Sump Pump load - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 01-26-2018, 09:31 AM   #21
Rewards Points: 3,062
Originally Posted by Paul S. View Post
Do you happen to know what amount of current will cause a GE inverse time circuit breaker to trip instantaneously? Do you know how long those particular motors produce their particular amount of startup current, or even if they do produce the amount of current required to throw the breaker? I don't. I do suppose this information might be obtained but I failed to do so... Alas, I probably should have erred on the side of caution rather than economy. The problem is now fixed.
I do know that running a breaker with a load of 80% plus for an extended period of time can cause it to fail.
Not knowing how long the pumps will run says 'don't do it to me'.
Glad you fixed it.
Old 01-26-2018, 09:35 AM   #22
20 amp CB 120-240 amps (6-12 times)
Sump pump depending on several factors 4-14 times.
4x9 ampsx2= 72 amps
14x9 ampsx2=252 amps
Shake the dice and see how it rolls out or install 2 circuits. It is your reputation on the line.
That is what is important to me, not looking like I took a guess.
Old 01-26-2018, 08:02 PM   #23
Rewards Points: 1,512
If your motors are only 1/2 hp ?
Then that would be 375W.
So at 10 x normal running current =3750w
3750w / 120v = 31.25A.
Even at 14 x that =5250W
5250W = 43.75A.
so a 30 or 40A breaker is required.
is it a 120v motor ?
Old 01-26-2018, 10:53 PM   #24
Rewards Points: 21,898
5250W = 43.75A.
DMX., just keep in your mind most sump pump in north Americian side typically 120 volts under 3/4 HP and most common size useally 1/4 or 1/3 HP is more common but yes there is few larger one for resdentail usage.
but anything over 3/4 HP useally go to straight 240 volts.
Paul S. (01-26-2018)
Old 01-26-2018, 11:32 PM   #25
Rewards Points: 333
5250W = 43.75A.
Yes, they are both 120V.
Paul S. is offline   Reply With Quote
Old 01-26-2018, 11:39 PM   #26
Rewards Points: 26,606
Hill side homes are often the victim of under ground streams.
This one sounds like it's at serious risk.
You should suggest a French drain.
frenchelectrican likes this.
Old 01-26-2018, 11:44 PM   #27
Rewards Points: 333
How about some pontoons? ... Seriously, it's in the middle of a large neighborhood, not on a steep slope, but it is on a higher part of the city if I am not mistaken.... I would have to really to go back and pay more close attention to know for sure... But, you are possibly right about the underground stream. Who knows for sure? ... Maybe the previous owner knows? Hmmm....
Old 01-27-2018, 09:14 AM   #28
Rewards Points: 1,986
All irrelevant what matters is what you were hired for. All the rest can be small talk.
Old 01-27-2018, 10:14 AM   #29
Can't Remember
Rewards Points: 578
Our new place is on about as level ground as you could ask for, but high water table. I have two maybe three sumps in our crawlspaces.
Old 01-27-2018, 11:55 AM   #30
My backyard is always dry and never hold standing water anywhere yet on the other side of my fence looking east the property next door holds water for days after it rains and is always mushy to walk on.
Drainage and soil content are a funny thing.
Old 01-27-2018, 11:59 AM   #31
Can't Remember
Rewards Points: 578
Most of our house is crawlspace with a small section of full basement. The previous owner lost a bunch of family history during one of the spring storms causing him to do a bunch of drainage work and pump installations. The crawlspace is all concrete and stays dry. Also a dehumidifier that's ugly, but keeps chugging along.
Tags
circuit breaker, load, loading, motor, overcurrent protection
Building Load Woodland Commercial Electrical Forum 15 01-22-2018 05:02 PM
Sump pump battery backup WronGun Residential Electrical Forum 40 05-25-2017 05:27 PM
Heat Pump Question power General Electrical Discussion 7 10-05-2016 12:58 PM
New sump pump receptacle on an old circuit. Mugs Canadian Electrical Forum 14 07-30-2016 11:30 PM
240v receptacle for sump pump. rrolleston General Electrical Discussion 16 02-07-2016 04:31 PM
