Stuck locknuts - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-30-2015, 08:29 AM   #41
Rewards Points: 132
Originally Posted by readydave8 View Post
Originally Posted by Norcal View Post
The OP said it was in a nursing home, want to hear some sniveling? Use PB Blaster indoors then watch the staff start complaining as the stench flows throughout the building. PB Blaster stinks when used in the open air, use it a closed space & it really will stink.
Hard to make the nursing homes I worked in smell worse
The urine soaked sheets coming down the laundry chute were piling up as I was piping out the laundry room. Then someone dumped a loaded diaper in the trash can there. I thought baby smelled, try a full grown adult taking a dump in a diaper
dielectricunion is offline   Reply With Quote
Old 01-31-2015, 04:05 AM   #42
freeagnt54's Avatar
Rewards Points: 66
Originally Posted by jrannis View Post
Not sure but, I think everyone here will agree that if someone showed up on my job with a tubing cutter expecting to run EMT, I would either get his money or hand him a shovel.
It was a requirement on the job we were on
freeagnt54 is offline   Reply With Quote
Old 01-31-2015, 08:42 AM   #43
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Originally Posted by JRaef View Post
Go down to the drug store and get some Oil of Wintergreen. It's a great non-toxic rust cutter and lubricant, plus it smells great. People will just think you are chewing a lot of gum.
Despite popular belief, WD40 is not that great of a rust cutter or lube. It's purpose is in the name; WD stands for Water Displacer. Personally I hate the smell, as do a lot of people. In high school I worked in a junk yard tearing apart antique cars, all we ever used was Oil of Wintergreen. I have never found anything better, including Liquid Wrench.
Completely off topic .....like that's an unusual event around here......but Oil of Wintergreen also works awesome for softening up old rubber. I used it and some rubbing alcohol mixed together to soak the carb boots for one of my motorcycles. The rubber was all dried and hard and impossible to work with, soaked it in that **** for 24 hrs......and the rubber was soft and malleable and slid right on the carbs and onto the heads like they were brand new.
Old 02-01-2015, 07:28 PM   #44
Rewards Points: 121
I just take a 1/ 4" drill bit to them and drill them in half
ibew415 is offline   Reply With Quote
Old 02-03-2015, 10:49 AM   #45
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Snap the lockout. Pry and snap.
The Following User Says Thank You to Shockdoc For This Useful Post:
mcclary's electrical (02-03-2015)
Old 02-03-2015, 11:26 AM   #46
just the cowboy's Avatar
Rewards Points: 24
Originally Posted by dielectricunion View Post
I'd be worried about the thing jumping around and contacting the hot lugs or something. Being a quick changeover, we had to prep everything as far as possible with panel and branch circuits hot.
All conduits besides the feeder were 1/2" and 3/4, but in a small 100 amp panel and tight together, which really only allowed a screwdriver or slim tool in there.
Watch that hot work, it's a no no. Be careful if they have you do hot work all the time.
"DID THIS FIX IT??"
Old 02-03-2015, 11:59 AM   #47
Rewards Points: 374
I would be interested in any info that would indicate that a tubing cutter is against code. I have always used one with a reamer and as mentioned already, I am pretty sure that is the issue. Also, to remove rusty or bound nuts in tight spaces I always drill and split.
Hawkrod is offline   Reply With Quote
The Following User Says Thank You to Hawkrod For This Useful Post:
retiredsparktech (02-03-2015)
Old 02-03-2015, 09:30 PM   #48
Rewards Points: 10,226
Originally Posted by JDJ View Post
This kind of tubing cutter would be acceptable I believe.
http://www.toolup.com/greenlee_8600_...FW4V7AodpkcAyg
I have never used that greenlee, but the ones that the plumbers use will remove a small strip of the "N" from your THHN.
Those locknuts? farlsincharge Lighting Design 13 01-03-2014 11:14 AM
Locknuts and ground bushings vida General Electrical Discussion 6 09-19-2012 10:49 PM
Sealing locknuts Antmc22 NEC Code Forum 6 05-25-2012 12:55 PM
locknuts on rigid Conduit Phil General Electrical Discussion 16 05-30-2010 08:32 PM
MC Connectors requiring locknuts??? scottfwelch NEC Code Forum 15 06-09-2009 07:47 AM
