Square d liquid tank switch issues - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By tates1882
  • 3 Post By Semi-Ret Electrician
  • 1 Post By MechanicalDVR
Old 01-03-2017, 11:21 AM   #1
Rewards Points: 221
Default Square d liquid tank switch issues
Here's the switch I'm having issues with:
I seem to have it set up and it works well several times in a row, and then I get a call saying it isn't working.
There is a float in the tank, long tube type, attached to a mechanism that actuates a rod, that flips a switch to a pump to empty the tank.
Any tips on setting this thing up that I might be missing? The instructions don't help
Breakfasteatre is offline   Reply With Quote
Old 01-03-2017, 11:30 AM   #2
Rewards Points: 221
Not sure how to edit in mobile:
Old 01-03-2017, 12:10 PM   #3
Rewards Points: 26,598
Mechanical issues.
These can't be solved over the Internet.
Cheers.
Old 01-03-2017, 12:26 PM   #4
zap
tates1882's Avatar
Rewards Points: 1,078
Not sure what the white build up is but that could be your culprit. Maybe causing the rod to jam and not start/stop the pump. I would ditch the mechanical float and change to something else.
sbrn33 likes this.
tates1882 is online now   Reply With Quote
Old 01-03-2017, 01:28 PM   #5
Semi-Ret Electrician's Avatar
Rewards Points: 486
There are 20 methods to measure and control level in a vessel and I've used them all.
The following questions are:
temperature
pressure
fluid: solid/ liquid
corrosive
biohazard
conductivity
viscosity
flammable
budget
clear liquid
need for redundancy
radioactive
sbrn33, MechanicalDVR and glen1971 like this.
Old 01-04-2017, 09:02 AM   #6
Rewards Points: 3,050
temperature
pressure
corrosive
biohazard
conductivity
viscosity
flammable
budget
clear liquid
need for redundancy
radioactive
It always helps to start at the beginning of a story rather than near the end when problem solving.
glen1971 likes this.
3way switch used as a bypass Anathera General Electrical Discussion 20 06-21-2016 01:33 AM
