Symptoms of an open neutral - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By backstay
  • 2 Post By backstay
Old 09-24-2017, 09:15 PM   #1
Rewards Points: 20
Default Symptoms of an open neutral
can someone please shed some light on this. I've seen two separate cases in which the answer was an open neutral. both had 120v H to G and 0 H to N. the difference was N to ground for one was 0 and the other was 120. i cant figure out how these two exact opposites can point to the same conclusion.
Dizzykidd is offline   Reply With Quote
Old 09-24-2017, 09:33 PM   #2
backstay's Avatar
Rewards Points: 296
Your neutral will have 120 volts to ground if the bonding is open between the ground and neutrals and there is a closed switch feeding it.
The_Modifier likes this.
Old 09-24-2017, 11:19 PM   #3
Bird dog's Avatar
Rewards Points: 942
Draw out each circuit with it's fault. Then you will see why two different symptoms are the same problem. Were all measurements taken at the same points under the same conditions?
Old 09-24-2017, 11:28 PM   #4
Rewards Points: 26,556
[ If the neutral is pulled high it is also at 120V to G. This is to be expected any time a connected load allows the Hot to bleed voltage through to the Neutral. This can be a plugged in load like a wall wart or an incandescent lamp.
Such values are the classic sign that you're looking at an open neutral. ]
[ In this instance, no path from the Hot to the Neutral exists ( ie through a resistive or inductive load ) ... but the Neutral is still broken. ]
Does that clear it up ?
Old 09-25-2017, 11:21 PM   #5
Rewards Points: 20
Sorry guys I'm still not getting it
Old 09-25-2017, 11:25 PM   #6
backstay's Avatar
Rewards Points: 296
If you power a light and then remove the neutral wire from the neutral bus, you will have 120 volts from that neutral to ground.
hardworkingstiff and telsa like this.
Old 09-25-2017, 11:35 PM   #7
220/221's Avatar
Rewards Points: 4,116
Smoke
Get a pencil and paper and draw a couple of 120V circuits with/without loads and it may become clear.
Old 09-26-2017, 12:30 AM   #8
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 362
Originally Posted by 220/221 View Post
Smoke
It may become clearer to the experienced, but for someone entering the trade- the experienced have long forgotten what it is like to be the FNG.
Just a tip- and just the tip, break it down like its a homeowner.... You'll soon see where the experienced have lost touch.
Old 09-26-2017, 05:29 PM   #9
220/221's Avatar
I couldn't explain it to a homeowner. I can only explain it to guys I teach by using a pencil and paper. Hell, I could only understand it myself by using a pencil and paper.
My brain like to follow lines.
Old 09-26-2017, 06:34 PM   #10
Rewards Points: 14,714
Whether you have 120 or 0 between N and G depends on where the neutral is broken and whether a circuit that involves that neutral is energized with a load.
Like others said, try drawing it out.
Open Neutral Again brian john General Electrical Discussion 6 07-04-2017 09:25 PM
Open neutral Sparky Mcgregor General Electrical Discussion 12 05-26-2016 09:24 PM
Another open neutral issue EricM Residential Electrical Forum 1 05-19-2016 08:44 PM
Conductor Electek inc General Electrical Discussion 25 05-05-2016 12:02 AM
Neutral required to be ran to generator? lynes.nathan Canadian Electrical Forum 7 03-01-2016 10:10 PM
