TDR recommendations - Electrician Talk - Professional Electrical Contractors Forum
Old 08-09-2012, 09:37 PM   #1
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,170
Default TDR recommendations
Looking to buy a tdr. I would like it to display as a graph and not as a distance reading.
What are you using and what do you like?
farlsincharge is offline   Reply With Quote
Old 08-09-2012, 10:07 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
What is a TDR?
Old 08-09-2012, 10:10 PM   #3
Rewards Points: 1,038
Time Domain Reflectometer.
jefft110 is offline   Reply With Quote
The Following 2 Users Say Thank You to jefft110 For This Useful Post:
HARRY304E (08-09-2012), janagyjr (08-10-2012)
Old 08-10-2012, 06:59 AM   #4
Can't Remember
Rewards Points: 1,532
What are you going to use it on? Twisted pair, coax, power? Riser Bond, Bicotest, and Megger come to mind. Sometimes that feature is integrated within some of the phone/data testers I have seen. I have a T631 from Bicotest and a Riser Bond 1550 not something I use every day, more as an experiment in finding faults in UF.
Old 08-10-2012, 08:14 PM   #5
Sideways Sparky
I want it for #14 to 500mcm cable.
I tried a telcom tester today (Dynatel 965) on a run of 1/0 copper. I set it at 19 gauge air core cable and got no real conclusive results.
I went after with a frame on my locater and dug 7 splices up.
The one I was really looking for was burnt off and reading 4k to ground.
I wasn't really impressed with the tdr results.
I have used this machine for its intended purpose and it works great.
Old 08-10-2012, 08:37 PM   #6
Can't Remember
I wanted to use these for that purpose too, but without knowing the VOP to properly set it, you can't get the proper accuracy. I don't know how well they might work with seperate direct buried cables where the spacing between them changes the impedance along the route, unlike twisted pair or coax. I am sure you would see major changes in impedance like direct shorts or opens. I have good luck with the sheath fault type locators so this has taken something of a back seat and need of more experimentation. Interesting stuff though.
Old 08-10-2012, 10:22 PM   #7
God-fearing Volt-head
janagyjr's Avatar
Rewards Points: 536
I thought he was talking about a Time Delay Relay. My bad.
Owner, Trinity Electrical and Handyman Services
All original content licensed via the OWL (
) from date of post.
janagyjr is offline   Reply With Quote
Old 08-12-2012, 01:34 PM   #8
Yeah your gonna get wet !
Sprink's Avatar
Rewards Points: 148
I am using the triplett 3271 TDR and it works very well. The triplett 3271 is a distance reading TDR and cost about $180.00. It takes a little bit of time and experimenting to learn how to use it.
If you own a TDR I would suggest buying a measure wheel. You use the measuring wheel to set and confirm the VOP. The VOP listed for a type of wire will be close but not always accurate or you will not find it listed and have to figure it out using the measuring wheel.
Here is a good link that explains how to do it.
http://www.tscm.com/riprcop.html
This is what I would like to buy if I needed a TDR with a waveform display. http://livewireinnovation.com/products-and-services/sparkchaser/
This is a SSTDR and is the only TDR that I know of that can test on live and de-energized wires. It is also the only one that has a coupler so there is no disconnecting of wires. Not sure if coupler comes with it or extra.
They also make a nice distance reading SSTDR called the Faultchaser. http://livewireinnovation.com/products-and-services/faultchaser/
The TDR is a great tool and will save you time locating faults in your wire. I use it for Irrigation, Outdoor Lighting and for Aeration motors on septic systems.
What is the make of your A Frame?
Sprink is offline   Reply With Quote
Old 08-12-2012, 01:44 PM   #9
Sideways Sparky
It is a dynatel. The locater is a 2273 I think. It found a 60k ohm to ground fault no problem.
Thank you for the info and links.
Old 08-12-2012, 01:47 PM   #10
Can't Remember
Some of the higher end units out there have mains blocking filters available as an accessory.
any recommendations? caseyelectric General Electrical Discussion 0 05-17-2012 09:07 PM
SEO Company Recommendations?? ratrod56 Business, Marketing, and Sales 17 04-30-2012 08:29 PM
Light Meter Recommendations? electrictim510 Lighting Design 6 03-10-2012 10:32 PM
Any service van radio recommendations? Sky Seattle General Electrical Discussion 40 01-16-2012 11:18 PM
Entry Buzzer Recommendations knowshorts Structured Wiring 7 12-07-2011 08:09 AM
