Technique for sofit/mast holes - Electrician Talk - Professional Electrical Contractors Forum
Old 11-27-2012, 07:13 PM   #1
Cletis's Avatar
Rewards Points: 2,050
Default Technique for sofit/mast holes
Whats some of you all's technigues for lining up and drilling nice clean, straight riser holes through soffits ?? Laser beam, level, straight up, straght down, one movement, etc
I'm shakin it boss..I'm shakin it
Old 11-27-2012, 07:15 PM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Cue 480's tool. Be warned, it's patented.
Awg-Dawg (11-27-2012)
Old 11-27-2012, 07:17 PM   #3
347sparky's Avatar
Rewards Points: 510
I usually drill up with a long 1/4" bellhanger bit after putting a level on it.
347sparky is offline   Reply With Quote
Old 11-27-2012, 07:22 PM   #4
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,318
My trick has always been to have someone else do it.
jza is offline   Reply With Quote
The Following User Says Thank You to jza For This Useful Post:
ibuzzard (11-28-2012)
Old 11-27-2012, 07:29 PM   #5
I own stock in FotoMat!
Rewards Points: 6,520
The Binford 6300 Mast Hole Saw.
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
chewy (11-27-2012), jeffmoss26 (11-29-2012), shocksystems (01-25-2015)
Old 11-27-2012, 07:32 PM   #6
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
I haven't heard the brand Binford in a while.
Old 11-27-2012, 07:42 PM   #7
jza
Mad as Hell Member
jza's Avatar
I think I'm going to be sick.
Old 11-27-2012, 07:52 PM   #8
Rewards Points: 1,360
A 30-06 makes a nice pilot hole through both sides.
The Following User Says Thank You to RePhase277 For This Useful Post:
mcclary's electrical (01-18-2015)
Old 11-27-2012, 08:00 PM   #9
wendon's Avatar
Rewards Points: 54
I've never tried that but years ago I watched an electrician do that with a .22! Can't imagine a HO being impressed with that!!
Old 11-27-2012, 08:05 PM   #10
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I use a lazer level to project the center point up to the soffit and then run a pilot through with my 1/4" bell hanger bit then use the hole saw on each side. Works well for me.
The Following User Says Thank You to Rollie73 For This Useful Post:
Old 11-27-2012, 08:11 PM   #11
Retired Account
Rewards Points: 14,650
Technique for soft mass holes
methinks it's time to fnd my spectacles for this ......~CS~
The Following 3 Users Say Thank You to chicken steve For This Useful Post:
Chris1971 (11-28-2012), mcclary's electrical (11-27-2012), stuiec (11-28-2012)
Old 11-28-2012, 09:30 AM   #12
Amish Electrician's Avatar
All you youngsters with your whiz-bang fancy ways! Here's how I do it:
I first figure out exactly where the hub on the panel will sit. That might mean mounting the panel, marking the location, and removing the panel. You need the panel off the wall to continue.
I next mount a full stick of mast to the wall. It's mounted on center with the hub opening I marked, and I use a level to make sure it's plumb. I raise the pipe until it contacts the soffit. Now I mark the soffit, and remove the pipe.
Since I now know where my hole must be, I set my hole saw, backwards and without arbor, within the circle I drew around the pipe. This lets me mark where the pilot drill will go.
Use your hole saw to just make a score in the soffit, to just start to cut. Do not make the big hole yet.
Instead, use the little pilot hole to place a long 3/8" drill. I use a 3/8, because I find 1/4" drills bend too easily when they meet the sloped roof. Making sure I'm plumb, I drill a 3/8" hole through the roof. Now it's time to go topside.
Asphalt shingles are instant death to hole saws. So, I use a knife to cut away the shingles around the 3/8 hole I drilled. Make the cuts simple and well clear of the mast; your 'roof jack' will cover this area.
Holding my hole saw plumb, I use my Sharpie to mark the oval hole. Since I have the Sharpie flat against the saw, the marked area is about 1/4" larger all around than the 'perfect' hole. No matter, you don't need - or even want- a tight fit.
