Terminal Torque - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree50Likes
Old 02-10-2019, 12:58 PM   #41
Wiresmith's Avatar
Rewards Points: 2,850
I tighten everything without a torque wrench first to what I think is just shy of the required value enough to make a small arc with the torque wrench, then finish with torque wrench in a smooth arc(that's also part of torqueing correctly). If my pre torque wrench torque was over the apparent required value I question the value, the only times this has happened is when I was going off a bad value. This of course is only when I use torque wrenches which I prefer to do but don't always, and only for large connections, with small connections like with screwdrivers I don't use 2 tools I think you can get a good sense with torque screwdrivers like you would a normal screwdriver. I think this method kind of calibrates my arm too for when I don't use a torque wrench and gives you a good sense for how much hand placement and wrench length plays into how much you are torqueing something. And yeah if the connection is not assembled well, you're p***ing into the breeze.
my opinion; The IBEW only does harm, It's actively exploiting and misleading young workers to pay for pensions that have been robbed by fat cats, with no care to their safety or well being.
Old 02-10-2019, 01:42 PM   #42
CoolWill's Avatar
Rewards Points: 488
Or you find a calibration certificate online and learn how to change the date.
Old 02-13-2019, 10:44 PM   #43
Rewards Points: 857
Originally Posted by jelhill View Post
Man! I'm getting too old for all of this... these new torque requirements remind me of the AFCI nonsense... just a big pain in the butt! How many thousands of lugs have all of us torqued down perfectly down through the years?
I've been in plenty of even industrial equipment where the failure was obviously an incorrectly torqued fastener. Heck last week I had to re-install one half of a parallel 250 neutral feed at a splitter because the wire had pulled free from the pad.
Old 02-14-2019, 07:54 PM   #44
Rewards Points: 3,208
Originally Posted by Gnome View Post
I've been in plenty of even industrial equipment where the failure was obviously an incorrectly torqued fastener. Heck, last week I had to re-install one half of a parallel 250 neutral feed at a splitter because the wire had pulled free from the pad.
A connection that is loose is loose because it was overlooked or stripped out during installation, and this will continue to happen torque wrenches or not. 99.9% of all electrical connections will be over torqued and with torque wrenches, the average electrician will continue to over torque connections.
I have used a torque wrench since 1974 on all bus and power conductors and will continue. Additionally, we have all torque wrenches calibrated yearly. I just think torquing switches and receptacles is stupid as long as quick stab switches and receptacles exist.
QMED, Kevin_Essiambre and gpop like this.
Old 02-14-2019, 08:17 PM   #45
Rewards Points: 58
I think wago should start making levernut devices.
Sent from my Moto Z (2) using Tapatalk
Old 02-17-2019, 12:24 PM   #46
QMED's Avatar
Rewards Points: 310
Agreed. I had to take a torquing class at a job and the instructor gave us a calibrated torque wrench and asked us if we thought thought we could hit the designated torque without going over spec. Most thought it would be easy. They had some special nut and bolt arrangement with a load cell attached so it gave some friction as I recall. Nobody hit the torque the first time they all overshot, some overshot by a huge margin. The key to not overdoing it was going extremely slow and smooth. So yeah basically every time I see people torquing connections like it's a lug nut on a semi I just laugh to myself.
QMED is offline   Reply With Quote
Old 02-17-2019, 09:28 PM   #47
Chops146's Avatar
Rewards Points: 1,032
I do the wiggle and tighten, tighten a little more, wiggle hard, and tighten more if it gives it. If QC checks it, they just put the wrench on and call it good if it clicks without moving. May be at specs, may be over, but none of my terms have ever had a problem in 17 years.
Kevin_Essiambre likes this.
None of us is as important as all of us.
Same plight, same fight.
An injury to one is an injury to all.
Chops146 is offline   Reply With Quote
Torque speicfications needed for lockrings on PVC T/A? Rodger Code Violation Discussion 26 03-31-2017 08:02 AM
2017 Torque Requirements Semi-Ret Electrician General Electrical Discussion 28 02-28-2017 11:17 AM
2017 changes-- Torque Tools Majewski Tools, Equipment and New Products 43 02-21-2017 08:20 AM
Torque driver Anathera Tools, Equipment and New Products 34 06-04-2016 11:00 AM
GE THQL Breaker Lugs Splitting at Specified Torque Mr. Skookum General Electrical Discussion 16 03-11-2016 01:53 PM
