Terminal Torque - Electrician Talk - Professional Electrical Contractors Forum
Like Tree50Likes
Old 02-07-2019, 10:17 AM   #1
Maintenance2's Avatar
Default Terminal Torque
What do you guys use to torque motor starter, or contactor line and load lugs. Really aything that requires pretty high torque 30-45lbs or more and has a phillip's or a flat head screw? Most of the torque screwdriver I've seen are rated for 60 inch pounds at the most
Maintenance2 is offline   Reply With Quote
Old 02-07-2019, 11:31 AM   #2
Rewards Points: 2,618
I never used a torque screwdriver before. Where are you getting the specs from?
Maybe contact the manufacturer and hear what they have to say.
Old 02-07-2019, 12:34 PM   #3
Rewards Points: 1,874
No Philips or flathead screw is going to "require" anything close to 30-45 foot pounds. Where are you getting these numbers from?
Old 02-07-2019, 01:23 PM   #4
Rewards Points: 1,386
I have seen it before and after they stripped out the screw they realized it was INCH POUNDS.
Check your specifications.
Old 02-07-2019, 03:09 PM   #5
DashDingo's Avatar
Rewards Points: 14
I use either a flat head, Phillips, Allen head or hex driver screw driver ( which ever one fits) and my hand.
Tighten so itís tight but not to tight.
DashDingo is online now   Reply With Quote
Old 02-07-2019, 03:24 PM   #6
While I tend to agree for branch circuit wiring many of our customers are specifying torque screwdrivers. And then there is that pesky NEC.
John Valdes and MechanicalDVR like this.
Old 02-07-2019, 10:01 PM   #7
trentonmakes's Avatar
Rewards Points: 138
Just tell them they're torqued to German specs....they're all
Goodntite
Old 02-07-2019, 10:46 PM   #8
Rewards Points: 888
Im seeing a lot more labels and sticky warning tabs that have to be removed to install the wires saying max torque rather than required torque.
MechanicalDVR and Chops146 like this.
Old 02-08-2019, 05:30 AM   #9
Rewards Points: 3,400
That was bound to happen once impact drivers became popular as screwdrivers.
MechanicalDVR (02-08-2019)
Old 02-08-2019, 07:12 AM   #10
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
Man! I'm getting too old for all of this... these new torque requirements remind me of the AFCI nonsense... just a big pain in the butt! How many thousands of lugs have all of us torqued down perfectly down through the years?
John Valdes and armsjac like this.
jelhill is offline   Reply With Quote
Old 02-08-2019, 07:45 AM   #11
Elderly Member
jelhill's Avatar
That shows you how old school and out-of-touch I am... I have never owned an impact driver. Hammer drill yes... impact, no. I still actually tighten screws and lugs down by hand.... how crazy in that?!
John Valdes and splatz like this.
Old 02-08-2019, 10:08 AM   #12
Rewards Points: 1,466
Foot-pounds, inch-pounds, and Newton-meters are the typical torque ratings I’m familiar with.
If it is a UL-508 rated panel then the terminal torque ratings are required to be on a chart inside the panel or on the drawings.
Old 02-08-2019, 10:23 AM   #13
Rewards Points: 15,405
I remember how I hated it when they changed the code and I started having to ground ceiling light fixtures. I remember how I hated it when they changed the code and I started having to ground switches. I remember how I hated it when they changed the code and then I had to make sure my boxes were all pretty much flush with the drywall. I remember when they changed the code and I had to start using handle tie's on multiwire branch circuits. I remember when they changed the code and multiwire branch circuits became pretty much stupid to even consider running in any single phase panel period thanks to these stupid new circuit breakers some jackass invented that didn't work like they said they were supposed to. I remember when they changed the code and I had to quit running all the home runs into the panel thru a single 2" pvc terminal adaptor even if I put one of those fancy plastic bushings on the inside of the panel after the locknut. I remember when they changed the code and.............................
I don't even think twice now about any of the above...
MikeFL likes this.
Old 02-08-2019, 12:49 PM   #14
Sorry I misread anywhere between 20-40 inch pounds. Anyway what do you all use to reach the proper torque?
Old 02-08-2019, 01:00 PM   #15
just the cowboy's Avatar
Rewards Points: 348
My torque screwdriver is ALL metal. Even though I would never use it in an energized panel I still hate the fact that I am holding a metal device.
brian john and armsjac like this.
Old 02-08-2019, 02:03 PM   #16
Anything on this page
https://www.amazon.com/s/ref=nb_sb_n...e+screwdrivers
They should make these in different sizes
https://www.amazon.com/TorQ-Armour-M...e+screwdrivers
Old 02-08-2019, 02:38 PM   #17
Rewards Points: 18,694
Especially with guys that only use impacts!
Old 02-08-2019, 02:44 PM   #18
See that's a subjective statement.
How many lugs have you seen that had heat marks from being too loose?
How many so tight that some conductors were dug into or cut off?
Not all of us clearly have the feel for it.
Gnome and Chops146 like this.
Old 02-08-2019, 02:51 PM   #19
sbrn33's Avatar
Rewards Points: 3,198
I bought a torque screwdriver for each van. I would guarantee only one has ever been used. One more completely useless code that cost me money that I will never get back.
DashDingo likes this.
Old 02-08-2019, 02:56 PM   #20
Many, many years ago as a 1st year apprentice I helped my JW use some Kearneys to splice some 500MCM together. A couple of days later another JW asked me if we had hit them with a hammer & then tightened them some more before taping (we had not). The 2nd JW shook his head and said there’s going to be trouble with those splices later.
From that point on I felt like if beating them with a hammer was what it took to make up a Kearney correctly then they may not be the best product to use, at least on large High current wires.
Kevin_Essiambre likes this.
Torque speicfications needed for lockrings on PVC T/A? Rodger Code Violation Discussion 26 03-31-2017 08:02 AM
2017 Torque Requirements Semi-Ret Electrician General Electrical Discussion 28 02-28-2017 11:17 AM
2017 changes-- Torque Tools Majewski Tools, Equipment and New Products 43 02-21-2017 08:20 AM
Torque driver Anathera Tools, Equipment and New Products 34 06-04-2016 11:00 AM
GE THQL Breaker Lugs Splitting at Specified Torque Mr. Skookum General Electrical Discussion 16 03-11-2016 01:53 PM
