Soldering pencil on a triac - Electrician Talk - Professional Electrical Contractors Forum
Old 04-15-2012, 11:30 AM   #1
Chris Kennedy's Avatar
Rewards Points: 2,000
Default Soldering pencil on a triac
I'm doing a test that requires a 30W soldering pencil on a rheostat. I got a bunch of triac dimmers around here and my pea brain tells me a resistive load is a resistive load and I should be fine. Correct?
Thanks
Old 04-15-2012, 12:08 PM   #2
Rewards Points: 6,421
It will work fine for a 30W load. For heavier loads, you'd probably want to look into a variac.
Teach a man to fish and youve ruined a good business opportunity.
Old 04-15-2012, 12:21 PM   #3
Rewards Points: 3,352
A pencil type soldering iron is a resistive load, so just about any type of voltage reducing device will work.
A gun type is inductive. That's a different story.
Old 04-15-2012, 12:38 PM   #4
Did not know that.
Old 04-15-2012, 02:14 PM   #5
Semi-Ret Electrician's Avatar
Rewards Points: 486
Thanks
Perfect application
Old 04-15-2012, 03:46 PM   #6
Originally Posted by Semi-Ret Electrician View Post
Perfect application
Yup, just completed the test. I was able to slowly take the pencil from 26C to 180C in 1hr.
Thanks all.
Old 04-15-2012, 03:56 PM   #7
Tabihu Juhar
76nemo's Avatar
Question
For what little they cost, why in the world would anyone put a soldering unit on a dimmer for a permanent application??????????????
Old 04-15-2012, 03:58 PM   #8
Just a test Brad, I labeled the box do not use, test only.
Old 04-15-2012, 04:04 PM   #9
Tabihu Juhar
76nemo's Avatar
Arrow
WHOOPS!!!! Gotcha Chris! Sorry man......
Old 04-15-2012, 05:36 PM   #10
Rewards Points: 486
Thanks all.
Now you can use a 300W iron and solder everything from transistors to Knob & Tube taps
Old 04-15-2012, 07:42 PM   #11
I have a 30 watt 12 volt pencil type soldering iron that's connected to a 12 volt DC power supply, a 3055 transistor and a potentiometer to control the wattage.
For very small connections, the full 30 watts is too hot.
Old 04-15-2012, 07:51 PM   #12
Rewards Points: 486
Is it something you designed or store bought?
Old 04-15-2012, 07:54 PM   #13
Home built, including the power supply.
Really simple though.
Poll- Conduit Bending (pencil or sharpie) 360max General Electrical Discussion 153 09-07-2012 08:45 AM
Anyone use the Striker Pencil? Ocularpatdown General Electrical Discussion 17 04-30-2010 01:44 PM
