Star Or Delta Motor - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2015, 09:39 PM   #1
Rewards Points: 52
Default Star Or Delta Motor
Our existing equipment in factory used the following spec of 3 phase motor.
5.5kW
415/S
1430/63 RPM
Now the above "Star" motor was damaged, can we change it to the following spec of 3 phase motor?
5.5kW
415/D
1400/63 RPM
Thanks.
atjm88 is offline   Reply With Quote
Old 02-27-2015, 10:11 PM   #2
Vintage Sounds's Avatar
Rewards Points: 4,004
Is this an application where the 30 RPM speed difference is critical?
Old 02-27-2015, 10:26 PM   #3
Rewards Points: 52
It's a gear motor and the output from the gearbox is connected to the chain for the rotating part of the material flowing only.
As by my knowledge, I think we usually see the output speed from the gearbox only right which is 63RPM at the end? As the 1400 and 1430 RPM both are 4 pole, if not mistaken, they should be the same? Please correct if I'm wrong.
Thanks.
Old 02-27-2015, 11:10 PM   #4
Rewards Points: 334
Thanks.
They are both 4 pole, but they have different amounts of slip. The 1400RPM will have slightly more torque, but not enough to get excited about. The important part in all of this is that the final speed at the working shaft is still 63RPM, which is what you want. The rest of that is interesting, but totally irrelevant, including the Star vs Delta part of it. There will be a difference in how the connections will be made, different numbers on the wires etc., but just follow the instructions on the new motor, ASSume nothing.
Tags
3 phase, delta, motor, star
Star-delta starting motor parallel feeds dantheman79 General Electrical Discussion 12 09-25-2014 04:02 PM
Star-Delta Motor Starting Polarity. cthom PLCs, VFDs, Motors and Controls 3 09-01-2014 11:51 PM
Star/Delta motor starter troubleshooting Electrorecycler PLCs, VFDs, Motors and Controls 23 05-03-2014 07:47 AM
star/delta motor blow fuses on isolation timetunnel General Electrical Discussion 13 08-12-2013 08:11 PM
Star/delta Motor Fault andyd1970 General Electrical Discussion 6 07-27-2013 07:55 AM
