Solve this - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree31Likes
Old 11-29-2017, 09:16 AM   #61
Rewards Points: 1,360
Originally Posted by eddy current View Post
That type of question is common on license tests.
The question we get like that is a 240 volt, 3000w hot water tank.
What would the current draw be if you fed it with only 120 volts?
A more interesting question is how many watts would it produce at 120 V. Most people would assume it would be 1500 watts at 120 V.... but nooooo.
hardworkingstiff and B-Nabs like this.
Old 11-29-2017, 09:26 PM   #62
Rewards Points: 1,498
These types of questions are used to sort the men from the boys,
Or those whom truly understand electricity
as opposed to those whom have just learn't it !
And there's a world of difference.
Old 11-29-2017, 09:31 PM   #63
Rewards Points: 2,079
You're the man now dog.
Peter Goldwing likes this.
Old 11-30-2017, 07:28 AM   #64
Rewards Points: 892
IMO this one is very little electrical theory and more algebra.
Before the math, a very little electrical theory, you need to understand the rating of the bulb, and figure a bulb is a purely resistive load, and the resistance is the same at 120V and 130V.
With that understanding of the bulbs, you're given power and voltage and you can solve for resistance. (The circuit doesn't matter yet.)
R=E*E/P
R1=130*130/75=225.33
R2=120*120/75=192
Now a very little more electrical theory, with resistance and voltage, with the switch open, it's a simple series circuit. A 240V circuit with two resistors in series. You have voltage and two resistance values, you can solve for current.
I = E/R = E/(R1+R2) = 240/(225.33+192) = .575
RePhase277 likes this.
Old 11-30-2017, 08:31 AM   #65
Rewards Points: 14,714
R=E*E/P
R2=120*120/75=192
How would you calculate the voltage dropped across each resistor?
Edit: I would just multiply the R value by the circuit current to come up with the voltage across the resistor.
Old 11-30-2017, 09:04 AM   #66
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
Yep, that's how.
Old 05-03-2018, 03:44 AM   #67
Rewards Points: 8
Originally Posted by Peter Goldwing View Post
I just did it R=V square/power. therefore first bulb is 225ohm, second 192 ohms
combined 417 ohm. 240/417= 0.575A. too bad i didnt have this amount of time to come up with it
You are right, the 130 volts on the other lamps make the confusion, but its not really a factor, the missing data is the resistance of that rated 130 volts lamp. And as you nail the resistance, its just an ordinary series circuit.
rene6985 is offline   Reply With Quote
Old 05-05-2018, 04:13 PM   #68
Rewards Points: 1,112
In my test I had this question
The bulbs are both 75W. One 130V one 120V. What is the current flowing thru the circuit when the switch is open?
The 120 volt bulb has a current of 75/120V=0.635A with the switch closed.
If the second bulb would also be 120v then if you open the switch the current would be the same 0.63A. But they are not the same. Anyone knows how to solve it?
Sorry for the miserable sketch.
When I look at the drawing, it looks like the neutral is on a switch that will create an open neutral if you turn off the switch. With the switch open, the current will be 0 because there will be no current flow, Unless I'm missing something? Maybe I should read the comments before I post lol, I'm leaving this here though. Lets see
Old 05-06-2018, 03:04 AM   #69
QMED's Avatar
Rewards Points: 290
QMED is offline   Reply With Quote
RS Logix 500 Question. Electrorecycler PLCs, VFDs, Motors and Controls 53 07-14-2019 07:40 AM
Lights flashing gil48311 General Electrical Discussion 14 10-30-2017 09:36 PM
Best online course for aptitude test 5park Union Topics 31 08-03-2017 03:25 PM
Looking to solve other peoples problems DavidMoss New Member Introductions 14 01-13-2017 10:36 PM
Solve this AFCI Mystery 480sparky Residential Electrical Forum 106 07-04-2016 12:32 PM
