Stranded vs Solid Wire - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree34Likes
Old 05-29-2018, 08:39 AM   #21
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,602
Originally Posted by zac View Post
I prefer solid wire (#12-14) to pull by myself off the reel. Stranded is great if you have someone feeding the wire otherwise it coils up on itself and costs more for your effort!
I pull from under and slip every other spool as over to keep them from doing that. But I donít pull stranded very often, only when I need to.
zac (05-29-2018)
Old 05-29-2018, 09:01 AM   #22
Rewards Points: 1,878
Originally Posted by Southeast Power View Post
Im not sure about Turkish conductors but, here in the States, you can fold a piece of solid wire in half, beat it flat with a hammer and it won't just crack.
Aluminum on the other hand...
Old 05-29-2018, 09:12 AM   #23
Small Potatoes
flyboy's Avatar
Rewards Points: 3,963
I like to run a solid ground wire with all other conductors stranded for raceway work since it makes for easier termination to box and device grounding means. I also use backwired (not to be confused with backstab) wiring devices which makes work with stranded much easier. It also makes pushing the wire through the raceway a bit easier with one solid conductor. This highly perfected and excellent system has been trademarked by me and I have exclusive use of it.
I see
Old 05-29-2018, 09:15 AM   #24
MikeFL's Avatar
Rewards Points: 624
Stranded is less susceptible to metal fatigue.
Stranded is used where repetitive bending is anticipated. An extension cord is the easiest example.
An umbilical cord is another example (cable assembly between control and something that moves).
Stranded will carry more current but the NEC is not going to tell you that.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 05-29-2018, 11:55 AM   #25
MTW
Rewards Points: 10,268
Originally Posted by flyboy View Post
I see
You'll be hearing from my attorney if I catch you using my method.
JoeSparky likes this.
The Following User Says Thank You to MTW For This Useful Post:
Lone Crapshooter (05-29-2018)
Old 05-29-2018, 03:12 PM   #26
Electrical-EE's Avatar
Rewards Points: 142
Default Quality
That might be a high-quality one and soft drawn with a lower diameter.
One thing about life: it goes on!
Automation solutions:
Electrical-EE is offline   Reply With Quote
Old 05-29-2018, 04:31 PM   #27
Small Potatoes
flyboy's Avatar
I see
Old 05-29-2018, 04:45 PM   #28
MTW
I see
Old 05-29-2018, 05:50 PM   #29
Vacated
Wiresmith's Avatar
Rewards Points: 2,848
Originally Posted by joebanana View Post
Where do you run wire that corrosion is a problem?
i didn't mean if corrosion was a problem, if it was i would use tinned. what i meant was like for exterior grounding, a lot of old installations i have ran across i have seen stranded wire corrode away in spots, it corrodes the same way its just stranded has more surface area exposed to the environment so it takes less time to cut through or thin it
Old 05-29-2018, 05:56 PM   #30
Rewards Points: 1,314
Nobody said they like solid better for wire nut splices and screw terminals?
The thing I hate about stranded is getting a stray strand and getting a short, but that's more for green terminal blocks.
B-Nabs likes this.
Old 05-29-2018, 06:22 PM   #31
I like forks crimped on stranded over solid hooks. I hate untwisting energized solid splices.
Old 05-29-2018, 06:22 PM   #32
Vacated
Wiresmith's Avatar
Originally Posted by readydave8 View Post
I have heard that many times and always wonder why solid and stranded same amps per NEC
Or am I missing something?
the way i understand it is eddy currents have less effect, same principle as laminated transformer cores
in terms of ampacity, i think it is what tggt might be thinking of, i think you can run bare solid hotter (or high temp insulation) because the small strands will brake down quicker at the same temperature, but at the same alternating current i've never checked it but have been told and think it makes sense stranded runs cooler; 1 less eddy current loss, 2 more surface area for heat dissipation
Originally Posted by TGGT View Post
Last time I checked solid had a higher amp rating. I'm in a food coma a few yards from my code book so I don't plan on looking it up.
Old 05-29-2018, 06:27 PM   #33
Vacated
Wiresmith's Avatar
Originally Posted by Electrical-EE View Post
Stranded wire is more flexible in terms of usage. Internal wiring of equipment is done using stranded wires, transmission lines, automotive and robotics use stranded wires since it can easily bend around.
In terms of durability, solid wire is useful in places where bends and vibrations don't take place.
As TGGT said:
I heard many times solid wire had high amps ratings than stranded as this solid vs stranded article also mentions.
In terms of pulling stranded are easy, however terminating such wires can be a headache is few cases.
that article says same diameter. stranded is slightly larger because of voids
Old 05-29-2018, 06:34 PM   #34
I will only wrap a stranded wire around a screw terminal in a real pinch, I just hate it. Forks or hooks for me with stranded wire on screw terminals but backwire is really the first choice.
Anyone know of an uninsulated hook terminal that's listed / kosher?
Old 05-29-2018, 06:49 PM   #35
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
common ... no frown...that was funny
Old 05-29-2018, 06:56 PM   #36
lighterup's Avatar
Also , machinery or equipment that vibrates when running...that is
if it is shaking the terminations / points of connection...solid is known
to eventually break in half as opposed to stranded can handle it
Old 05-29-2018, 06:59 PM   #37
lighterup's Avatar
What happened to the OP?
Not interested in the dialouge
SPOILER ALERT
He was CS troll posting (or Hacks)
Old 05-29-2018, 09:34 PM   #38
neutral member
readydave8's Avatar
Rewards Points: 138
So solid will carry more amps, but stranded will carry more current?
lighterup, MTW and gpop like this.
Dave Ruth
The Following User Says Thank You to readydave8 For This Useful Post:
lighterup (05-29-2018)
Old 05-29-2018, 09:39 PM   #39
lighterup's Avatar
Thanx Dave...I did not know this
Old 05-29-2018, 09:47 PM   #40
Rewards Points: 1,991
I see
Crimping Solid Ground Wire rellison General Electrical Discussion 79 03-10-2018 02:20 PM
CEC 2012 - How to find resistance of a particular length of solid wire snapper007 Canadian Electrical Forum 31 11-11-2017 10:16 PM
stranded aluminum spliced to solid copper at range johnnyfalcon NEC Code Forum 13 10-19-2017 09:06 AM
compression lug selection - finely stranded wire NitroTurkey Alternative Energy Forum 3 12-16-2016 07:41 AM
Wire Strippers for #18 stranded 2 conductor !Tom Tools, Equipment and New Products 22 05-04-2016 09:22 PM
