Teck90 Support Question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By martindag
  • 1 Post By PlugsAndLights
  • 2 Post By martindag
Old 09-27-2016, 02:55 PM   #1
martindag's Avatar
Rewards Points: 215
Default Teck90 Support Question
Hi there,
I want to know if its legal or not to use strut channel to support a Teck90 Cable over a long distance ?
I can't find the article but i dont know why, i always used EMT Conduit for long distance installation if i had to use strut channel or straps.
For long distance on Teck90 i thought i had to use Cable Tray because using Cantruss to support these cable wasnt allowed.
Any clarification about it would be appreciated
Thanks !
martindag is offline   Reply With Quote
Old 09-27-2016, 03:00 PM   #2
Rewards Points: 416
Parallel or perpendicular to the cable?
mitch65 is offline   Reply With Quote
Old 09-27-2016, 03:02 PM   #3
Rewards Points: 14,265
No issues as far as I'm concerned. Tray is used for multiple cables. For only one cable, tray is overkill.
Old 09-27-2016, 03:36 PM   #4
martindag's Avatar
Rewards Points: 215
The strut are perpendicular to the cable.
Old 09-27-2016, 04:23 PM   #5
Rewards Points: 416
depends on the distance. For only a couple of cables we'll use 4" instrument tray then you only need strut every 3M instead of every couple of feet to keep it looking like bunting.
Old 09-27-2016, 06:44 PM   #6
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
I've attached teck to all sorts of things including the outsides of buildings.
That's one of the nice things about teck, you can use it almost anywhere
and run it on almost anything. Attaches nicely to strut with off the shelf
straps. Support within 300mm of boxes and every 1.5m throughout run.
P&L
LuckyLuke likes this.
Old 09-28-2016, 12:15 AM   #7
Rewards Points: 330
P&L
Can teck cable be run along a floor or on the ground on a concrete pad?
Canaduh is offline   Reply With Quote
Old 09-28-2016, 12:45 AM   #8
Rewards Points: 3,994
I have seen guys run cable inside of unistrut and that is one HUGE PITA IMO... Especially when the cable has to be pushed in, and a seal on one end.. Two pairs of channel locks and the strut was destroyed...
Old 09-28-2016, 12:55 AM   #9
Needs mechanical protection in those places.. Rigid PVC conduit usually works..
Old 09-28-2016, 08:05 AM   #10
Safety Pin Member
I've only done this with strut bolted to the floor immediately to one side.
Teck's tough, but not forklift, etc tough.
P&L
Old 09-28-2016, 08:09 AM   #11
martindag's Avatar
Rewards Points: 215
Thanks for the quick answer!
It's a good news then, im gonna hae more option when doing new installation.
99cents and PlugsAndLights like this.
Old 09-28-2016, 09:16 AM   #12
Rewards Points: 330
The guy I have been working for does some hot tubs and I always see teck cable near the floor going into the tub though. The last house we did a hot tub removal and the tub was about 20" away from the house wall. The installer ran teck horizontally along the house, down to the ground, then across the patio slabs the 20" distance.
The teck was on the floor for this small portion and was unprotected and got passed.
Old 09-28-2016, 09:33 AM   #13
Next time it could fail. It's a trip hazard for one thing. Lift a patio slab and dig it in. An extra half hour on the job to make it pretty makes for happy customers.
different panel from same switch gear, & panel feeder and branch circuit question mike883 General Electrical Discussion 33 10-21-2017 11:20 PM
2-005(a) is it safe to say that... NDC Canadian Electrical Forum 57 09-21-2016 08:03 PM
Question!! Grimes General Electrical Discussion 32 07-12-2016 12:53 AM
Electrical circuit question [email protected] NEC Code Forum 12 02-26-2016 12:29 PM
EMT Support Handasee Canadian Electrical Forum 6 02-11-2016 09:49 AM
