Start Current - Electrician Talk - Professional Electrical Contractors Forum
Old 08-23-2012, 05:40 PM   #1
quanchai's Avatar
Rewards Points: 150
Default Start Current
Hi Guys
Can some one please explain, How to figure out the starting current on a
Motor ore a A/C Compressor?
quanchai is offline   Reply With Quote
Old 08-23-2012, 05:46 PM   #2
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
If the locked rotor current is listed (LRA) then that's going to be your starting current. Otherwise the rule of thumb is 6-10 times the full load current.
I've heard it said that because you're putting voltage to a load with very low initial impedance, that taking a resistance measurement and using ohms law will give you a worst-case estimate of locked-rotor current, but I don't know how true that is.
-John
Old 08-23-2012, 06:05 PM   #3
quanchai's Avatar
Rewards Points: 150
So you mean the LRA means the starting current ?
Old 08-23-2012, 06:10 PM   #4
triden's Avatar
Rewards Points: 382
LRA is the maximum current that the motor will ever draw. It's the current at the time when the rotor is in a stationary state and power is applied. Since the rotor is stopped, it will draw the LRA when starting for a very short period of time.
The Following User Says Thank You to triden For This Useful Post:
Big John (08-23-2012)
Old 08-23-2012, 06:14 PM   #5
quanchai's Avatar
Rewards Points: 150
How do i find out the LRA if it's not mentioned on the motor ore compressor
Old 08-23-2012, 06:21 PM   #6
Rewards Points: 3,522
-John
My experience has been 4-8 times is closer to a realistic number though under certain circumstances we have seen 12 times.
Old 08-23-2012, 06:22 PM   #7
Use a clamp on with motor in rush capabilities, use a high speed disturbance analyzer.
Contact the manufacture. Do a google search.
Old 08-23-2012, 06:56 PM   #8
quanchai's Avatar
Rewards Points: 150
Is there no way to calculate the LRA ?
Old 08-23-2012, 07:12 PM   #9
Only roughly estimate it.
Is the motor fully loaded, over loaded, lightly loaded, utilized per design, belts properly tightened.
Hence 4-8 times is a rough number
Motor draws 10 amps inrush/starting current is 40-80 amps but it could be higher 100-120 amps.
Old 08-23-2012, 07:21 PM   #10
quanchai's Avatar
Rewards Points: 150
Well i got two A/C units each are 18000btu same comp size. The first one is 5 years old and the second one is 1 year old
The old one draws around 80 amps when starting
and the other one draws 40 amps at start point
What i did to find out how much the start current is was by looking at the Ammeter
that i got at home when one of them kicked in
So i want to find out what is the right LRA for the Comp
Old 08-23-2012, 07:41 PM   #11
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I'd bet the LRA is on a nameplate somewhere. That aside, it can be hard to get accurate starting current without a true RMS meter with a fast sampling time.
What model ammeter did you use?
-John
Old 08-23-2012, 07:55 PM   #12
quanchai's Avatar
Rewards Points: 150
LRA is not meantioned any where
I use a normal ammeter gauge
P.S
what does P1MAX and P2n on motors mean ?
Finding line current when neutral current is given? CelticElect NEC Code Forum 56 12-07-2011 10:25 PM
Soon to Be Pre-Apprentice - I want to start learning, where do I start? csbwmn General Electrical Discussion 11 07-01-2011 11:28 AM
if you had to start again.......... jhall.sparky General Electrical Discussion 31 06-20-2011 05:59 PM
im trying to start out and need help! cucucachu0000 General Electrical Discussion 1 07-01-2008 06:30 PM