You've got a pilot hole; now cut the roof deck with a Sawsall or saber saw. You're done cutting 'on top.'
Now return to the soffit and finish the hole you started. You won't need the pilot drill to guide you, since the saw kerf you cut before will guide the hole saw.
Push the mast through, and anchor it a bit high. Hang the panel, and drop the mast into the hub. Better yet, have the hub ON the mast, and now boltthe hub to the panel. Finish tightening all your anchors.
Amish Electrician is offline   Reply With Quote
The Following 3 Users Say Thank You to Amish Electrician For This Useful Post:
David046 (02-17-2013), Stolnik (11-12-2014), swimmer (01-19-2015)
Old 11-28-2012, 01:59 PM   #13
220/221's Avatar
Rewards Points: 4,352
Remember the redneck idiot who accidentally shot/killed his wife while installing cable TV using this method? It was a great story from a couple years ago.
I only occasionally run into eave soffits out here. When I do, I just drill the soffit hole then eyeball a pilot hole thru the roof.
The Following User Says Thank You to 220/221 For This Useful Post:
plantpot (01-19-2015)
Old 11-28-2012, 07:45 PM   #14
carryyourbooks's Avatar
Rewards Points: 1,292
ditto...........or just use a 6 inch hole saw....that way you have some play if miss by a few inches or so, and you are good!
carryyourbooks is offline   Reply With Quote
Old 11-28-2012, 08:26 PM   #15
mbednarik's Avatar
Rewards Points: 1,126
bell hanger bit and a good and a junk 2 1/2" hole saw. The junk one i ram through the shingles, and use the good one for the soffit and the wood left up top. For roof too steep for the bell hanger bit, I have a peice of RMC bent into a u, 3' in each direction, with 2 level jb welded to it. Set this contraption around the soffit, line up the bottom centered both ways where the mast will be, then plumb it up. Where the top of the u tool lands on the roof is where you need to drill. I have only had to do this twice. I think each house had a steep pitch and a deep soffit.
Old 11-28-2012, 09:18 PM   #16
Electricity is Amazing!
thoenew's Avatar
Rewards Points: 538
Around here, people pay us to remove their overhead and install underground. New installations are always underground.
thoenew is offline   Reply With Quote
The Following User Says Thank You to thoenew For This Useful Post:
mcclary's electrical (11-28-2012)
Old 01-19-2015, 09:31 AM   #17
Rewards Points: 134
Here's the one we used to use. Boy does that bring back memories. We always used a longer pilot bit than shown in the picture.
Sparky48 is offline   Reply With Quote
The Following User Says Thank You to Sparky48 For This Useful Post:
Old 01-19-2015, 10:56 AM   #18
Sparks fly from my finger
Jhellwig's Avatar
Location: Where you live. Feel free to be as specific as you like. THANKS!
Rewards Points: 4,677
The guy I used to work for had something similar to that but it only drilled the pilot hole. It was just a piece of 2 inch rigid with a piece welded in each end to center the bit. The bit slid up and down a long ways. You drilled the bottom hole the stuck this up in it leveled it then drilled the pilot hole in the roof. Then you drilled out the hole up above. Worked great.
Aw carp. Zombie cleti
Old 01-19-2015, 04:47 PM   #19
220/221's Avatar
Dammit.
I hoped that Cletis was back.
Old 01-19-2015, 05:17 PM   #20
Rewards Points: 3,078
Framing Square and know how to read it.
Greg
Holes vinroc Business, Marketing, and Sales 33 05-08-2012 10:30 PM
Meter Holes #%$^ Cletis General Electrical Discussion 31 03-04-2012 12:11 AM
Holes too big...what to do now? bradleyheathhays General Electrical Discussion 21 02-16-2012 06:37 AM
Technique to punch LB from exterior to attic? swimmer Residential Electrical Forum 34 12-31-2011 05:56 AM
Is a Press Release a Viable Marketing Technique? wdestar Business, Marketing, and Sales 3 01-10-2010 01:37 AM
