Stuck locknuts - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-29-2015, 07:08 AM   #21
Rewards Points: 134
Locknuts on couplings?????
Sparky48 is offline   Reply With Quote
The Following 3 Users Say Thank You to Sparky48 For This Useful Post:
220/221 (01-29-2015), CopperSlave (01-29-2015), glen1971 (01-29-2015)
Old 01-29-2015, 07:19 AM   #22
Rewards Points: 132
Locknuts. And the issue being crimped on male box connectors to the panel, and crimped couplings down the whole pipe until it's destination.
If there were any junctions in the attic, it wouldn't be hard to modify the conduit run, but they ran far with no junctions.
dielectricunion is offline   Reply With Quote
Old 01-29-2015, 09:15 AM   #23
JDJ
Rewards Points: 547
Originally Posted by five.five-six View Post
Tubing cutter is a code violation IIRC
First trick: if there's no wire inside, heat it with a torch
2nd trick, cut it with a dremmel.
This kind of tubing cutter would be acceptable I believe.
http://www.toolup.com/greenlee_8600_...FW4V7AodpkcAyg
JDJ is offline   Reply With Quote
Old 01-29-2015, 09:17 AM   #24
JDJ
Rewards Points: 547
Originally Posted by LARMGUY View Post
Those , look like my next new toys
Old 01-29-2015, 11:34 AM   #25
220/221's Avatar
Rewards Points: 4,352
I am always amazed that locknuts come off so easily after many decades.
Only one out of thousands give me trouble.
Maneuvering is tricky but, I would try the sawsall method.
Old 01-29-2015, 11:34 AM   #26
Fond of three phase
Rewards Points: 928
Originally Posted by dielectricunion View Post
These were flush mounted in plaster board wall stud bays. The locknuts are a tacky kind of steel that tends to cling like the way some cast couplings are tacky against pipe.
I seldom, if ever use any pot-metal EMT connectors or pot-metal locknuts. Pot-metal Romex connectors usually come with the same type locknut. I use a steel one instead.
I use the drill method, someone else suggested. They snap right off, using channelocks.
retiredsparktech is offline   Reply With Quote
Old 01-29-2015, 03:45 PM   #27
Watt Pusher
B-Nabs's Avatar
Rewards Points: 486
I use one of these to ream a pipe I've cut with a tubing cutter, works great:
http://toolsandparts.com/store/reed-...with-3-blades/
Old 01-29-2015, 07:02 PM   #28
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
A couple of times I have a piece of EMT that I had no choice but to cut with a tubing cutter. I found an old dull uni-bit takes the inside ridge down pretty quickly then a quick rub with a rat tail file and your good to go.
For old stuck locknuts I use the drill bit method. I just drill into the locknut on the edge of it and split the old crap off of the connector.
The Following User Says Thank You to Rollie73 For This Useful Post:
Old 01-29-2015, 07:46 PM   #29
Rewards Points: 250
They work very well but they aren't cheap.
local134gt is offline   Reply With Quote
Old 01-29-2015, 08:59 PM   #30
Southeast Power's Avatar
Rewards Points: 144
How about PB Blaster on the locknuts?
Old 01-29-2015, 09:21 PM   #31
Rewards Points: 4,138
Hammer and a cold chisel... Drill and a carbide burr to cut through the side of it.. Die grinder... 24" pipe wrenches...
How big of a locknut are we talkin about?
Old 01-29-2015, 09:42 PM   #32
Rewards Points: 2,328
In panels use a small SDS electric hammer like a 1" Bosch with a precussion only setting and a worn out chisel. Or for that matter grind a chisel fat or blunt . I have seen a contractor use a similar setup to tighten 4"locknuts.
LC
Old 01-29-2015, 09:47 PM   #33
Rewards Points: 132
LC
I'd be worried about the thing jumping around and contacting the hot lugs or something. Being a quick changeover, we had to prep everything as far as possible with panel and branch circuits hot.
All conduits besides the feeder were 1/2" and 3/4, but in a small 100 amp panel and tight together, which really only allowed a screwdriver or slim tool in there.
Old 01-29-2015, 09:56 PM   #34
freeagnt54's Avatar
Rewards Points: 66
I've ran thousands of feet of emt using a tubing cutter. You have to score the outside and "snap" the pipe in the bender, after a little bit of practice it shouldn't leave a burr. In the instances that you have to remove a burr, this tool works great.
http://www.amazon.com/General-Tools-...deburring+tool
Don't get one with a plastic handle, they're crap.
freeagnt54 is offline   Reply With Quote
Old 01-29-2015, 10:03 PM   #35
Rewards Points: 12
The OP said it was in a nursing home, want to hear some sniveling? Use PB Blaster indoors then watch the staff start complaining as the stench flows throughout the building. PB Blaster stinks when used in the open air, use it a closed space & it really will stink.
Norcal is offline   Reply With Quote
Old 01-29-2015, 10:18 PM   #36
Rewards Points: 3,078
soak overnight with PB Blaster
Greg
Old 01-29-2015, 10:29 PM   #37
Rewards Points: 682
Go down to the drug store and get some Oil of Wintergreen. It's a great non-toxic rust cutter and lubricant, plus it smells great. People will just think you are chewing a lot of gum.
Despite popular belief, WD40 is not that great of a rust cutter or lube. It's purpose is in the name; WD stands for Water Displacer. Personally I hate the smell, as do a lot of people. In high school I worked in a junk yard tearing apart antique cars, all we ever used was Oil of Wintergreen. I have never found anything better, including Liquid Wrench.
Old 01-30-2015, 01:31 AM   #38
Jlarson's Avatar
Rewards Points: 340
Crappiest tool ever
Old 01-30-2015, 05:56 AM   #39
Rewards Points: 144
Not sure but, I think everyone here will agree that if someone showed up on my job with a tubing cutter expecting to run EMT, I would either get his money or hand him a shovel.
Old 01-30-2015, 07:19 AM   #40
neutral member
readydave8's Avatar
Rewards Points: 18
Hard to make the nursing homes I worked in smell worse
Dave Ruth
Those locknuts? farlsincharge Lighting Design 13 01-03-2014 11:14 AM
Locknuts and ground bushings vida General Electrical Discussion 6 09-19-2012 10:49 PM
Sealing locknuts Antmc22 NEC Code Forum 6 05-25-2012 12:55 PM
locknuts on rigid Conduit Phil General Electrical Discussion 16 05-30-2010 08:32 PM
MC Connectors requiring locknuts??? scottfwelch NEC Code Forum 15 06-09-2009 07:47 AM
