company wants to cheap out and replace nothing unless there is an "official" document saying it has to be replaced.
Ba$tards.
Old 08-06-2014, 10:21 PM   #10
Ba$tards.
Not really, they are being prudent; would you expect them to give you a new car if you had a fender bender?
Not trying to be a PIA but I make a fair portion of my income from work such as this.
Old 08-06-2014, 11:26 PM   #11
wcord's Avatar
Rewards Points: 1,658
Can't tell you about BC Safety, but here is the ruling from MB Hydro.
They refer to 2-024 as the basis of their ruling.
Maybe it will aim you in the right direction for searching.
Good luck
ITEM NO.3 SMOKE AND WATER DAMAGE TO CIRCUIT BREAKERS
Rule 2-024 Use of Approved Equipment
CSA Audits and Investigations Department has
advised inspection authorities that circuit
breakers exposed to water or smoke damage, such as may be experienced in a flood or fire, may
not operate under overload or fault conditions.
Where circuit breakers have been so exposed
they shall be replaced or undergo factory re-certi
fication to ensure safe operation. Equipment
taken out of service and deemed unsuitable for use should be destroyed in the presence of the
electrical inspector or by the factory.
The Following 2 Users Say Thank You to wcord For This Useful Post:
Old 08-06-2014, 11:33 PM   #12
Very Long Vacation
Rewards Points: 5,262
Chances are if you have to debate this its a replacer. Panels are cheap over liability.
guest (08-06-2014)
Old 08-07-2014, 12:17 AM   #13
Rewards Points: 5,198
It seems as though you may be wanting to salvage the components. if possible. The insurance company will not assume the risk if you say they are good enough to re use. The fact that you say that they have incurred fire damage speaks loudly. If that is the case you want to look at replacing the feed wires to the panel as well. Don't take the risk trying to save a customer ...or yourself money.
Old 08-07-2014, 01:20 AM   #14
Well, you're a smart guy amongst smart a$$es so I'm going to say "thank you" for teaching me something today .
Old 08-07-2014, 06:42 AM   #15
And then nothing form the OP.
I love post like this.
Old 08-07-2014, 06:43 AM   #16
Ba$tards.
A know a little about a lot, many here know a lot about a lot more.
Old 08-08-2014, 01:54 PM   #17
Zog
Zog's Avatar
Rewards Points: 1,096
http://www.necanet.org/docs/default-...t.pdf?sfvrsn=0
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
The Following 5 Users Say Thank You to Zog For This Useful Post:
Big John (08-08-2014), guest (08-10-2014), Pete m. (08-08-2014), pete87 (08-09-2014), theJcK (08-08-2014)
Old 08-08-2014, 03:17 PM   #18
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 370
Check your PM's
The_Modifier is online now   Reply With Quote
Old 08-09-2014, 12:23 PM   #19
Rewards Points: 864
I have very slowly started to do work for Belfor in my area and their stance is either replace or the liability is yours if there is a question about damage. I do have to say I have to side with them as they pay me, but also because society is so lawyer friendly.
I mean as far as testing maybe on larger stuff but not on resi stuff.
Pride is doing what you know is right especially when no one else is looking.
Sparky J is offline   Reply With Quote
Tags
breakers, fire, replace electric panel, smoke
Sub-panel max breakers alselec53 General Electrical Discussion 3 06-25-2014 04:18 PM
Are smoke alarms connected to fire alarm panel? katwalatapan Canadian Electrical Forum 5 02-25-2014 10:18 PM
Smoke detectors for old Edwards panel farlsincharge Commercial Electrical Forum 6 07-09-2012 01:59 AM
277/480 breakers in a 120/208 panel? 220/221 General Electrical Discussion 11 01-07-2011 11:26 PM
Smoke detectors and afci breakers Power21 Residential Electrical Forum 28 02-04-2010 07:03 PM
