SO Close - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 2 Post By HackWork
  • 3 Post By drewsserviceco
  • 1 Post By MikeFL
  • 1 Post By Cow
  • 1 Post By sparkiez
  • 1 Post By Jlarson
  • 2 Post By macmikeman
  • 2 Post By MikeFL
Old 09-06-2017, 07:25 PM   #1
Rewards Points: 1,314
Default SO Close
Here's one for you. See the attached sketch. I have a control panel that's just ten feet away from a manhole at the end of a loooooong run. I have to figure out the best way to get from the vault to the panel.
I can't imagine why nobody ran another 10 of pipe to those panels when they poured the slab...
I am not nuts about cutting a slit trench in the concrete to get to the panel, I am not sure what might be in the slab.
The vault is about 4' deep, I thought about drilling through the retaining wall into the vault down deep, deep enough to be out of the way of the existing system in the slab. I am not sure what the way to go about that, maybe a small core drill on a long piece of 5/8" threaded rod...
Old 09-06-2017, 07:34 PM   #2
Rewards Points: 1,639
Wiremold.
splatz and sparkiez like this.
splatz (09-07-2017)
Old 09-06-2017, 09:22 PM   #3
drewsserviceco's Avatar
Bluetooth
HackWork, splatz and MikeFL like this.
The Following User Says Thank You to drewsserviceco For This Useful Post:
splatz (09-07-2017)
Old 09-06-2017, 10:10 PM   #4
MikeFL's Avatar
Rewards Points: 624
Is there any pipe at all coming down from the panels? Maybe the box was not there when they set the panels and some goofball set (or poured) the vault without connecting the last inch of pipe?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
splatz (09-07-2017)
Old 09-06-2017, 10:38 PM   #5
Cow
Rewards Points: 4,914
Solar.
In all seriousness I'd cut the concrete.
splatz (09-07-2017)
Old 09-06-2017, 10:43 PM   #6
Rewards Points: 938
Cable tray and UV rated cable
The Following User Says Thank You to sparkiez For This Useful Post:
splatz (09-07-2017)
Old 09-07-2017, 12:05 AM   #7
Jlarson's Avatar
Rewards Points: 4,074
What's the surroundings like, is it really elevated like your sketch shows? Just run RMC on the top then LB down, core and linkseal it?
glen1971 likes this.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
macmikeman (09-07-2017), splatz (09-07-2017)
Old 09-07-2017, 03:58 AM   #8
Rewards Points: 18,271
Bingo. I have done this before. Just make sure to make the conduit a 2'' because the customer will want more wiring run thu it once you are done......
Cow and splatz like this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
splatz (09-07-2017)
Old 09-07-2017, 05:26 AM   #9
I wonder if they could have done something like that... The control panels have conduits coming in from the slab, but they don't go through the vault. The vault has next to nothing coming into it. I'll double check there are no empty pipes unaccounted for going out of the vault.
Old 09-07-2017, 05:29 AM   #10
It's elevated but the elevated concrete surface is a busy walkway, so surface mounted wouldn't fly. I didn't draw in the handrails, there's a rail around the perimeter of the concrete. The grass comes right up to the bottom of the retaining wall.
Old 09-07-2017, 06:11 AM   #11
MikeFL's Avatar
Rewards Points: 624
Worst case cut a nice square around the vault, take out the vault, run your pipe and put in a new vault.
chicken steve and splatz like this.
GPS Timers
(833) GPS-TIME
splatz (09-07-2017)
Close and Latch Rating Lone Crapshooter Industrial Electrical Forum 6 04-27-2017 02:30 AM
6-3 Non-Metallic Wire; close to gas pipe and HAVC ductwork...SAFE? orange315 NEC Code Forum 12 03-25-2017 06:55 PM
Meter close to window WronGun Residential Electrical Forum 58 01-23-2017 12:39 PM
How close Is to close ? numbers General Electrical Discussion 13 09-10-2016 12:52 PM
We had a close one! Cow Workplace Safety 44 08-28-2016 02:33 PM
