Splicing 500 MCM to #2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
Old 06-06-2019, 07:44 AM   #1
Rewards Points: 520
Default Splicing 500 MCM to #2
I have a job where I need to splicing some 2 AWG to 500MCM. I cant cut the 500 either. i have previously used piercing tap connectors for lack of something better. Are there other options out there?
John M. is offline   Reply With Quote
Old 06-06-2019, 08:14 AM   #2
Rewards Points: 10,725
Split bolt and duct tape*.
* Duct tape only approved in Canada.
Old 06-06-2019, 08:34 AM   #3
Rewards Points: 1,013
I’m not a fan of insulation piercing connectors. I think good old-fashioned split bolts work great. The problem is that I don’t think they make one that could go from 500 to number two.
You can splice in a larger conductor and then use a set screw reducer to go down from that larger conductor to number two.
I’m just curious why you can’t cut the 500 and use a Polaris style connector?
Bird dog and trentonmakes like this.
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 06-06-2019, 09:14 AM   #4
Cow
Rewards Points: 4,438
If insulated taps, dist. blocks, insulating piercing taps are all out.....then I'd probably be looking at these:
https://commerce.ilsco.com/e2wShoppi...237:3100012842
I haven't used them, I've just seen them in the catalog when I was looking for something else. They have one listed for a 500mcm main with a #2 tap.
Old 06-06-2019, 11:04 AM   #5
Rewards Points: 1,488
The giant red wire-nuts that look like a Solo cup?
Yeah, if somebody could just post a picture of a Solo cup, that'd be great.
ralpha494 is offline   Reply With Quote
Old 06-06-2019, 06:07 PM   #6
86 45 20
Southeast Power's Avatar
Rewards Points: 7,650
OK,
You are going to have to provide some context. What the H E double toothpicks are you up to??
Old 06-06-2019, 06:30 PM   #7
Modrateur
Rewards Points: 16,624
I have used that few time and they work pretty good but John ,.. are you plan to use the tap rules or not ?
Old 06-06-2019, 07:01 PM   #8
460 Delta's Avatar
Rewards Points: 520
Are you trying to build out an old school trough and board where you are nippleing down to combo starters and kearneying on to the 500 mcm?
Old 06-06-2019, 07:26 PM   #9
Rewards Points: 520
customer has a run a 500 to a larger sub panel. he has a j-box inline where he wants to split off for a 100 amp panel
Old 06-06-2019, 07:32 PM   #10
460 Delta's Avatar
Rewards Points: 520
I'm pretty sure you will run afoul of tap rules [or maybe not I don't have my book close] but you will need a large JB to get those kearneys tapped tightened and taped[ the 3 T's].If you do this, take your time and get those kearneys tight.
Old 06-06-2019, 07:40 PM   #11
Rewards Points: 44
Depends what he's doing. We did a job that had 500 AL run 1100' on a 100A circuit and tapped a panel off partway out.
Sent from my XT1650 using Tapatalk
Old 06-06-2019, 08:14 PM   #12
Jlarson's Avatar
Rewards Points: 3,882
There are ones out there that will do 500 run with 2 tap.
Old 06-06-2019, 09:18 PM   #13
Russian Bot
Helmut's Avatar
Rewards Points: 3,887
Bunrdy(?) or blackburn makes a H or C -tap crimp I believe,
http://www-public.tnb.com/ps/fulltil...rt=54780&co=US
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
Old 06-06-2019, 11:05 PM   #14
Jlarson's Avatar
I mean yeah if you have a crimp tool you could H or C tap it.
But there are split bolts that can do that sort of run and tap combo and you just need wrenches to do them.
Old 06-07-2019, 12:53 AM   #15
Rewards Points: 6,565
Originally Posted by Southeast Power View Post
OK,
I'm glad I read the replies before I jumped right in. That was the first thing that popped into my tiny little mind, what situation would this be acceptable in? Then, which ones wouldn't it be?
Old 06-07-2019, 12:54 AM   #16
OK,
Edit: double post.
Old 06-07-2019, 04:05 AM   #17
Rewards Points: 3,282
It's getting harder to find the info on the web sites, a lot of the manufacturer's web sites are more mobile friendly, they just don't contain the technical info you need any more
Ilsco AK-500
http://www.ilsco.com/wp-content/uplo...12/FORM-10.pdf
Burndy KSA500
https://www.ideadigitalcontent.com/f...URBRO/5077.pdf
Old 06-07-2019, 04:52 AM   #18
Would there be a problem with the tap rules? I'd have thought it's OK as long as the main is within 10' and probably at 25'.
460 Delta likes this.
Old 06-07-2019, 05:14 AM   #19
460 Delta's Avatar
Rewards Points: 520
Your'e right, I was thinking of a long mid-span tap in a pull C for some reason. Probably was confusing something Iv'e seen [I wouldn't do this]in my travels working on R-mix plants.
The Following User Says Thank You to 460 Delta For This Useful Post:
splatz (06-07-2019)
Old 06-07-2019, 05:20 AM   #20
What about using the Polaris IPLD500-3? 3 ports, it accepts conductors from both sides, and handles 500MCM to #4.
Just cut the conductors, strip a little off each end, insert them into the connector, then insert the #2- Done. No having to insulate in tight spaces, and you can cut all the conductors at once to get the other ones out of your way as you work.
