Spacers for RMC One-hole Straps - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By glen1971
  • 3 Post By Cow
  • 4 Post By Wiresmith
  • 1 Post By Southeast Power
Old 04-19-2019, 10:01 PM   #1
Rewards Points: 3,726
Default Spacers for RMC One-hole Straps
Some places if I ask for RMC straps, I get regular looking straps that look just slightly heavier than EMT one hole straps. Other places, they give me the heavy malleable straps with the spacers.
The spacers give you some room around the coupling so it lays a bit straighter. Other than that, is there any major reason to use one or the other?
Old 04-19-2019, 10:40 PM   #2
Rewards Points: 3,698
For the spacers, there is no need to worry about a box offset if you are using an FS box or a Tee, or L fitting for surface runs.
I haven't had the spacers "thrown in" with one type of strap vs another. Most times I've just used the straps similar to a thicker one hole EMT strap.
splatz (04-20-2019)
Old 04-19-2019, 11:44 PM   #3
Cow
Rewards Points: 4,542
We call what you have pictured as "backs and straps". We use them with rigid all the time for the reasons glen mentioned.
We call the regular straps, 1 or 2 hole heavy wall straps, the type that look like regular emt straps.
glen1971, telsa and splatz like this.
splatz (04-20-2019)
Old 04-20-2019, 01:11 PM   #4
Vacated
Wiresmith's Avatar
Rewards Points: 2,844
Nec 2017 300.6
(d) indoor wet locations. In portions of dairy processing facilities, laundries, canneries, and other indoor wet locations, and in locations where walls are frequently washed or where there are surfaces of absorbent materials, such as damp paper or wood, the entire wiring system, where installed exposed, including all boxes, fittings, raceways, and cable used therewith, shall be mounted so that there is at least a 6-mm (1∕4-in.) airspace between it and the wall or supporting surface.
Think like a man of action, act like a man of thought. ~Henri Louis Bergson
The Following User Says Thank You to Wiresmith For This Useful Post:
splatz (04-20-2019)
Old 04-20-2019, 05:25 PM   #5
86 45 20
Southeast Power's Avatar
Rewards Points: 7,878
We call them two piece straps. You can't use one without the other.
splatz (04-20-2019)
One Hole Straps for RMC on pearlings outside silentbodhi General Electrical Discussion 2 04-02-2018 09:56 PM
Cruel Joke - 1-3/8" Hole Saw splatz Tools, Equipment and New Products 39 02-22-2018 09:32 PM
Hole saw wobble UncleMike Tools, Equipment and New Products 21 11-30-2016 04:59 PM
Hole saw for drilling wood HackWork Tools, Equipment and New Products 20 06-12-2016 07:22 PM
Best Tool for 4" Hole Saw quick_2 Tools, Equipment and New Products 39 02-05-2016 08:09 AM
