Static auger - Electrician Talk - Professional Electrical Contractors Forum
Old 02-23-2015, 08:34 PM   #1
Rewards Points: 698
Default Static auger
We have an underground pvc conduit that is dry and we were running a stainless steel hand operated drain cleaning machine through. I believe it's creating static electricity that shocks pretty hard. We were looking for another source and put a meter on it and it appears that the meter is ruined. It doesn't power on. The pvc is a grain vacuum. Anyone have any experience with this?
garfield is offline   Reply With Quote
Old 02-23-2015, 08:42 PM   #2
Cow
Rewards Points: 4,914
I've heard pvc dust collector systems build up one heck of a static charge. I've also heard that some people lay a bare ground wire through the piping to keep it to a minimum.
I'd assume grain vacuum piping is probably the same way.
Old 02-23-2015, 09:22 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
So you're running a flex auger through this? Stop holding back and tell us details. Let me guess, the flex auger is made of rolled, half inch square stock. The product is dry, the pipe is non conductive, and the weighed product scale it's dropping onto, made of stainless steel, and grounded, is being damaged. Am I close?
Old 02-23-2015, 09:31 PM   #4
Rewards Points: 698
Well it's just a grain probe and the pipe is used to transfer the sample and it just eventually gets plugged up with dry grain dust etc. The employee running the auger called us thinking it was an electric shock.
Old 02-24-2015, 08:03 AM   #5
Rewards Points: 1,224
The probe pipe should be conductive to prevent that problem.
Old 02-24-2015, 08:18 AM   #6
MWayne's Avatar
Rewards Points: 270
The worst I've ever been shocked was by a shop vac hose while vacuuming up dust from a hole that was behind hammer drilled. Through dry leather gloves! Like a dummy I couldn't believe what was happening and I got zapped several times until I laid the hose down by the drill and kept in place with a tool box laying on it.
Try keeping the stainless steel snake grounded with a jumper wire and see if that will shunt the static away from the person.
MWayne is offline   Reply With Quote
Old 02-24-2015, 08:27 AM   #7
Southeast Power's Avatar
Rewards Points: 8,716
You do mean to say to ground out the machine and not the snake right?
If not, I see some shearing action happening here.
Old 02-24-2015, 11:18 PM   #8
MWayne's Avatar
Rewards Points: 270
Originally Posted by jrannis
You do mean to say to ground out the machine and not the snake right? If not, I see some shearing action happening here.
Yes.
Old 02-24-2015, 11:28 PM   #9
Rewards Points: 698
After a little more experimenting we could lay the tail of the snake on the ground or we could snap a carabiner on the cable that was run to an alligator clip hooked to a screwdriver and avoid the shock. The spark would jump 3/4 of an inch and really hurt.
Old 02-25-2015, 12:12 AM   #10
Rewards Points: 25
Also sounds like it could have potential (no pun intended) to be a grain dust explosion hazard if it is creating 3/4" arcs.
raldous is offline   Reply With Quote
The Following User Says Thank You to raldous For This Useful Post:
Almost always lurkin (02-25-2015)
Auger bits Jstanton27 Tools, Equipment and New Products 19 09-14-2013 01:20 PM
Auger Art Deep Cover General Electrical Discussion 7 08-31-2013 12:49 AM
Sharpening auger bits Current General Electrical Discussion 75 09-29-2012 09:36 PM
Greenlee stubby auger zwodubber Tools, Equipment and New Products 21 11-30-2011 10:49 PM
Let's talk auger bits! 480sparky Tools, Equipment and New Products 22 11-28-2010 01:27 AM
