Splicing fan wires - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
  • 1 Post By B-Nabs
  • 3 Post By MechanicalDVR
  • 2 Post By MechanicalDVR
  • 5 Post By splatz
  • 3 Post By Signal1
  • 1 Post By CoolWill
  • 1 Post By HackWork
  • 1 Post By zac
Old 06-22-2019, 02:33 PM   #1
zac
Rewards Points: 826
Default Splicing fan wires
Quick question concerning splicing. I have to extend some fan wires and was wondering the best method of the two:
A. Butt splice (insulated)
B. Heat shrink
C. Both?
This should be interesting.
Old 06-22-2019, 02:43 PM   #2
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
Personally I would do solder and heat shrink.
micromind likes this.
The Following User Says Thank You to B-Nabs For This Useful Post:
zac (06-22-2019)
Old 06-22-2019, 02:45 PM   #3
Rewards Points: 3,050
A. What type fan are you talking?
B. What environment are the wires located in?
C. What wire size / amp draw are you talking?
Bird dog, MikeFL and Max C. like this.
Old 06-22-2019, 02:52 PM   #4
zac
Rewards Points: 826
A. Residential.
B. Rod.
C. Probably 1/2 amp.
Old 06-22-2019, 03:07 PM   #5
Originally Posted by zac View Post
A. Residential.
B. Rod.
Insulated butt splice.
sbrn33 and Max C. like this.
zac (06-22-2019)
Old 06-22-2019, 03:28 PM   #6
Rewards Points: 1,316
A western union splice, soldered and insulated with heat shrink, is super secure and strong but it's overkill IMO in this case. If it had to be bomb proof it's a good way to go. If was low voltage you could splice legally without solder and it would be great.
The insulated stakon type butt splices are great with stranded wire but so-so with solid wire. In this case I wouldn't worry too much about it.
If it's solid wire, I'd take an uninsulated butt splice and heat shrink over the insulated type. You can crimp these down harder and deform the solid wire some so it grips better.
Insulated, they aren't made to crimp down super hard, the die is made so the tool bottoms out before you mangle the insulation. It's very easy to heat shrink over the uninsulated.
Stagger the butt splices so they don't overlap, and use three pieces of shrink tube, two small pieces over each butt splice then a bigger piece over both. I usually use the marine type with glue inside because why not.
zac (06-22-2019)
Old 06-22-2019, 03:38 PM   #7
Rewards Points: 1,641
I wish Wago would make an inline levernut, similar to the Ideal Spliceline inline connectors.
I like the Splicelines for solid but I don't think smaller stranded wire like fan wiring pushes in right.
In your situation I would just use butt splice crimps with 2" wide tape around it.
zac (06-22-2019)
Old 06-22-2019, 04:06 PM   #8
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,366
The wire will break before that comes apart.
micromind, B-Nabs and splatz like this.
Old 06-22-2019, 05:11 PM   #9
To piggyback onto zac's question, what do you do when you need to lower a chandelier and there is not enough wire, and you can't open it up to run a new wire?
Old 06-22-2019, 07:46 PM   #10
I guess there's really only two options there, splice onto the end of the original wire and hope nobody really looks at it, or, cut the wire off with just a couple inches at the top, and splice on new wire as I described, with the big shrink tube right up to the base.
Old 06-22-2019, 10:16 PM   #11
zac
Rewards Points: 826
I've seen one once. The chandelier had a sleeve that went around the chain and wire. To lengthen the chain the wire needed to be spliced. The sleeve covered the whole length of the chain like a sock so the splice wasn't scene.
Old 06-23-2019, 12:20 AM   #12
CoolWill's Avatar
Rewards Points: 4,682
You guys crack me up. Solder and heat shrink for a ceiling fan Take that nonsense back to the desk-tricians over at Holt's.
JoeSparky likes this.
Old 06-23-2019, 07:27 AM   #13
I've never done it, but I asked a friend who said that he has used those little blue wirenuts with a wrap of white tape and you could only see them if you were looking for them.
This is another place where the Splicelines would work well since they are straight-thru and clear, but I can't imagine that little stranded wire would push in well.
I really gotta talk to Wago, I want a straight thru levernut connector like I mentioned here as well as a 4-port levernut in a square configuration instead of inline. For all the promotion of their product that I'e done, they owe me
Old 06-23-2019, 08:43 AM   #14
Rewards Points: 14,271
I’m sure they’ll get right on that .
Old 06-23-2019, 10:56 AM   #15
Signal1's Avatar
Made me a customer.
Old 06-23-2019, 12:06 PM   #16
Rewards Points: 5,136
Residential or commercial / industrial?
In some resi ceiling fan I would not even bother with a spice, I would just marrette some wire and be done with it.
If it was on a high velocity fan say in a barn or heat exchanger, I would be more inclined to solder and heat shrink due to the potential vibration issues.
If it was something that had to be changed out quickly or often, I might actually go with some sort of terminal block arrangement.
Cheers
John
The Following User Says Thank You to Navyguy For This Useful Post:
zac (06-23-2019)
Old 06-23-2019, 02:22 PM   #17
zac
Rewards Points: 826
I just inline spliced in with insulated butt splices and wrapped scotch 33 around it.
The fan is properly bonded so all should be good. Thanks guys.
samgregger likes this.
