Square Knockout seal? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
  • 3 Post By Majewski
  • 1 Post By Going_Commando
  • 3 Post By wcord
  • 7 Post By freeagnt54
  • 2 Post By philipdybel
  • 2 Post By 220/221
  • 3 Post By thespunkster
Old 07-22-2016, 09:00 PM   #1
Rewards Points: 8
Default Square Knockout seal?
Does anyone know of any square knockout seals? I have a square hole to seal up and using a round knockout seal isn't an option for the location. I've never seen one before, but figured it wouldn't hurt to ask.
Shocked101 is offline   Reply With Quote
Old 07-22-2016, 09:05 PM   #2
Rewards Points: 1,477
Does it have to be neat, or could you bolt on a 4" blank cover plate?
Old 07-22-2016, 09:08 PM   #3
Rewards Points: 8
Yes I needs to be neat. PLC inside cabinet and it's in a wash down area. really don't want to drill more holes in the side and make a "make shift" gasket. Welding a plate isn't an option either due to warping. just thought id ask around otherwise im going to reach out to an outside machinist vendor and have my own seals made up.
Old 07-22-2016, 09:12 PM   #4
Gotcha. Sorry, I don't know of anything that will seal it, look good, and be square. Good luck.
Old 07-22-2016, 09:14 PM   #5
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
If and when you find someone, I'd love to see before and after pictures!
Old 07-22-2016, 09:14 PM   #6
Going_Commando's Avatar
Rewards Points: 1,542
Got a meter socket or 3r panel hub cover floating around? Slap that bad larry on there, rtv silicone around it, and nothings getting in.
Majewski likes this.
Old 07-22-2016, 09:15 PM   #7
wcord's Avatar
Rewards Points: 1,656
Meter socket hub closure seal
Old 07-22-2016, 09:23 PM   #8
freeagnt54's Avatar
Rewards Points: 66
What size is the hole? Hoffman makes these from 1/2 to 4" and they don't care what shape the hole is.
freeagnt54 is offline   Reply With Quote
The Following User Says Thank You to freeagnt54 For This Useful Post:
MechanicalDVR (07-22-2016)
Old 07-22-2016, 09:26 PM   #9
Jlarson's Avatar
Rewards Points: 4,074
I'd whip one up out of a little square of stainless in no time.
The Following User Says Thank You to Jlarson For This Useful Post:
John Valdes (07-23-2016)
Old 07-22-2016, 09:32 PM   #10
Rewards Points: 416
Default Reund Peg, Square Hole?
Can it be round & big enough that covers the square hole? These are water-tight by Milbank and Hoffmann, and the Wiegmann is also oil-tight. Probably fine for wash-down...
John Valdes and wcord like this.
philipdybel is offline   Reply With Quote
Old 07-23-2016, 04:47 AM   #11
220/221's Avatar
Rewards Points: 4,116
End caps/plugs for square steel tubing.
John Valdes and readydave8 like this.
Old 07-23-2016, 07:34 AM   #12
Rewards Points: 22
You could knock-out the square hole to the closest size round knock-out seal.
readydave8, wcord and daveEM like this.
thespunkster is offline   Reply With Quote
Old 07-23-2016, 03:15 PM   #13
Rewards Points: 3,006
What is the size of this square hole that needs the cover?
Old 07-25-2016, 05:13 PM   #14
Rewards Points: 332
Wash down implies NEMA / UL Type 4 or 4X. Assuming the box has that rating, or did before the square hole was made, whatever you use to seal that hole now will need to be rated as a Type 4/4X closure. The Hoffman plugs shown would be, and as mentioned, they don't really care if the hole beneath them is round or square, as long as the gasket covers the entire open area and seals against the enclosure. The machinist made or the square meter cover + RTV idea might technically work, but if it's going to be inspected, would not pass.
In the past, I have used the end closure plates made for NEMA 4X wireway and passed inspection, so long as the size works out because they only come in 4x4 or 6x6 sizes. Do a search for a Hoffman F44WPSS to see what it's like. But it would mean drilling 4 small holes for the SS screws in each corner to hold it down, it's not a clamp type of plate.
Red seal trade 6foot8sparkie Canadian Electrical Forum 8 07-07-2016 10:25 AM
AMP Rating for Square D QOC24UF swimmer Commercial Electrical Forum 3 07-05-2016 09:41 PM
Red seal Arcflasher Commercial Electrical Forum 5 06-12-2016 12:16 PM
Milwaukee 2-1/2 in. x 4 in. Knockout Set mobiledynamics Electrician Swap 3 05-13-2016 07:36 AM
Obsolete Square D QOC442L series G2 Panel Covers RePhase277 General Electrical Discussion 2 01-19-2016 02:11 PM
