Thread Tools | Display Modes |
#1 |
Rewards Points: 70
Hi folks,
This is my first post and most definitely will not be my last. I have tried looking for more information in here and come up short. It is a two part question: 1) Since surge protectors work by dumping excessive voltages to the grounding wire, an attempt to plug any sensitive equipment into a surge protector when a residence only has a two prong system (ungrounded) would only mean you are just using an expensive power strip correct? 2) What about plugging in a surge protector into a GFCI plug that has replaced a two prong plug (still ungrounded) but GFCI protected? What does this achieve? Same as above? Thanks in advance |
Join the #1 Electrician Forum Today - It's Totally Free! ElectricianTalk.com - Are you a Professional Electrical Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for electricians to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that ElectricianTalk.com is a great community to join. Best of all it's totally free! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ElectricianTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
#2 |
![]() ![]() Join Date: May 2009
Rewards Points: 1,480
If really don't know much about this but it will definitely work if installed at the panel. I have used the surge suppressors that you install in a panel on the buss bar. It looks like a breaker but isn't.
They have some that will replace a dp 20 amp circuit so that the breaker itself is a surge suppressor
They say I shot a man named Gray and took his wife to Italy She inherited a million bucks and when she died it came to me I can't help it if I'm lucky |
The Following User Says Thank You to Dennis Alwon For This Useful Post: | Bird dog (11-17-2017) |
#3 |
Rewards Points: 70
@Dennis Alwon, thanks for the reply. That is interesting...I'm more specifically referring to the power strip type.
Advertisement |
#4 |
Rewards Points: 246
You are correct, most surge strips rely on the ground for protection, they use MOVs to shunt the surge current. However you can find surge protection devices that use other ways, some use silicone avalanche diodes or big chokes / inductors for series mode protection. You also may be able to use an isolation transformer.
As Dennis pointed out even if the circuits are two wire you can install protection at the panel, that type of protection is supposedly not quite as good for sensitive electronics as a quality surge strip, but I think it's still pretty good protection.
Everything Should Be Made as Simple as Possible, But Not Simpler |
The Following 3 Users Say Thank You to splatz For This Useful Post: |
#5 |
Senior Moment
Rewards Points: 40
We use MOVs and SASD such as a Transtector APEX IV and a lot of their other products.
Here is a link to transtector, lots of good information. https://www.transtector.com/
Sent by Commodore Vic 20 with 9.6K modem |
#6 | |
Rewards Points: 70
![]() Quote:
#7 |
Rewards Points: 2,149
Another new member
The Following User Says Thank You to active1 For This Useful Post: | Rey (11-11-2017) |
#8 | |
Rewards Points: 140
![]() Quote:
2) still helps! It can still open the circuit on lightening strikes. Mine do all the time and remember the ground does nothing on a gfci (for detecting anything) Sent from my SM-G900V using Tapatalk |
#9 | |
Rewards Points: 70
![]() Quote:
#10 |
Rewards Points: 1,750
A good quality plug strip SPD (Surge Protection Device) has 3 MOV's Line to neutral, neutral to ground, and line to ground.
The best protection is with multi level SPD one at the panel and one at point of use. A properly installed SPD at the panel will have leads as short as possible, as straight as possible no sharp bends and the conductors tightly ty-wrapped together. A GEC should also avoid sharp bends but no one does, inspectors sweat over two ground rods then the GEC to the rods has nice neat sharp bends, RePhase277 and Mike_kilroy like this.
Ah, but I was so much older then, I'm younger than that now |
#11 | |
Rewards Points: 140
![]() Quote:
Lightening was just a good example of a surge. If I ventured a guess, it causes 80% of all surges. Glad to hear you live where there is not lightening! So what clarification can I add to point 1? Hmmm... how about info on the MOVs used... 120Vac rms line has 160Vpeaks... So 180-200V MOVs typically are used. When the line voltage goes above their rated voltage, they CLAMP: means they short both their leads together. So the one across the line in the surge protector SHORTs out the surge, preventing it from remaining, thus protecting the equipment plugged into it. Just because there are not 2 more to ground does not mean the one will not work. For clarification on your point 2, perhaps google "how does a GFCI work." The ground has nothing to do with its operation. When it sees current not equal in both legs of the line, it opens the circuit to the load. Ground not involved at all. So if a surge makes huge current, it is likely to not be equal down to a few ma, thus it opens. So not having a ground attached makes zero difference in the case of the surge. Hope this helps? |
#12 | |
Rewards Points: 70
![]() Quote:
Mike_kilroy likes this.
The Following User Says Thank You to Rey For This Useful Post: | Mike_kilroy (11-16-2017) |
#13 | |
Rewards Points: 140
![]() Quote:
I am not sure how you relate the fact that power strip has 3 prong plug to requiring a GFCI... hmmm... well maybe I see where you are headed... If the gnd prong was real, and a 3 prong device is plugged in, there is a good chance the case of the thing plugged in will be grounded... so without that, adding a GFCI will offer a level of protection against current going somewhere other than between the hot and neutral... OK, I agree - good thinkin' |
#14 | |
Rewards Points: 70
![]() Quote:
#15 |
Rewards Points: 786
Maybe just instal a "whole House " surge suppressor at the panel ...it has much bigger MOVs and can probably survive surges a lot longer....it also has indication of failure of the MOVs.
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
TPMOV Surge Protection | splatz | General Electrical Discussion | 5 | 03-25-2017 12:00 PM |
Whole House Surge Protection | splatz | General Electrical Discussion | 41 | 02-07-2017 11:55 PM |
Surge Protection for SCADA and control circuits | Southworth | PLCs, VFDs, Motors and Controls | 6 | 01-25-2017 12:41 AM |
lost neutral and surge protection. | te12co2w | General Electrical Discussion | 10 | 05-26-2016 10:44 AM |
Surge protection | green light | General Electrical Discussion | 13 | 01-07-2016 09:53 PM |
