SO CORD can it be used on structure? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-07-2007, 06:30 PM   #1
Question SO CORD can it be used on structure?
Can a SO cord be used on the structure of a building as a branch circuit?
glenn easterly is offline   Reply With Quote
Old 04-07-2007, 06:31 PM   #2
Rewards Points: 150
what do you mean by on the structure? SO cord can be permanently installed.
Old 04-07-2007, 06:41 PM   #3
Rewards Points: 6,421
As a buss drop, probably so. Anything other than that, nope. Well, there are some exceptions for article 645 locations that might let you use SO as a branch circuit.
Care to offer some more specifics that cause you to ask?
Old 04-07-2007, 06:42 PM   #4
For my understanding rubber cords article 400.8 nec 2005 indicates that it shall not be used as fixed wire on a structure. Is there somewhere else in the code that said something different.
Old 04-07-2007, 07:05 PM   #5
Default Contractors violation
Working for the state as an inspector this contractor said it is legal to install a SO cord on the block wall and have it run between two twist lock receptacles. I said Article 400.8 was the violation.
Old 04-07-2007, 07:13 PM   #6
Rewards Points: 3,240
If I understand your post he wants to run this between two mounted boxes?
Sure he can till you stop him from violating the NEC.
Old 04-07-2007, 07:21 PM   #7
Default Brian your the man
Well thank you for the advise you just answered my question. Talk to you soon,
Old 04-07-2007, 07:49 PM   #8
Glenn hang around we could use a few inspectors, seriously!
Old 04-07-2007, 08:15 PM   #9
Rewards Points: 150
I come across the use of cords many times during the month... I do not understand the need for the usage of cord in the permanent wiring of premises. And then we wonder why the pay scale of this industry is headed towards the toilet.
Pierre Belarge is offline   Reply With Quote
Old 04-07-2007, 08:23 PM   #10
Rewards Points: 150
the only permanent use i can think of is for receptical cord drops. but no other permanent installations.
Old 04-07-2007, 08:25 PM   #11
Default I Will
Thanks Brian, I am goingto, and thanks again for the help earlier.
Old 04-07-2007, 08:39 PM   #12
Default I thought so
HCECalaska I think I have checked almost all the resources out on this subject, OSHA Reg. CFR-1910-29 General Industry,NEC and this Web site.
I think this contractor just does not care.
Old 04-07-2007, 09:49 PM   #13
I once (and only once thank goodness) saw a 100' extension cord male adaptor cut off terminated in a panel, no connector at the box, 90' across a drop ceiling, ceiling tile lifted and cord hanging to a piece of equipment. I was told this "installation" had been there for years.
Old 04-07-2007, 10:07 PM   #14
JohnJ0906's Avatar
I believe the technical term for this is "Handyman special".
John from Baltimore
"One day at a Time"
Old 04-07-2007, 10:17 PM   #15
Oh, boy... that reminds me of a picture I've been meaning to take. Sorry for the teaser, but I think I'll take it tomorrow if I can figure out some sap story to get me into the place with a camera.
Old 04-07-2007, 10:20 PM   #16
JohnJ0906's Avatar
http://www.electriciantalk.com/showthread.php?t=149
Reminds me of this one!
John from Baltimore
"One day at a Time"
can i run an 1800 watt a/c unit on an extension cord? jmatthews General Electrical Discussion 1 07-14-2008 05:41 AM
flex cord works for everything, right??? BP_redbear Code Violation Discussion 2 07-11-2008 10:08 PM
Got an extra cord? MF Dagger General Electrical Discussion 6 06-07-2008 12:19 AM
Wireless Extension Cord kkelter Tools, Equipment and New Products 13 01-20-2008 02:29 AM
AFCI/LDCI A.C. cord problem Greg Sparkovich General Electrical Discussion 7 09-19-2007 12:02 PM
