Special fittings for HCF MC Cable? - Electrician Talk - Professional Electrical Contractors Forum
Old 01-20-2015, 10:35 AM   #1
Swimmer
swimmer's Avatar
Rewards Points: 676
Default Special fittings for HCF MC Cable?
Do I need special fittings for Health Care Facility (HCF) MC Cable?
There are 2 ground wires in 12/2 HCF MC Cable: A 12AWG and a much thinner one. Do I connect the thin ground wire to the rest of the grounds in the outlet box?
Thanks
Elvis is in the building
Old 01-20-2015, 10:37 AM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
The manufacturer of the cable should list the approved connectors.
AFAIK, the bonding strip can just be cut off flush with the end of the cable.
Pete
Old 01-20-2015, 11:11 AM   #3
Lurker...
LJSMITH1's Avatar
Rewards Points: 322
1) If you have a "thin bond wire" within your armored cable, you are dealing with AC cable, not MC. The only MC with a LARGE, bare, aluminum conductor is MCI-A (aka - Southwire MCAP or AFC MC-STAT)
2) All HCF cable needs to be terminated with fittings specifically listed for use with said cable.
3) The thin bonding strip can either be wound around the outside of the armor and clamped in the fitting, OR it can be cut flush with the armor. It is not designed to be terminated under a separate bonding screw. If you have a push on fitting, the strip should be cut flush with the armor so that it doesn't interfere with the grip fingers of the fitting.
4) Don't forget to install the redhead insulators in the end of the armor before terminating the AC cable onto a fitting.
Larry
LJSMITH1 is offline   Reply With Quote
The Following User Says Thank You to LJSMITH1 For This Useful Post:
swimmer (01-21-2015)
Tags
hcf cable
HCF again.... 10492 NEC Code Forum 3 12-10-2013 07:14 PM
HCF cable ElectricZombie Commercial Electrical Forum 1 11-12-2013 08:00 PM
HCF medical grade cable DieselElectric General Electrical Discussion 15 10-30-2013 06:35 AM
HCF Mc cable connectors shanerIEC Other Codes and Standards 8 01-22-2013 07:14 PM
HCF cable.............. 220/221 General Electrical Discussion 23 12-04-2011 08:18 AM
