So THAT's how you install an outdoor outlet... - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree59Likes
Old 12-25-2018, 11:13 AM   #21
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,046
Originally Posted by ppsh View Post
That cut in box has quite the wiggle to it when they go to put in the GFCI. The snap in romex connector on the inside is a nice touch too.
If this guy and Corey from Lowes got together it would be the dream team. Commercial and resi they can do it all.
Old 12-25-2018, 11:41 AM   #22
Rewards Points: 698
They forgot the last step: Take it back apart and fix the splices that they did not twist together.
Old 12-28-2018, 09:26 PM   #23
Rewards Points: 2,969
Originally Posted by SummitElectric1 View Post
...the outrageous electrical advice Iíve overheard customers receive from the orange-vested guruís...
A few years ago at the big orange store:
Customer: I need to replace these two 15A breakers. Can I just use one 30A, because it's cheaper?
Orange Guru: Ya, I can't see why not.
I usually keep my mouth shut and continue my shopping, but I had to say something there.
AK_sparky is offline   Reply With Quote
Old 12-29-2018, 12:27 AM   #24
Jlarson's Avatar
Rewards Points: 3,814
From now on I'm gonna use the SDS and the longest bit I can find for it for everything, **** it just send it on through!
macmikeman likes this.
Jlarson is online now   Reply With Quote
Old 12-29-2018, 12:46 AM   #25
Rewards Points: 14,819
I put the long one in the drill once because of all the mechanical duct in the way to get me a drop in anchor for a hanger up on the ceiling once. I ended up drilling out a conduit concealed in the ceiling pour. That was a Friday afternoon. On Monday morning the building management asked me if they could hire me to figure out why the parking lights on the 6th floor aren't working and to fix the issue. I kinda knew what was the problem, but I kept my mouth shut about it while I tried to find the spot between lights that was shorted. Couldn't . So , checked the start of the circuit in the basement. Found double pole contactors running the lights, one per floor. I swung the offending bad circuit up at the lights onto the other side of the circuit, which shared a neutral, and disconnected both ends of the bad circuit . The amps were less than ten on a twenty amp breaker with #12 anyway once it was all fixed. $$$ . I'm a bad bad boy.
Kevin_Essiambre likes this.
Old 03-01-2019, 11:43 AM   #26
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 126
Originally Posted by armsjac View Post
I like finding tape on the wire nuts, then I know it's a handyman or homeowner job and I can act accordingly. Especially if it's a troubleshoot job.
I installed a $10 000 fixture at a house the other day... The instructions said to tape the wire nuts on so they do not fall off... Best part is... This fixture had wago lever nuts for me, but the factory did not tape their wire nuts! (for the record, I do not ever tape wire nuts weather the instructions say to or not).
HackWork and tmessner like this.
Old 03-01-2019, 11:46 AM   #27
Rewards Points: 1,749
I tried to explain to my father, who I always made fun of for all the taped wirenuts in our house, how if you have to tape on the wirenut then you failed to install it properly.
It's like taping a nut onto a bolt.
Old 03-01-2019, 01:03 PM   #28
five.five-six's Avatar
Rewards Points: 8,370
I like how the inside recep was held in place with drywall screws. And at 0:12 the light pole blocking the existing GFCI cover opening from the last HDDIY video LOL
Max C. likes this.
Old 03-01-2019, 07:46 PM   #29
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 288
I love the 5/8" sds they just plow right thru the existing box. Who cares if the hole pops right thru the siding overlap.
That's all taken care of in the "How to reside your house after you watched our other how to videos"
Old 03-01-2019, 09:32 PM   #30
CoolWill's Avatar
Rewards Points: 642
He wrapped his pigtail on the hot screw in the wrong direction.
I'm With Her! Hillary 2016
Old 03-01-2019, 10:10 PM   #31
Wish Iíd known that, I guess Iíve been doing it wrong all along.
TheBigAndy is offline   Reply With Quote
Old 03-01-2019, 11:40 PM   #32
zac
Rewards Points: 812
It's what I think of you twist the wires with your linesman's guy! It's a redundant step if your using the right wire nut. Now I'm not putting you on the level of a wire nut taper. I think it's more of a conscience thing.
Old 03-02-2019, 03:42 AM   #33
Pre-twisting wires with pliers is more for easiness than anything else. Itís easier to twist the wires with a tool made for that purpose than to twist them with the wire nut using my fingertips.
As I mentioned the last time you tried to hurt my feelings like this, I did it more when using three or four number 12 conductors in the past. Or when dealing with existing short wires that are hard to hold together. Nowadays, with 2-3 new number 14, I will just throw the wire nut on. Or lever nut.
Old 03-02-2019, 07:25 AM   #34
Rewards Points: 2,798
True but I'd say holding the wire nut in a dottie brand socket like @zac uses, or a 5/16" wrench like I use, or the Ideal screwdriver with the wire nut socket in the butt, are even quicker easier ways to twist.
Old 03-02-2019, 07:32 AM   #35
I don't see it being any quicker. Even if it was, I am not counting split seconds. And you are still using a tool, so what's the difference...
CoolWill likes this.
Old 03-02-2019, 10:51 AM   #36
zac
Rewards Points: 812
It is quicker. And if we're doing it all day the difference in time would be quite noticeable. The only advantage twisting wires with linesman pliers gives you is Popeye forearms.
Old 03-02-2019, 10:58 AM   #37
MTW
MTW's Avatar
Rewards Points: 6,908
I'll agree with you if you're talking about 2 or 3 conductors. Otherwise, it's much easier to pretwist them.
Now, if you simply use red wing nuts all the time on #14 without pretwisting, I can see a case being made for that. I remember seeing a lot of work in California done that way in new houses. It was all red wing nuts everywhere, they didn't use any other kind of connector.
Bird dog likes this.
Old 03-02-2019, 11:04 AM   #38
zac
Rewards Points: 812
I will line up to 4 wires and twist a red or tan wire on with no problem. I pull the wires to make sure their in secure because I'm not!
Half the time I'm using wago's anyway
Old 03-02-2019, 11:11 AM   #39
3M red/yellows and blue/oranges are the best wirenuts known to man.
ppsh likes this.
Old 03-02-2019, 11:20 AM   #40
MTW
MTW's Avatar
Ceiling Fan Install - Antenna Issues dsaville Lighting Design 3 05-10-2018 11:48 AM
Atlanta - Looking for bids for commerical 3P panel install in A mlamias Looking To Hire 1 05-01-2018 08:28 PM
if we want to install two 20A receptacles in the kitchen, how many circuits I need? mike883 Canadian Electrical Forum 39 09-06-2017 07:39 AM
Who should install ceiling medallions? Canaduh Residential Electrical Forum 37 03-29-2017 05:04 AM
