Testing submersible pump motor - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By MechanicalDVR
  • 1 Post By Cow
Old 06-19-2016, 02:04 PM   #1
Rewards Points: 386
Default Testing submersible pump motor
So I have a megger but this is my first use outside of uf cable, what's the best way to check our little giant submersible pump? I read from the hot to ground wire but wanted to make sure I am doing it right before I condemn it to the dump
Anathera is offline   Reply With Quote
Old 06-19-2016, 02:22 PM   #2
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,582
They were to small to bother with. Check the impeller to see if it's stuck.
If it tripped your gfi, toss it.
I had a fish pond for 25 years, until this year.
Old 06-19-2016, 02:29 PM   #3
Rewards Points: 386
It may be my problem, I'm not so much concerned with the pump as confirming that it was the problem so that I can avoid a second work order. There were a few other variables that may have caused my issue as well. That would be the right way to read it right? It's really a sump pump they were using to fire the fountain
Old 06-19-2016, 03:13 PM   #4
Rewards Points: 3,412
Yep, hot to ground.
Old 06-19-2016, 04:47 PM   #5
Wirenuting's Avatar
If it was just a sump pump, it's duty cycle wasn't continuous I'm sure..
Little giant has some good pumps for running a fountain.
My pond pumps lasted about 5 years. I ran them 24/7 to keep the water aerated the fish.. I liked the sound of the water fall at night.
Old 06-19-2016, 05:53 PM   #6
Rewards Points: 24,126
Even the stainless body pumps with a continuous duty cycle are hit or miss for more than three years straight. They sure don't build them like they used to just 15-20 years ago.
Wirenuting likes this.
Old 06-20-2016, 09:11 AM   #7
Bad Electrician's Avatar
Rewards Points: 4,969
2-Wire Circuit?
Black to White
White to Ground
Black to Ground
I was born with a plastic spoon in my mouth.
The Following 2 Users Say Thank You to Bad Electrician For This Useful Post:
hardworkingstiff (06-20-2016), wildleg (06-20-2016)
Old 06-20-2016, 09:33 AM   #8
Cow
Rewards Points: 5,210
I've had the worst luck megging large submersibles?
I just did one a week ago, 125HP 480v, it megged .7 megaohms at 1000v, even after letting it test for 2 minutes to build the voltage up.
I closed the pump panel door, made sure the latches were tight, turned my head and pressed start. It ran. This is the second large submersible I can remember that I should of been able to condemn with my megger, that ran fine. I don't get it.
For regular motors, I usually tell customers anything below 25-50 megaohms is on it's way out, but these submersibles still seem able to run when they are almost shorted?
Bad Electrician likes this.
Old 06-20-2016, 06:48 PM   #9
Rewards Points: 386
Mine read bad too yet 9/10 it ran just fine. It had been in service two years in a heavily chlorinated pool though
Old 06-20-2016, 08:59 PM   #10
Cl906um's Avatar
Rewards Points: 1,206
Originally Posted by Bad Electrician View Post
2-Wire Circuit?
Black to White
White to Ground
Black to Ground
The pump..
Old 06-20-2016, 09:44 PM   #11
Originally Posted by cl219um View Post
The pump..
Sure if it is a 3-wire Black to white had better be a dead short or there's the issue.
To be honest I forgot he was meggering a pump, I was thinking the branch circuit wiring to a JB for the pump.
motor calculations... stonewhite NEC Code Forum 4 06-02-2016 01:13 AM
Deep well submersible pump - 26 - 954 Judoka Canadian Electrical Forum 3 05-11-2016 06:19 AM
Single phase motor wont start murph7489 PLCs, VFDs, Motors and Controls 41 05-09-2016 10:16 PM
New motor install KAD General Electrical Discussion 12 03-14-2016 05:34 PM
Motor overload setting katwalatapan Canadian Electrical Forum 9 01-26-2016 03:18 PM
